Question about Konica Minolta DiMAGE E201 Digital Camera
Maximum aperture of the lens
What is the maximum aperture of the lens?
    Master:
  • 425 Answers
The maximum aperture of the DiMAGE E201 is f/3.0.
Posted on Sep 19, 2005
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
Aug 19, 2014 | Olympus Om Auto Extension Tube 7 For Om-1...
Zoom and aperture problem
What lens do you have on the camera? Many zoom lenses have a variable maximum aperture. This means that the maximum aperture varies depending on the focal length. If you set the lens to its maximum aperture and then zoom, the aperture may change.
Feb 11, 2013 | Nikon D3100 Digital Camera
Why the "f" number in manual mode, doesn't go to under the 5.6 ?
f/5.6 is the maximum aperture for the 18-55mm lens zoomed in to 55mm. If you zoom out to 18mm you'll be able to open the aperture to f/3.5.
The maximum aperture is a matter of physics. The larger the aperture (smaller f/numbers) the larger the lens has to be. In theory you could make a 55mm lens with a maximum aperture of f/0.5, but it would have to be more than four inches across on the inside. Lens designers have to balance cost and size with performance.
If you really need a faster lens you can get something like this, but it'll cost you a bundle, about six times as much as your 18-55mm.
Jun 18, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
I have Rebel camera. The lowest f-stop I've been able to set it at, whether on AV or Manual, is 5.6. Do I need to adjust the ISO speed to be able to get larger aperture?
The maximum aperture is determined by the lens. At 55mm, the 18-55mm lens will not open up beyond f/5.6. This has nothing to do with the ISO or the camera's exposure mode. If you zoom out to 18mm, you can open up to f/3.5.
The varying of the aperture with the focal length is part of the design. While it is possible to build a lens with the same maximum aperture throughout its entire zoom range, that would result in a larger and more expensive lens. For example, Canon has a 17-40mm f/4 lens. That lens weight two-and-a-half times as much and costs more than four times as much as the 18-55mm.
Mar 23, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Lens will not change aperture setting.. it's stuck on F4. Should be able to change to F2.8 Michael
You'll notice that the maximum aperture is specified as f/2.8-4.0. The lens has a maximum aperture of f/2.8 only at the 17mm focal length. At the 35mm focal length, the maximum aperture is f/4.
Does the lens open up to f/2.8 when you zoom out to 17mm?
Feb 17, 2011 | Sigma 17-35mm f/2.8-4.0 EX Aspherical HSM...
On my d90, under M (manual mode or aperture priority), the aperture on the readout goes beyond the actual aperture range; i.e. f3.5 - 5.6; readings will show aperture range of 5 - 29 when I scroll with the...
There is NOT a problem. The f3.5-5.6 indicates the maximum aperture in the zoom range. At 18mm the maximum aperture is f3.5, at 105mm it's f5.6. The minimum aperture ranges from f22 to f38.
So, at 18mm, the aperture can range from f3.5 to f22. At 105mm, the aperture can range from f5.6 to f38. At intermediate focal lengths the aperture range is somewhere between the two extremes.
Nov 16, 2010 | Nikon D90 Digital Camera with 18-105mm...
Why won't my aperture go lower than 5.6?
You do have total control, within the constraints of the hardware. The 18-55mm lens has a maximum aperture range of f/3.5 to f/5.6. This means that at 55mm the maximum aperture is f/5.6. You can go the other way, all the way to f/38. At shorter focal lengths you can open up as far as f/3.5.
If you want a larger aperture, you'll have to get a faster lens. For example, Nikon has a 17-55mm f/2.8 lens which has a maximum aperture of f/2.8 at all focal lengths. It also costs $1300 new.
Feb 19, 2010 | Nikon D3000 Digital Camera
Cant use f/3.5
You will only be able to use the f3.5 aperture setting when the lens is zoomed out to the 18mm setting. As you zoom in, the maximum aperture available will decrease until you reach the 55mm setting where the maximum aperture will be f5.6.
Check to see if you can obtain f3.5 with the lens zoomed fully out. If not, it sounds as if the aperture blades could be sticking, in which case it will need to be professionally repaired.
Hope this helps!
Jun 12, 2009 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
Aperture not going below 6
There is no problem. The lens is f/3.5-6.3. That means that at 200mm the maximum aperture is f/6.3. At long focal lengths you will not be able to open up beyond f/6 or so. At the short end, at 18mm the maximum aperture is f/3.5.
Aug 16, 2008 | Tamron 18-200mm f/3.5-6.3 for Nikon
Konica Minolta DiMAGE E201 Digital Camera Logo
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Damen Wong
Damen Wong
 Larry
Larry
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
