Question about Nikon D70 Digital Camera with 18-50mm Lens
Can't see renamed images
I have just got a nikon d70 and have a quick question. After I have edited and renamed an image, then transfer it back to the memory card I am no longer able to view it. Am I doing something wrong? When I check the D70 "drive" under My Computer, the files are there, but I still can't see them. I want to use the video connection to show people pics that don't have a computer. Thanks
    Sergeant:
  • 255 Answers
Check out this link: http://bermangraphics.com/press/ex-z55.htm A package called TV Writer is described, which will enable you to view post-processed images back on your camera. Hope this helps
Posted on Sep 19, 2005
SOURCE:
Cannot transfer images from camera to computer using view nx2
Nikon split the functionality between two programs. ViewNX lets you catalog, view, and edit your images. Nikon Transfer is for transferring pictures from your camera. Current versions of Nikon software Nikon Knowledgebase
May 07, 2014 | Nikon Capture NX2 Photo Editing Software
DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Nov 02, 2007 | Nikon D70 Digital Camera with 18-50mm Lens
I have a Compact Flash card of 512mb (CF card) i use this card in my nikon D70, i went to my friend house and tried connection my camera to his comp to download image, but my friend machine was infected by...
Guide to recover deleted photos from Nikon D70?
Connect Nikon with PC
Using a USB cable or putting SD card into an SD card reader to connect Nikon with Computer.
Scan Nikon d70- Running the Nikon Photo Recovery,you can choose Nikon media drive and click "Start Scan" for scanning
Recover deleted photos
After scanning, you will see all recoverable media photos and videos with file type. At last, click "Recover" to recovering deleted Nikon D70 photos.
This Photo Recovery also can recover all photos files from Nikon D3100 like JPEG, BMP, TIFF, GIF, etc. Support all Nikon camera.
For full details please refer to Nikon D70 Manual.- https://guideusermanual.com/product-name-d70-manual&po=4425&lang=English
Mar 28, 2017 | Computers & Internet
Nikon D70 not showing shots in order as when i take them.
Greetings...
There are a couple of things to look at here...
Your camera settings and your computer file settings...
For the Nikon D70 make sure the file number sequence is set to on...
SET UP MENU (wrench icon)
File Number Sequence: This lets the camera number your images starting at the last shot you made, even if you've formatted your card. I leave this to ON. If you turn this feature off you'll start from 0001.JPG each time...
Are you working on a Mac or PC?
If you are on a PC make sure that the program you are working on is set to sort by name...
If your Nikon was not set to sequence, you will need to rename the files. Nikon has a free program, ViewNX, that will allow you to view, sort and rename image files...
Additionally, on a PC, open Windows Explorer, go to Tools, Folder Options, View, and UN check the 'Hide extension' box...
This allows you to see the naming extension's on you files...
Have a great day....
May 07, 2008 | Nikon D70s Body Only Digital Camera
NIKON D70
problem in card holder repair or replace
Feb 11, 2008 | Nikon D70 Digital Camera with 18-50mm Lens
Can I transfer photos back to the card after editing the images?
Nikon complies with the industry standard DCF (Design Rule for Camera File Systems) format which governs the file structure of images on memory cards as well as file naming and other image properties. Due to the constraints of this file system, images that have been edited may not be able to be read by the camera when copied back to the card. The card can, however, be used to move images (or other files) just like any other removable disk. To do this connect the camera to the computer using the "MSC" USB mode (where supported) or use a third-party USB memory card reader. The camera's card will then appear like any other "Removable Device" and files can be copied to it. Nikon cannot offer additional assistance in transferring images back to the card or viewing edited images on the camera.
Aug 30, 2005 | Nikon Coolpix 2000 Digital Camera
D70 USB setting issue
Users of Windows 98SE, Windows ME, Windows 2000 and Mac OS 9.x may experience problems trying to download images from the Nikon D70 using Nikon View. Initial shipments of the D70 have the USB option in the "Set up" menu set to PTP - Picture Transfer Protocol. PTP is only compatible for downloading images with Windows XP and Mac OS X. To solve this issue please set the USB menu option to Mass Storage and then connect the camera to the computer. The D70's card will then mount like a removable disk and Nikon View will be able to transfer images
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
NEF Image will not open - Macintosh
RAW NEF images from Nikon cameras are proprietary formatted raw data directly from the cameras's sensor. If the images are improperly transferred to the computer they will not be able to be opened and will give an "Unsupported File Format" warning. Macintosh OS X has an "Image Capture" application (found in: Hard Drive/Applications/)that can be used to transfer images. If "Image Capture" is used NEF files will be corrupted and will not be able to be read. Only Nikon View, or manually dragging images from the mounted card, should be used to transfer NEF's. To disable "Image Capture": Double-click to open the hard drive and then the "Applications" folder Double-click "Image Capture" From the "Image Capture" menu choose "Preferences..." In the "When a camera is connected" pop-up choose "No Application" Close the Preferences window and Quit Image Capture After disabling Image Capture, it will not launch when the camera is connected and you can use Nikon View to properly transfer NEF images.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Nikon D70 Digital Camera with 18-50mm Lens Logo
62 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
