My washing machine dial that sets the cycle just keeps turning & turning
General Electric Profile Washer
  • 538 Answers
SOURCE: washer will not cycle
well..timer is ticking, check?
the knob is not moving, right?
seems that one of two things is happening
the knob is loose(not likely)
the mechanism is trashed between the clicker and the ticker feel up to doing the swap out of that whole mechanism?
Posted on Oct 24, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
  • 51 Answers
SOURCE: Lower washing machine function inoperative in Maytag stackable
This is very odd, and probably isn't going to be any help,,,, but i know that most top loading washers have motors that spin in 2 directions. 1 direction engages the transmission/gearbox which than makes the agitator go back and forth while also turning the water pump in a direction that actually sucks in air, or water. When the motor spins in the other direction the transmission/gearbox engages so that only the drum spins and the water pump now does its job and pumps out any water in the drum before and while its spinning. With this in mind, and the fact that you say the washer only spins,,,, its possible that the motor is only spinning in one direction allowing the washer to drain and spin,,,, but not agitate.
Posted on Mar 13, 2009
  • 70 Answers
SOURCE: Water pours out the bottom of machine during cycle
Don't get rid of that machine. Those can last 30 years easily, and the stuff you get today cannot compare. You got a bad seal going from the basket to the outside tub. If left go, the motor eventually will short out. You will need to remove the adgitator first, by pulling up hard on it. Then grease the spline before you put it back. A 13mm metric socket (12 point) to take out the bolts holding down the basket. That rubber boot you will see in there is about 12" inches across at the bottom, and about 8" at the top, and looks like that funny hat Goober used to wear on Andy Griffith. The bottom band goes to the tub bottom, and the top goes up against the transmission. The clamps are reuseable, and the boot should be less than $30.00.
Posted on Apr 24, 2009
  • 130 Answers
SOURCE: GE Profile washing machine not finishing cycles
the OL error is for over load.that is when you over load the clothes in the washing machine. If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch If your washer has a selector switch on the control panel, make sure the button for your selection is pressed all the way in, or set properly.
Clutch assembly Many GE®/Hotpoint® washers use a clutch and an automatic shift lever. This assembly is quite complicated. If there's a problem with it, you probably should contact a qualified appliance repair technician.
Drive motor Many washing machines have multiple-speed drive motors. Though it's uncommon, the drive motor may work fine on one speed but not on another. If the drive motor has failed on one speed, you need to replace the entire motor.
Posted on May 07, 2009
My ge profile wpdh8800 won't fill with water in any wash cycle. Have done all the troubleshooting suggestions, including cleaning lines and even turning off power to hopefully reboot electronics. Any...
You need to remove top cover to get to inlet valve (part where hoses attach). Be careful while testing parts for 120 volts. The inlet valve usually has 2 electric coils on it, some have 3 coils. While the machine is in fill cycle, check for 120 volts across each set of terminals on each coil (round plastic part with 2 terminals at each end). 1 coil is hot water--one is cold water (in some 3 coil valves 3rd coil is warm). If 120 volt is present depending on if machine is on hot or cold, the electronic boards and controls are good. Problem will be with the inlet valve itself and will need replaced. If no voltage, problem may be with control board or wiring.
Feb 21, 2015 | General Electric Profile WPDH8800JMG 4.2...
Have an older geneal elecrtric top loading washer that won't wash clothes on gentle cycle.
more times than not it would be your setting dial or switch is bad. You can still use it for regular loads but you might start looking for a different washer. It would cost to much to replace.
Sep 03, 2014 | General Electric Washing Machines
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Why does he GE profile top load washer trip my GFI circut half way thru it's scan cycle
Earth leak either due to water in something or a ground fault in the motor is my guess. It may even be a motor windings fault that is building up resistance as it warms up. You need a service engineer with a good test meter,
Nov 18, 2017 | General Electric Profile WPGT9150 Washer
General Electric WBVH5200J Front Load Washer Washing While using speed wash setting, it... Answer Setting the washer on speed wash for 38minute cycle, the machine is working for 50+ minutes. At... (More)...
Your washer may be doing this because you use far too much detergent or non HE detergent. To solve, use 1 eyedropperfull of liquid HE detergent, or one half teaspoon of powdered HE detergent dissolved in extremely hot water. Try running a Basketclean cycle with vinegar to remove the extra suds which can STILL be lurking in your drums and lengthening your rinsing time.
Feb 05, 2010 | General Electric WBVH5200J Front Load...
WHDSR209DWW on/off button will not engage to spin the cycle selector dial
The cycle selector is not engaged onto the timer shaft. Need to remove the on/off knob by removing the plastic "U" clip. Remove the cycle selctor knob and check that the steel spring clip on the selector is fully seated. Re-install the cycle selector onto the timer shaft aligning the selector key with the with tthe notch on the timer shaft. Re-install the on/off knob.
The cycle selector and on/off combination is a poor design. Users press the on/off knob in and turn clockwise to set the wash cycle. If you're not gentle this action wears the teeth on the timer shaft and the user has to press harder and harder to set the wash cycle. This pressing causes the cycle selector to be pushed off the timer shaft and you can no longer operate the machine.
Stop using the on/off knob to set the wash cycle. Press on the cycle selector to set the wash cycle. Use the on/off knob only for starting or stopping the machine. Don't press or pull too hard on the on/off knob or you will wind up pushing the cycle selector off the timer shaft.
Jan 12, 2010 | General Electric WHDSR209DWW Top Load...
My ge hydro wash washer model WHDSR316G1WW will not spin or agitate. It did this same thing a couple of months after I bouht it, the serviceman said the belt was off. I've checked the belt and it seems to...
for model: WHDSR316G1WW General Electric Washing Machine
Unplug the machine at least 30 seconds
Turn the dial to the spin cycle, but do NOT pull it out yet.
Plug the machine back in and then lift and close the lid 11 times within 15 seconds and finally pull the knob to start the washer on spin cycle.
This should clear the error code.
GE service 1-800-626-2000 (option 3)
Apr 23, 2009 | GE Washing Machines
I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
Feb 24, 2009 | General Electric WBVH6240HWW Front Load...
Water won't drain
you have a sock or something stuck in the pump that wont allow it to drain,,,hve it checked and im sure youll find something there
Jan 23, 2009 | General Electric WHDSR316G Top Load Washer
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
