We have a jvc av-27bm5 (manufactured 1995) .. it was purchased used for our teen's room, we do not have the original remote and have purchased a universal remote. The problem we are experiencing is a black square in front of the picture leaving only a border all around. Someone told us it may have to do with "closed caption". We have Star Choice installed on it and the teen has an x-box 360. Can you help us remove the black square without having to purchase the original remote at a cost of $100.00.
techman
  • 3130 Answers
SOURCE: help
No a universal would not let you use any functions but the power volume and channel up and down. Go to http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=50A50&brand_pn=TOSHIBA_50A50&mode=large&uid=11646537713590 to get an original replacement remote alot less then what toshiba sells it for. Good Luck Please do not forget to raye this thread.
Posted on Nov 27, 2006
circuitcity
  • 137 Answers
SOURCE: closed caption and black square
your TV do not disable close caption in composite mode. It may in component mode. Please make sure that the close caption in your TV menu is not set to "text"
Please be advice that CC :Text is the ONLY one that can give you a black box.
Best regards
Circuitcity
Posted on Dec 09, 2007
mattballew
  • 89 Answers
SOURCE: Remove CC Black Box without original remote?
Hello, I was the one who assisted you in Live Chat, Just wanted to remind you to rate the chat session, Thanks. Have a great day!
Posted on Nov 25, 2008
pgh_pa_guy
  • 2992 Answers
It can be done with the front panel buttons. Here's a link to the user manual from JVC's site. It's covered in the book.
http://resources.jvc.com/Resources/00/00/99/LCT0305-001B-A.pdf
Posted on Dec 07, 2008
SOURCE: Toshiba TP50G60 Big Black Square Covering the screen?
try the closed caption adjustments. i had a tv that did the same thing and the captiong did it. turn caption off nd try.
Posted on Dec 19, 2008
How do ni turn off a channel guard on the remote of a 1995 av-27bm5 tv
Good, go to menu and locate close captions--there you will find a setting for TEXT, it is engaged--switch it off.
Apr 16, 2012 | Televison & Video
Received this TV from a friend, was working when it left his house, I have place on tv stand, plugged it in, hit the power button, it came on for a breif second. Now the on-timer light is blinking, I can...
what was that outside temp in transport, was it in the cold. If so the unit needed to get back up to room temp before pluging in, if not you will blow the starter.
Mar 06, 2011 | JVC AV-32150 32" TV
I have a JVC AV-27120. Just purchased a new remote but the TV codes that came with the remote user guide dont work. What is the 3 digit code for my TV to program the new universal remote?
The codes in the owner manual don't work not any codes out here will help u.Return the universal remote.Try website like Remotes.com to buy an exact remote as original remote,might have some new JVC codes u could tries,but not likely it will work either.
Feb 02, 2011 | JVC AV-27120 27" TV
God morning Sr. a need service manual of AV-27BM5 PLEASE. Thanks ..
I could not find a free service manual, which is not uncommon.
I found a service manual for your JVC TV at
http://www.service-docs.com/store/search.php?searchstring=JVC%20BM&showresult=true&exp=&resultpage=&categories=&msg=&search=search.php
Scroll down to your model and you can buy it for $12.95.
Apr 10, 2010 | JVC Televison & Video
AV-27BM5 relays click on but no picture,high voltage or sound
It's been my experience that symptoms that point to the power supply, generally are not the case. Schematics now days are tough to find unless you are an authorized servicer for that brand. There are a couple of generic dealers out there but they don't carry everything. Before you replace the power supply I would suggest you go though other boards first looking for bad solder connections and/or transistors and IC's that may be defective. A good DVM with an ohm's scale should suffice. If you still can't find anything, I would suggest taking it to a reputable repair person.
Feb 25, 2010 | JVC Televison & Video
Cannot fix color without remote
Here's a link to order the original JVC remote controller for this model (AV-20220) from a major parts distributor if you need the remote to fix the colors on your unit:
JVC AV-20220 Replacement Part Remote Controller / Remocon Unit
Feb 12, 2009 | JVC AV-20220 TV
Tv will not recognize channels to save, goes to black screen
If you want to get the original remote for this model (AV-30W776), you can find it at this JVC parts ditrubutor:
JVC AV-30W776 Replacement Part Remote Control
Jan 09, 2009 | JVC AV-30W776 30" TV
Nov 25, 2008 | JVC AV-32260 32" TV
JVC AV-27CM3
There is no specific "remote code" as such for a TV. A universal remote control will come with a set of codes for you to try, and the control manufacturer makes up these codes. If none of the listed codes work for a particular brand, the remote normally will have a code-search feature so you can hunt for the one you need. If the trouble is that you have a universal remote and no instruction sheet, you can try to find it online, or just buy a new control. They are inexpensive.
Nov 04, 2008 | JVC AV-20220 TV
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
