Question about Panasonic DP-C213 Color Copier
Fax errors I keep getting a failure to send error from my desktop on faxing. The relay XMT password both match on the PC and the device. I am reading the phonebook and can print to the copier with no problems.
The tech from our copier company finally figured out the problem. Panasonic has a link on the CD to download PANAFAX program. Once installed he still had problems and had to re=initialize the entire machine to get it to work.
Posted on Oct 01, 2008
    Sergeant:
  • 284 Answers
Erase fax memory on epson workforce 3620
If you see an error message telling you that the product's fax memory is full, try these solutions:
  • If you set the product to save received faxes in the product's memory or inbox, delete any faxes you have already read.
  • If you set the product to save received faxes on a computer, turn on the selected computer. Once the faxes are saved on the computer, they are deleted from the product's memory.
  • If you set the product to save received faxes on a memory device, connect the selected memory device containing the save fax folder to the product. Once the faxes are saved on the memory device, they are deleted from the product's memory. Note:Make sure the memory device has enough available memory and is not write protected.
  • If the memory is full, try sending a monochrome fax using theDirect Sendfeature or sending your faxes in smaller batches.
  • If the product cannot print a received fax due to a product error, such as a paper jam, the memory full error may appear. Clear any product errors, then ask the sender to resend the fax.
May 24, 2017 | Epson Office Equipment & Supplies
I have an hp officejet pro 8500 fax, scanner, copier and printer. I keep getting an error message 350 when I have repeatedly tried to send a fax. What do I do and what does error 350 mean? Thanks in...
error 350 means a disconnection, from your machine to that of the remote fax machine. Disconnection can either come from a power shortage, defective or not so good telephone lines, a call-waiting mode on the telephone, a defective fax machine or manual interruption.
Sep 12, 2010 | Computers & Internet
Trying to send a fax and it keeps giving me a error 0503
If you are trying to send a fax message using your desktop computer and it shows an error 0503, you just need to turn off both devices your modem and the computer. Now if you have an internal modem so you just need to turn off your computer for atleast 5 minutes to drain the power. Then you can try to refax your message.
Sep 09, 2010 | Computers & Internet
Error codes 283 and 232 in received Faxes
basically error 232 indicates that a communication failure has occurred between the two machines
Following these steps may help resolving your issue
1. Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
2. Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
3. Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
4. Try sending and receiving faxes on a different fax line.
5.Try using a different telephone cord.
6. Have the phone company test your line for static or noise problems.
7. Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
Hope this helps.
thx
Jun 02, 2009 | HP LaserJet M1522nf Multifunction Printer...
Can't send faxes. Dials Ok but no connection to send fax
If you are unable to send the faxes, please try decreasing the modem speed and disabling the "Error Correction Mode." To decrease the modem speed, please follow the steps given below:
1. Press the "Fax" button.
2. Press the "Options" button 15 times till it reads "Advanced Fax" on the display.
3. Press the "Select" button.
4. Then press the "Options" button 10 times till it reads "Max Send Speed."
5. Now press the "Right Arrow" button and choose "9600 bps."
6. Press the "Select" button.
To disable "Error Correction," please follow the steps given below:
1. Please press the "Fax" button.
4. Then press the "Options" button 11 times till it reads "Error Correction."
5. Now press the "Right Arrow" button and choose "NO."
May 19, 2009 | Lexmark X4270 All-in-One Multifunction...
Fax failure error # 551
Check the phone line with a regular phone.
Feb 01, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
In the - IND. XMT JOURNAL - the destination number is wrong
to set the com journal, press function-7-4-set-1-2-set-2-set-stop
to check the phone number you could look in function-7-1-set- keep hitting set till you see the phone number
Dec 09, 2008 | Panasonic Panafax UF-585 Plain Paper Laser...
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Error Code 406
"XMT/RCV password does not match. Last 4 digits of TSI does not match with the last 4 digits of the ONE TOUCH, ABBR Telephone number." This is straight from the Panasonic service manual. I would suggest looking in the User's manual uner "passwords" and try to either reset or clear out the password info.
Dec 17, 2007 | Panasonic Panafax UF-595 Plain Paper Laser...
Error message 714
hi RESET !! first clear all files from the memory cards (if there is) enter "001" and press "set" to delete all files enter "1" (page 143 ) http://service.us.panasonic.com/OPERMANPDF/DX2000AU.PDF take the battry out (page 196) unplug the device for a day and assemble it hope it works good luck
Apr 04, 2006 | Panasonic DX-2000 Plain Paper Laser Fax
Panasonic DP-C213 Color Copier Logo
111 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
