Question about Philips HD-7810 Espresso Machine
Philips HD-7810 Espresso Machine - lid jam
The lid of the machine has jammed in position and I cannot open the top of the machine to access the used pad/padholder in the normal way. Perhaps a vacuum is present but I do not want to force the lid open in case I damage the machine. All guidance/suggestions are most welcome. Thanks!
  • ineke554 Oct 22, 2008
    Same problem - lid stuck, held by vacuum suction. It happened when I used a Capuchino pod - we were able to finally get it going after 15 minutes, but now it happened again with the plastic refillable pod and we cannot get the lid open, not get it going again. We left it outside to cool off all night. I am afraid I am going to break the coffemaker.
Have just been saved by signing in & reading the 'solution'. Thank you. The vacuum did eventually release itself & hey-presto!
Posted on Oct 26, 2008
The dispenser drawer on my AEG Lavamat is stuck half open and appears jammed. Help please
Open the machine up on the top lid. 2 screws at the back of the machine at the top. Slide the lid back and remove it. The drawer can now be accessed. There should be a bunch of clips holding the lid of the drawer . You can carefully open these clips to remove the lid or just remove the entire drawer assembly and replace it or try to figure out what is jamming it.
Jan 22, 2018 | AEG Washing Machines
Why lid wont close when pod is in holder ?
Did you place the lid in correct?
Is it the lid that came with the machine?
You should have two, one for one pad, and one for two pads. Make sure you only put in one at the time.
You can fine the manual online, but the most important pictures are here too e2d40f99-b185-43c6-bffd-a3c704f68e25.png
Jun 07, 2014 | Philips Senseo HD-7810 Coffee Maker
I have a new senseo machine & inadvertently stopped the initial flushing process. It doesn't appear to be working properly now.....what do I need to do to rectify this
"> It is quite common. If your machine is less than 2 years, contact Philips and they will give you a new one. Else, It takes a bit of patience to disassemble the machine. (The version that I have HD-7810) you have to: ) 1. remove the water tank;remove the back part that is touching the water 2. remove the back cover beneath the water tank; 3 spot 2 screws at the sides of the vertical plastic, one on each side(better to use a light or led to really see it); 4. Remove the screws with a Philips driver; 5. Use a small sharp tool to pop open the under cover of the machine - star by one of the sides, go through the part where the buttons are and continue untill all of it is off; 6. You will see a yellow rectagular capacitor. Desolder and solder a new one. 7. Close the machine as nothing happened and enjoy the coffee!
Aug 03, 2013 | Philips Senseo HD-7810 Coffee Maker
Hi i have à senseo HD 7810 which i bought à week. R after running through the power up and forst time clearing procedure,The power light Doesjanbe not stay on. Therefore it is impossible to get...
You can repeat the cleaning procedure once more; there may be some air trapped in the machine. If that doesn't help, it's a warranty case I'm afraid.
Aug 06, 2010 | Philips HD-7810 Espresso Machine
Senseo HD-7810 Coffee Maker: how many uses can i get out of one coffee pad?...
Hi. They are only made for one shot, because the coffee will get weaker and weaker the more you use it. Also, it can compact and not let anything through.
The official stance from Philips on their website is this:
"We do not recommend this. The second cup of coffee will be rather weak. Also make sure the lid is closed properly, and do not press the 2-cup button if you want to brew only one cup."
May 16, 2010 | Philips Senseo HD-7810 Coffee Maker
Senseo hd7810, The locking/unlocking latch on the
The product is still in production, so that should not be the problem. Question is whether the handle is a spare part.
G
Mar 02, 2009 | Philips Senseo HD-7810 Coffee Maker
Replacement seals for Senseo Coffee machine
If no good,
Call senseo at 866-4-736-736 866-4-Senseo and describe the problem.if you have purchased or received it as a gift less than two years ago they will send a new one FREE.
Nov 22, 2008 | Philips Senseo HD-7810 Coffee Maker
Water does not reach the spout. After flushing it leaks out, warm.
Senseo Customer Service offered to replace the unit under an extended warranty plan.
Mar 07, 2008 | Philips HD-7810 Espresso Machine
Philips HD-7810 Espresso Machine Logo
200 people viewed this question
Top Philips Coffee Makers & Espresso Machines Experts
Kolbrun...
Lisa
Lisa
just-ice
Are you a Philips Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
