Laptop networking issue
I have never seen anything like this before. The laptop will not boot up in the house plugged in or not. They take it outside, and it works. A tech guy came over to the house and installed a wireless router in the house as well. Any ideas???
  • 2 more comments
  • steveheiner Sep 05, 2008
    From what I have heard, the laptop doesn't boot up at all. Either windows or the CMOS check. When it is taken outside, it boots up perfectly.
    I will investigate it a bit more with what operating system is being used, what brand laptop it is, what errors are comming up. I am under the suspision that it could be a power problem, i.e. the battery is bad or the power supply.
    I am also thinking it picked up a nasty virus when it connected to the internet and just froze up. I will post more when I have more answers.
  • Anonymous Sep 05, 2008
    just brought a new laptop from Ace it will not boot up in the house and when I took it out side it tried to but did not happen. Do laptops have already install entranet, because I see that the name of the program is Signal wireless. I just got this laptop 2 days ago and can not connect to the enternet. Please help Gwen S
  • steveheiner Sep 08, 2008
    I just found out that they had the geek squad come over and install the new router in the house. They connected it wrong and that is why the laptop has been crashing and freezing up.
  • Matthew Rodela
    Matthew Rodela May 11, 2010
    Please confirm that you're saying the laptop doesn't even boot into Windows? At what point in the boot process does it stop?
    I think you may mean that the laptop doesn't connect to the internet inside, but it does outside. If that's the case, let me know and we can easily troubleshoot it from there.
Pxe e61 media test failure
Solution:
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Cause:
PXE (pronounce Pixie) is an agent used to boot on to the network
It's using the DHCP protocol to localise a server where the image of the OS is located
In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
That is caused by the hard drive is missing, unplugged or failed
Aug 07, 2014 | Toshiba Satellite Computers & Internet
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
Ethernet issues.
Can you plug pick up internet with a different laptop in the same place? If another laptop can plug in with the same ethernet cable and get a signal then you know its "your" laptop and not the cable or the connection, If it is your laptop that is the problem, check to see if your network card is working properly by going into device manager. My guess is you need a new network card.
Aug 20, 2012 | Toshiba Satellite L655-S5156 Notebook -...
Ethernet adapter not visible
Try installing the latest LAN driver.
Download the LAN and device drivers from the Acer WEB site. Makesure you select the model of your laptop the drivers you that require thatmatches the Windows version that is installed on your laptop. Use this link toget to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
Feb 26, 2012 | Acer Aspire 5100 Notebook
My laptop does not work it says PXE-E61:Media
Cause:
Jan 11, 2011 | Acer TravelMate 4062LCi Laptop Charger...
Laptop turns on then freezes
Shut it off, pull the battery out. Unplug all devices that you might have plugged into the laptop (anything USB, cards, etc).
With the battery OUT, and the power cord unplugged, hold down the power-on button for about 20-30 seconds. Reinstall the battery and/or power cord and then boot the machine into safe mode (hit "f8" white booting on windows operating systems to get into the safe mode menu). Try booting safe mode NO networking (top choice). Still locks up?
Possible issues are
1) Bad or failing HD
2) Failing RAM
3) Virus or drive issues.
Booting into safe mode should allow you to run a virus scan, then clean and defrag the HD and check for resource conflicts or "flags" for issues (control panel, administrative tools, browse until you find "Event Viewer" and click each icon in the drop down field on the left and read the "errors" in red on the right).
We'll need your OS and laptop model number as well as things like wireless devices or anything custom you've done or have installed.
Sep 05, 2010 | Samsung Computers & Internet
PXE-E61 media failure when i start up my computer
The PXE-E61 failure is a failure to boot to the network card, this generally indicates a problem with the hard disk drive.
  1. Boot to the BIOS and reset the defaults
  2. Reseat the hard drive
  3. Boot to Windows CD and run CHKDSK /R on HDD
If the system will not boot to the HDD, but it is seen in BIOS, then the HDD may have an OS issue, if not detected in BIOS HDD likely has failed.
Mar 02, 2010 | Acer Aspire 5315 Notebook
Medion akoya e1210 notebook. failure to boot pxe
Failure to boot PXE 061 is a BIOS message that indicates 2 things:
  1. System failed to boot to the hard drive
  2. System failed to boot to a network connection
The apparent problem is failure to boot to the hard disk. If the system was running yesterday and there have been no hardware changes to the system, then most likely failures are:
  1. HDD failure (Replace the HDD, reinstall OS and applications) I hope you have information backed up.
  2. HDD not being detected by the motherboard due to connection issue (Remove HDD and reseat it, then see if seen in BIOS) If no change replace hard drive, if new drive not seen, replace motherboard
Jan 11, 2010 | Computers & Internet
Cruster jumps allover screen
Try updating the video driver and the BIOS. See if anything changes. If not change try booting to Safe Mode (F8 at boot) and see if the issue occurs there. If it does, replace the palmrest, if not edit MSCONFIG Startup group and Non-Microsoft services and see if the issue stops.
Also, id you haven't moved the system from it's location, try a different room or outside I've seen appliances like air filtration systems cause point issues too
A palmrest on Ebay, generally abour $50 to $100 depending on model
Aug 29, 2009 | Computers & Internet
Ethernet NIC card not seen in Network adapter (code 31)
Code 31 means that the device drivers are incorrectly installed.
In order to solve the issue fully, can you please tell me what Operating System you are using.
Jun 19, 2008 | Toshiba A205-S4577 Notebook
Open Questions:
Computers & Internet Logo
David Payne
David Payne
