Question about Maxtor DiamondMax Plus 6800 (91366U4) 13.6 GB Hard Drive
Can't find OS
It was working for years, then on boot made a high whining sound (almost screeching) and then got a message that no operating system could not be found. i plugged in my old (ME OS) machine and ignored the problem for a month, tried it again ad it boot.. but had incredible lag. so i tried to sestart, only to get the "no OS" message again. but i feel it's at least close to working.
- solution 1: different IDE cable.. no difference
- solution 2: swap hard drives: system boot to ME from the other HD, but i'm missing loads of drivers, and ME, ew.
unfortunately, this computer was passed along to me without the Windows XP installation disks, so making a BartsPE boot disk seems to be out of the question. as it's an old machine, but sure it's worth repair money, but it is a better system than i'd otherwise have!
also i had been "bad" hadn't run disk cleanup tools in ages, and had filled up the space on the drive up to about 1 GB remaining. i'm guessing one or the other of these caused my problem. uhg.
anything else to try to get the HD to boot? or do i just set it to slave and pull any files i need off of it?
    Sergeant:
  • 359 Answers
Even if you set it to slave, what has happened is the drive motor is burned out. Lets face it, your HDD is dead and there is no hope of recovery unless you take it to a data recovery shop, and that is $$$$.
The No OS message is the worst message you could possibly see and that is a direct indication that your HDD is dead in the water.
Just go get another HDD or go buy XP to replace ME on that other HDD you have.
Realistically there is nothing you did or didn't do to cause a harddrive failure. It is just the way of the world nothing lasts forever...
Posted on Sep 04, 2008
High pitch screeching on my pc cannot fix thru speakers check ok
Unusual noises coming from your computer can mean anything from serious trouble to no problems at all. The uncertainty, together with the expense of computer hardware components -- not to mention the risk of losing data and being without your computer -- make it important for you to investigate any unusual sounds as soon as they come to your attention.
Normal Sounds
Not every high-pitched sound coming from your computer suggests a problem. Computers also generate a variety of sounds as part of their normal operation. In particular, anything that spins can easily make noise. This includes cooling fans and the hard drive. In the case of fans, their sound sometimes grows louder when the computer works harder because it needs to run the fans at a faster speed in order to dissipate the extra heat from the higher level of operation. You probably don't need to concern yourself with an unknown high-pitched sound unless you have used the computer for a while and the sound is new. b> Capacitors Capacitors sometimes make a high-pitched buzzing sound, either when under a high load or when defective. In the latter case, faulty construction can cause gas to build up inside the capacitor, which then vents under pressure and sometimes creates an audible noise. Defective capacitors can damage or destroy other hardware. f you suspect a bad capacitor, or don't know what else it might be, give your computer an inspection. b> Capacitors Inspection b> Your computer has capacitors all over it, including on the motherboard and on nearly everything that plugs into the motherboard, so tracking down a bad capacitor can take some time -- especially if you don't know whether a capacitor is actually causing the problem. Many capacitors look like tiny little soda cans and smaller ones look like squat cylinders. Failed capacitors usually bulge out at the top or have crusty residue around them. Be sure to check not just the motherboard but also any other hardware components with visible capacitors on them. If you find a bad capacitor, keep looking in case you find more. Afterward, don't use your computer again until you repair or replace the faulty hardware. Fans b> The bearings and motors on fans sometimes go bad. If this happens then the fan may begin to whine, whether or not it stops working. If feasible, open the side panel of your computer tower with the system running and try to pinpoint the exact source of the sound. If you can determine that the noise is coming from a fan, power down the computer and replace that fan. b> Power Supply Unit b> Power supply units sometimes make a high-pitched whining or droning sound; it can happen continuously, when you perform certain tasks on the computer or when you take the power load high enough. This can happen either because of cheap construction or because the unit is too close to maximum capacity. As you would do to check the fans, open the side panel while the computer is running and put your ear up to the PSU. If this is where the noise is coming from, replace the unit with a high-quality model and upgrade to a higher power output if you need to do so. Hope this helps.
Jan 08, 2013 | Acer Aspire Z3100 (2771498) 21.5 in. PC...
Screeching noise, especially w/heat on
SOUNDS LIKE YOUR A/C COMPRESSOR IS DEFECTIVE. WITH HEAT ON COMPRESSOR CYCLES FOR LUBRICATION
May 08, 2012 | Mitsubishi Cars & Trucks
Boot problem
Reinstall your operating system. First start p with the method you described, then backup all important data. YOU WILL LOSE EVERYTHING ON YOUR HARDDISK SO BACK UP IMPORTANT DATA AND PROGRAMS, OR YOU WILL LOSE THEM!!! Then insert the disk with your Operating System, and restart the computer. Boot from the disk and install the OS. After that you can reinstall your prgrams and put your data back on it.It should boot fien from now on. If not, please post back here. I hope this helps, Yannick.
Jun 08, 2009 | Samsung P30 Notebook
1991 CR 500 (reving to high on idle high serges)
take some wd 40 & spray around the carb boot while running to see if the idle drops for a few seconds. sounds like you have an intake side air leak causing a lean condition making the motor rev high.
Feb 16, 2009 | 2001 Honda CR 500 R
Boot Loder Problem when working with two operating System
best practice it when installing windows and linux install windows first and then linux. GRUB or LILO boot loader is much better then windows boot loader and very easy to reinstall. Mandriva cd should have a rescure feature that will allow you to reinstall the boot loader.
Jan 15, 2009 | Computers & Internet
''operating system not found''
This message means it cannot find the OS. Is the OS hard drive working? It could be damaged or missing. I would check this first. Which operating system were you using?
Nov 21, 2008 | Computers & Internet
Polaroid 373b Blues!
what does the board look like in same area as black arc spot on case (damaged??) the high pitch whine you hear is the high freq switching going on in the electronics , this by itself is not too bad ( I had an old floursent clock that whined so loud it made my dog howl !! and it still works !! ) but when it accompanies a non functional device id say the power supply is straining to provide power (over loaded)
Mar 04, 2017 | Polaroid FLM-3732 Television
Missing operating system
missing operating system message usually means that your HDD is pooched, or corrupted
check your bios settings to check that it can still "see your HDD"
if you can hear your hard drive going "click, click, click" when attempting to boot, that is usually a bad sign
to perform setup use orignal recovery setup disk or OS disks of your choice (BOOT from CD) to install OS from scratch.
Sep 30, 2008 | Microsoft Windows XP Professional With...
Boot up problem
i would format it redo it al ok fresh boot tell cd to go 1st in bios and not hd hard drive ok
Feb 06, 2008 | Adapters.com CAT 5 LAN Computer Network...
Maxtor DiamondMax Plus 6800 (91366U4) 13.6 GB Hard Drive Logo
78 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
