Question about Bernina Bernette Deco 600
Needle is hitting something
I am new to embroidering. I just purchased a deco 600 and it worked great on the first 4 things I embroidered. Then it started making anoise like the needle is hitting something. i changed the needle,bobbin,fabric,tension. I removed the bobbin and inner rotary hook to clean and try to see what it is hitting.The bobbin side is embroidering fine the top is not, looks like the bobbin thread is not catching the top thread. Should I take this in for repair or try to fix myself? I was sewing patterns fine until the thread got stuck on 1 pattern. I got it unstuck but know the top thread will not pick up the bottom thread. I opened it up and it looks like the bobbin thread is not getting grabbed or picked up by anything down there. I am good at problem solving and following directions if you could suggest some things to try I would appreciate it.
    President:
  • 1,952 Answers
Tightng the needle bar . bobbin case screw is lose adjust the screw
needle portion is just adjust take bottam thread
Posted on Sep 04, 2008
    Genius:
  • 2,028 Answers
I'm going to suggest taking back for exchange. Obviously, there shouldn't be any noise of something hitting, so I'm going to say the either something internally is bent, broken, or misalligned. With it being as new as it is, you shouldn't have any problems at all, especially one of this nature.
    Genius:
  • 3,422 Answers
HI,
You will have to retime your needle.Try this out:
"Timing" is the alignment of the needle at its lowest point and the hook on the bobbin case. The point of the hook must pass directly behind the "scarf" of the needle fo the interlocking loop of a "single needle lockstitch" machine to occur. Look closely at the needle. You will see the long groove along the front of it. This is where the thread rides as the needle goes up and down. If you look at the back of the needle you will see a flattened area just above the point. This is the "scarf"; it's flattened to permit the hook of the bobbin case to run right by it and catch the loop.
When a machine is out of "time", the hook is either too early or too late, OR to far away from the scarf to make the connection. You can send a machine out of time by hitting a pin, or breaking a needle "hard" (too fast through too many layers, etc.). You can usually identify a machine that is out of time by multiple skipped stitches at high speeds, or by stitching fast and then quickly putting it into reverse. Sometimes, you can scrape by if you rotate the insertion of your needle a little bit, this can help compensate for minor timing issues.
  • Priya darshan Sep 04, 2008
    Please don't forget to accept the solution as fixya.
    If you need anymore help let me know.
  • 421 Answers
Look down in there there is a hook to grab the top thread may have gotten bent or loosend , you may also try comparing the new neddle with the old and be sure it is correct, look for a small latch under the grab foot, please rate -jeff
  • jeff r
    jeff r Sep 04, 2008
    remove the metal plate and make sure you positioned the hook correctly and run the machineby hand to be sure the bobbin is working correctly -jeff please rate
My deco bernette 500 embroidering machine won't sew and the bobbin don't pick up all the time
Try a brand new needle. If that doesn't help, most likely your machine has been knocked out of time. Take it for service.
Sep 15, 2017 | Sewing Machines
Needle arm loose
Your machine needs retiming that is why the hook is not picking up the thread.
check to make sure first of all that the needle is in the correct way round
Oct 16, 2008 | Bernina Bernette Deco 600
When I turn on the machine I get a message that says Lower needle, raise pressure foot and power on machine. It is making a noise and the carrige wont move.
it's possible that breaking the needle could have done something to the computer or damaged a part of the machine, having the machine checked
would be a good idea
Apr 15, 2012 | Bernina Bernette Deco 600
I have the Deco 600 and it's a workhorse! I love the machine. I just had it serviced and now when I embroidery and use white bobbin thread it shows on top. I have tried adjusting the tension like the...
I have a 600 also...have you changed brand of white thread? Sometimes it can be the design you are embroidering that will bring bobbin thread to the top. I use the prewound bobbins--very thin thread & tightly wound.
Jun 15, 2011 | Bernina Bernette Deco 600
I broke my small frame embroidering hoop. where do I look to buy another one. I have a bernina deco 600
They are available from baby lock, brother or bernina dealers. Same hoop.
Derek
Jan 17, 2011 | Bernina Bernette Deco 600
Spacing between words
I have the Model 600. In the characters, there is one that looks like an "underline". Actually, it allows a space between words and does not make an underline mark. Some of the embroidery machines use that character to allow a space between words instead of having a "space" character.
Dec 27, 2009 | Bernina Bernette Deco 600
Problem with threads not catching
Try putting in new needles. Make sure they are in the proper position. There is a stopper which keeps the needle down far enough to make the right connection. Sometimes the needle stopper, after long use, moves up a little which prevents the needle from going low enough to pick up the bobbin thread. You could try lowering the needle just a little. Not to far, or it will break the needle. Sewing machines need a lot of oil. Not all at once but a drop or two after an hour of use. All lint needs to be removed from under and around the bobbin before it is oiled. Keeping the machine clean and oiled is the life of the machine.
Zelma
Dec 26, 2007 | Bernina Bernette Deco 600
Sewing Machines Logo
248 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
