My Dell monitor works fine unless I open a program! Everytime I try to open a program, the monitor flickers back and forth from the regular screen to a screen that says "Dell.com Genesis Display Perfection." It will not stay on the regular screen at all unless everything is closed.
SOURCE: Screen not working
there is a problem with the degausing coil of the monitor. just open the case and try to clean the degausing coil. thx jsut vote for me so that i can help u better.
SOURCE: Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
SOURCE: I have a Dell E173FPc monitor. The power flickers on and off.
The blinking power light usually indicates a blown power supply board. We have a step by step repair guide posted on our web site at: www.ccl-la.com If you don't want to do the repair yourself we do offer a repair service. If you have any questions just contact us at the address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
[email protected]
My monitor is doing the exact same thing
YES!!! the same thing has been happening to me!
