Question about Philips DVDR3320 DVD Recorder/VCR
Timing I want to set my dvdr3320v (philips) to record for a certain period of time.I know that by pressing some buttons on the front panel you can set it for the 10minutes intervals, but unfortunately I lost somwhere the manual. Can You help please
  • 8,596 Answers
Follow the basic recording instructions from p.32 of your user manual, and add this step:
Press RECORD (z) repeatedly to select the
recording time length. Recording starts after the
first press.
DVD: Each subsequent press increases the
recording time by 10 minutes.
Here is a link to the manual:
http://www.p4c.philips.com/files/d/dvdr3320v_37/dvdr3320v_37_dfu_aen.pdf
-Tha Mp3 Doctor
Posted on Feb 15, 2009
If I press the 'Guide' button on the remote I get the following message: "This function cannot be used now"
Go to the recording menu and make certain you have no timer recordings set. If you have clear them and try again.
Jul 22, 2016 | Televison & Video
Philips DVDR7260h
Hello
Disconnect the recorder from power outlet for one minute and reconnect it again. If the recorder still don't operate well, you have to reset it to factory default settings.* Disconnect the recorder from the power outlet. * Press and Hold down the STANDBY/ON button on the front of the recorder whilereconnecting it into the power outlet. * Release the STANDBY/ON button when STARTING appears on the display. * Wait until the recorder's demo starts scrolling; press STANDBY/ON button again to turn ON the recorder. [All information stored in its memory will be erased. The first installation menu will be appeard on the TV screen. OK.
Feb 02, 2012 | Philips Televison & Video
Dvdr3320v will this model record digital tv programs
This device has 2 composite AV, 1 S-Video, 1 Firewire, 1 RF video inputs. The RF input is a way for it to accept a signal from say a VCR's or Video Game's output on Ch 3 or 4.
Your device also can record via internal tuner.. The tuner can tune VHF:2-13, Cable:1-125 and UHF:14-69. Unfortunately, if you only have a UHF / VHF antenna on your house for TV (do not have cable TV, satellite TV, or the like) you're not going to be able to find anything due to the change from analog TV to digital TV. For this, you would need to purchase a digital TV converter box, and put the output of it into the the DVDR3320V.
I hope this helps and good luck. Please rate my reply. Thanks.
May 06, 2011 | Philips Televison & Video
Screen on laptop goes black periodically and then will only work in certain positions for a time.
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button.
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 09, 2010 | Apple MacBook PC Notebook
Front panel buttons on Philips rear projection do random things
Leaky tact switches on control panel. Part number is 242212802742. Takes 6. They will cost you around 6.00 a piece. Lower front panel pulls off. Be careful as there are two cables attached to htis panel. This should take care of your issues.
Pete....Digital TV & Radio in NC
May 16, 2009 | Philips 55PP9401 55" Rear Projection...
DVDR3570h is stuck in standby, cannot turn on
I had this problem, it was solved by reformatting the hard-drive.
NOTE: if you do this, all settings and all that is saved on the harddrive is lost. But seeing that you can't start it anyway, that is acceptable, right? :)
Anyway, here's how you do it, according to Philips support:
  1. Pull out the power cord from the socket.
  2. Press and hold PREV and STOP (i.e. left and down) on the front panel.
  3. Plug the power cord into the socket again.
  4. Wait until the front panel says "FMT KEY" to let go of the buttons. Wait for it to finish formatting, upon which you will get "-- --" on the panel.
Restart the box and you should now end up at a screen asking you to set the language for the box, as if being started for the first time ever.
Also of note: if you want to restore the firmware to factory settings, Philips support told me to pull the cord, press and hold the STANDBY button, and plug it back in again. For the looping problem though, I didn't need that.
Mar 15, 2009 | Philips DVDR3576H DVD Recorder
Philips DVDR3570
Nov 17, 2008 | Philips DVDR3450H DVD Recorder/HDD...
Dear all I have a DVDR3320v vid player & recorder, do I need any special code or tools to play DVDs from America,i have been told before i buy that I cant play them , can you help,many thanks Dennis.
try the following with your remote. After input you should be able to play dvds from anywhere in the world.
In DVD mode, press System Menu
Go down to the "Lock " icon
While lock is highlighed press zero "0" for 7 times ( i.e 0,0,0,0,0,0,0)
There will be pop-up window that asks you confirm. Press "OK"
Sep 11, 2008 | Philips Televison & Video
Hp 2210
The bulb in your HP PSC remains on for a specified period so that the unit
is immediately ready to respond to your request. When the HP PSC has not
been used within that specified period, it turns the bulb off to preserve
power and displays Power Save On in the front-panel display. (You can exit
this mode by pressing any button on the front panel.)
Your unit is automatically set to enter power-save mode after 12 hours.
Follow these steps if you want the HP PSC to enter this mode earlier.
1 Press Setup.
2 Press 5, then press 6.
This selects Maintenance, and then selects Power Save Mode Time.
3 Press until the desired time appears, then press Enter.
http://h10032.www1.hp.com/ctg/Manual/c01176633.pdf
Nov 10, 2007 | HP PSC 2210 All-In-One InkJet Printer
Philips DVDR3320 DVD Recorder/VCR Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
