Question about Mtd 22" White Outdoor Self Propelled High Wheel Mower
Wheels do not freely roll backwards
I just replaced the nylon springs on the rear wheels and now my rear wheels do not turn freely when I try to pull the mower backwards. Is the transmission supposed to be free when not engaged?
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
HAVE A 4 YR. OLD REAR WHEEL DR. HONDA MOWER THAT THE REAR WHEELS LOCK UP WHEN PULLING IT BACKWARDS OR TURN REAL HARD.
sounds the belt may be too tight if it is the same belt that has been working maybe a weak spring on the transmission
Aug 17, 2017 | Honda Garden
Tip
Fix the self-propelled function (MTD, Yardman, Troy-Built, others)
I just purchased a used Yardman 24A-203C701 which, as the title states, has similar variants among other brands.
If you remove either hubcap from the pneumatic drive wheels, you may see the drive pawls with thin pieces of nylon (like a wire ty-wrap) sticking out either side. This is what passes for the engagement spring for the pawls. The fix is to remove each pawl and modify them as follows: Remove the nylon piece. On the rear side of the pawl, under the short end which engages the axle shaft, there is a place where you can drill a 1/8" pilot hole. Expand the size to 5/32" (the drill will want to catch on the pawl's metal, so drill carefully) and tap for 8-32 threads. Buy four 8-32 Allen head bolts which are 5/8" long and four 8/32 hex nuts. Using Loc-Tite on the threads, install one Allen bolt and hex nut into the front side of each pawl. When the threads are flush with the rear side of the pawl, tighten the hex nuts to jam the fastener in place. Purchase four small extension springs which just fit over the Allen bolts and which have just enough tension to pull the pawls into engagement with the axle shaft. The machine will then pull with both wheels but can still be turned and even pulled backwards.
on Nov 24, 2008 | Troy Bilt Walk Behind...
Why does lawn not want to pull backwards when mowing? Feels very hard and tight when pulling back. Unsure if it has anything to do with belt?
pull both rear wheels off and clean the half moon shaped key you will find on the drive shaft gear that turns the wheels, you will need snap ring pliers to do this properly and clean the small springs under the half moon key you find so they operate freely DO NOT use grease in this area wd 40 or nothing works fine once they are clean, also check for wear on the parts
Jul 26, 2014 | John Deere JA65 Self Propelled Mower
Why do my rear wheels lock up pulling machine backwards?.
your drive will driver dogs are full of dirt you need to remove both wheels and clean the dirt out the dogs are spring loaded be ready for parts to spring out maybe depends on how much dirt
Jul 05, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Drive wheels won't freewheel when pulling mower backwards,
pull off what looks like hub caps and check the wheel clutches
Apr 02, 2012 | Garden
Craftsman mower #247.887760 rear drive. rear wheels lock-up when you try to pull mower backwards
The rear wheels are locked to the drive train. To pull or push the mower, you must pull out the release probably at the back of the mower, near the transmission.
Gary
Jul 10, 2011 | Craftsman Garden
2003 audi tt when front wheels are turned full left or right the car will not roll and there is a binding poping sound from rear of car. it is worse when car is cold. car is fine if you put wheels straight...
jack up the car and see if you have the plastic transit blocks still inside the springs(some are yellow some are blue or green)whatever the colour TAKE THEM OUT.
Sep 02, 2010 | 2003 Audi TT
The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
My Oreck has in the last 2 weeks become very hard to push on carpet , ok on bare floors. Thanks
Look at 3 things:
(1) is there something wrapped around the rear
wheels or axles?
(2) Is there something wrapped around the small, front wheels or axles. (not likely this is the culprit.)
(3) Is your brushroll still turning. (This requires looking underneath while unit is on, have someone else nearby to pull the cord from wall, turn on & off quickly and make sure brush roll spins.
If it is rear wheels, you can pop them out if necessary to clean the debris, they may be hard to press back in. Similar for the small front wheels, don't loose the axles. If brush roll is issue, check belt, insure that brush roll will spin freely and does not have debris wrapped around it.
Aug 12, 2009 | Oreck XL2000 Bagged Upright Vacuum
Wheels lock when self propel not engaged
Hi
a;; you need tp do is loosen the cable slightly to the self drive mechanism
Apr 05, 2009 | Garden
Mtd 22" White Outdoor Self Propelled High Wheel Mower Logo
821 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
