Toshiba VCR How to extract the video tape. VCR turns itself off in 10 seconds.
  • 2 more comments
  • g35tommyt Sep 12, 2008
    The VCR is a Toshiba M-683. I get a blue screen in the brief time it is on, but nothing else works, either from the front panel or from the remote.
  • g35tommyt Sep 13, 2008
    Frankly, I was hoping for something more specific to my Toshiba M-683 and the problem of it turning itself off after about 8 seconds, as opposed to a link to another (free) website.
    I inserted the tape and the VCR turned off. When I attempt to turn it back on, it only stays on for about 8 secords, then turns itself off.
  • g35tommyt Sep 17, 2008
    Manually cycled the mechanism and got the tape to eject. Tried another tape and had the same problem. Since I had (wisely) left the cover off, I was able to eject that one.
    I'm thinking maybe an inexpensive new VC player is going to be the best solution. Any thoughts?
  • 10,594 Answers
Some thing wrong in mechanism of vcr. Please take off top cover of vcr and turn back loading motor manually to eject cassette. Loading motors in VCRs usually rotates worm gear to start loading / unloading in vcr mechanism. in your case, it seems loading motor / worm gear is stuck. I hope, rotating manually will release it and vcr will start work normally.
Posted on Sep 13, 2008
  • Shahid Electronics
    Shahid Electronics Sep 13, 2008
    VCR turns off itself is not problem. Its just caused by stuck mechanism and micro processor of vcr waits for any mecha movement and then shuts down power to avoid any damage.
    Shahid Electronics Sep 17, 2008
    Yeah, you can get another vcr on ebay etc in less then $25 so its better choice.
    Genius:
  • 1,239 Answers
Hi
My guess is that the tape got wrapped around the capstan shaft so it
can't be pulled back into the cassette so that it can be ejected.
Somebody will have to disassemble part of the camcorder and manually
unwind the tape from around the shaft. Unless you are nimble of
hands and fingers, have a well lit work surface and possess jewelers
tools, that job is best left to a repair person.
thanks..........
Posted on Sep 12, 2008
  • 6,487 Answers
Check this link it has some solutions that you can try in removing the tape inside the VCR http://www.fixer.com/no-eject.html
Hope that helps...........
Vcr ejects after 10 seconds
The tape is wound tight or is not wound evenly creating friction. There is a safety feature designed into the vcr that senses that there is too much tension. Fast forward all the way then rewind all the way. This is the way it was in the 70's 80's for cassette tapes and vhs tapes. If the tape still ejects then check the belts.
Dec 01, 2013 | Toshiba DVR620 DVD Recorder/VCR
I put a tape in and I hear a loud clicking noise and the VCR doesn't play the tape and turns itself off after 8-10 seconds.
first, try another tape. if it does the same thing the vcr is out of alignment. many times a broken lever inside the vhs tape can cause the vcr to shut down.
Mar 05, 2010 | Panasonic PV-9662 VCR
1) I turn on the power and place a prerecorded
If it is not a bad soldering joint somewhere, it could be the mode switch. They can sometimes be cleaned with Servisol Video 40, but you might have to replace it.
Dec 21, 2009 | Panasonic AG-1980 S-VHS VCR
VCR tape was hung in Sylvania SRDV495. Got the
You need the aligniament the eject gears to tape gears.Please remove the cover platen and the rear cover(bottom) and align the gears manually.Obturated the sensors hole and insert the cassette.Verify the eject and the tape belts.If you have knowlwdge VCRs the problems solved in 1 hour.
Aug 21, 2009 | Sylvania Televison & Video
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Some tapes will start and immediately shut down
the vcr is on threshold of belt life. try replacing (or cleaning with alcohol) the take-up reel belt. The vcr has a built-in time-out feature to protect the video tape. if it takes too long for things to happen, shut-down occurs.
Aug 30, 2007 | Toshiba M655 VHS VCR
TV keeps shutting off after 10 seconds
It's possible from what you described that your center LED or prisim was broken when the tape was extracted. Like many others these units depend on a series of startup checks and one being the tape path. On the play table of the VCR is a center prisim/LED and two light sensitive diodes on either side of the tape loading assembly. If these diodes do not detect the infared beam the unit will go into shutdown. I'd check there and let me know. Bill
Jun 03, 2007 | Sylvania 6319CC 19 in. TV/VCR Combo
Tape stuck and tv turns off
With the set unplugged remove the back and extract the main board. You'll find a metal cover over the tape housing area that is easily removed by removing some screws holding it to the board area and manipulating some wired over it... You should then be able to see the tape and what's hanging it up. If you need to unwrap tape from the pinch roller or around the guides do so carefully. When it all looks free you can either manually crank the load motor assembly to eject the tape or put it back together enough to plug it in and press eject. If you do the later be VERY careful... Good Luck! Bill
Jun 01, 2007 | Sylvania 6313CB 13 in. TV/VCR Combo
Televison & Video Logo
205 people viewed this question
Top Televison & Video Experts
Electro Med Services...
