Question about Sony FD Trinitron WEGA KV-21CL10 21" TV
SONY KV-XF21N90 WON'T TURN ON, Blinks 5 times
I'VE OWNED A SONY WEGA KV-XF21N90 FLAT SCREEN TV FOR 5 YEARS AND NOW THE THINGS WON'T TURN ON. ALL ITS DOING WHEN I PUSH THE POWER BUTTON IS MAKING THE NOISE OF TURNING ON BUT NOT DOING IT. NO STATIC BUT THERE IS A RED LIGHT FLASHING 5 TIMES FOR EVERY 5 SECONDS.
  • 1 more comment
  • evilmikethyk Nov 04, 2008
    the tv will not turn on. stand by will flash a couple of times
  • Anonymous Mar 28, 2014
    5 times bilink
    Hookup to a home thear.
  • 10,594 Answers
5 times flashing light shows following possible problems in your tv..
• G2 is improperly adjusted.
• CRT problem.
• Video OUT IC1800 is faulty.(C5 board)
• IC301 is faulty. (A board)
Most probably cause is G2 voltage adjustment. If you know how to do it, please go ahead or look a tv tech around.
Regards,
Posted on Sep 04, 2008
My tv kv-xr29m50 won'to on.stand-byl light blinks 8 time
Count the number of blinks occur at one time switch ON. These blinks are fault indications. After counting it, check this link for more details. There are details about Sony blinking codes. Search the site by brand name and model number to your TV in its search box.
Jan 29, 2013 | Sony FD Trinitron WEGA KV-13FS100 13" TV
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32.FS120 wont turn on and stand by flashes 5 times. Is this any easy and inexpensive fix or not worth the time and money since tv is 6 years old ?
5 blinks indicates that your system has detected fault on Chroma board (Chroma board is the only board connected at the rear part of CRT). Often there are loose connection on IC terminals. Re-soldering of ic terminals can fix your problem.
Oct 19, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega Kv-36XBR250 screen blinking
I have seen this flashing before, this could be an indication that the picture tube is weak, what happens is that if the white balance is off there is a circuit called akb it monitors the kathode of each gun and if they are not in balance it will attempt to balance it out. if it can't the picture will begin to flash, sometimes in some models the power light will blink 5 times. On some models the power light will only flash if the tv gives up trying to compinsate for white balance and shuts off compeletely. If you see the tv shutting off with 5 blinks then you know for sure it is time for a new set.
Sep 02, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Tv shut itself off while I was watching.
The power supply will need to be replaced. You can get them for $30 plus dollars and solder them in.
Aug 02, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-27FS210 won't turn on: 5 blinks
If you have little experience of TV repair then take off back cover of Sony Kv-27FS210 and find Screen Control Knob on flyback transformer, turn that knob slightly CW or CCW and turn on TV to get picture. I think you need to turn ON TV few times to get proper adjustement of screen volts.
Above said procedure is for non-tech person.
(Tech person will adjust screen volts (G2) as per procedure mentioned in service manual with proper tools.)
Jul 28, 2009 | Sony FD Trinitron WEGA KV-27FS210 27" TV
My 32'' sony wega blinks 5 times
The 5 blinks means a problem in the set's AKB (auto kine-bias) circuit. Sony TV's monitor the operation of the picture tube. When some kind of trouble has been detected, the TV blanks the screen and flashes the 5 blink error code. This may be due to problems in the video circuit, a bad picture tube, or adjustments that have changed due to aging of parts. There isn't anything I can suggest you try on your own to fix it. Because several things may cause the problem, and the proper tools and service information needed to troubleshoot, you should refer this repair to a professional.
Feb 17, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony wega trinitron won't turn on
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • and some times the eprom ic is fulty ...
  • try to unplug your tv from the main power for 5 hours then press the power button and keep pressing for 7 seconds then release ,if this do not work ,you should take your tv to a qualified person
  • i hope this helps ..
  • Jan 01, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
    SONY WEGA KV-32XL90E
    Hiii...
    what chassis your tv set ?
    Thank's
    [Vrya]
    Jan 23, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
    My TV will not turn on!
    I have a tie dye of rainbow colors on the whole screen. Is the screen shot?
    Dec 08, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
    Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
    392 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
