Question about Whirlpool Washing Machines
Washer saying f1 notr allowing me to open door model wgd9600twi
    Genius:
  • 1,028 Answers
Must be duet sport most likely main control but ck connections just in case remove screws on rear of top cover controls on right front
Posted on Sep 05, 2008
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Why does my washer say door open when it's closed
Hello Friend, this is Z. Thank you for allowing me to assist you!
I understand that your door indicates it is open and your washer will not operate. Try resetting your washer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. Select a normal cycle and verify if your washer will start. If your washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, I recommend contacting a professional to move forward accurately. Best regards!
Aug 08, 2014 | Frigidaire Washing Machines
Why do i get F1 notice and machine stops working
Whirlpool uses the F1 code for some of their front load washers when there is a problem with the electronic control board (the brain of the washer). You can try unplugging the washer for 30+ minutes.
However, it's likely that you need a new control board. (If the washer is still under warranty, contact Whirlpool.) Otherwise find the model number of the washer (usually inside the door). Then use the model number to find a replacement. The last time I checked the part is ~$175.
I hope this helps. Please add a comment with the model number of the washer for specific information.
May 15, 2012 | Whirlpool Washing Machines
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Whirlpool washer Model WTW6600SW2. Error F1
My boss's washer has the same problem, located the tech manual inside the washer at the front it was saying to check the pressure hose for any kinks if no kinks found and problem continues replace the motor control board.
Nov 13, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Couldn't open door after using Clean Cycle Function
hi thanks for the question there should be a solenoid at the back where the lock rod comes out check there thanks the appliance doc
Sep 23, 2008 | Thermador C301U Electric Single Oven
Problems with the washer
The manual for this model says the washer has tried unsuccessfully to unlock the washer. It suggests you ensure the door is firmly closed and to try again, if this fails then to unplug your unit for 2 minutes to allow the circuit board to reset.
So far as the clothes being wet, you may have a situation where the load became unbalanced and the drum struck the interior floor of the washer where a switch is located. This swich is designed to stop an unbalanced spin cycle from damaging the machine. To reset this, remove the four screws inside the doors opening. This will remove the door and allow you to pull off the face of the washer. On the base of the drum where you will find a switch. Depress (push upwards) on the button and ensure it is in the outer most position to reset the switch.
See link for manual
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_2727060.PDF
Hope this helps!
Dec 15, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De GO PATS
