Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Welcome to fixya
I have a solution for this
Content
1. check the load weight
2. check all filters some may require that you remove panels in order to access them
3. check or wear caused by overloading in past loads.
Your pre-solution is located above. More information is available
in the comments
My name is Bruce
