Question about Gateway GT4022 PC Desktop
2 ATX POWER SUPPLY PLUGS
Why is there 2x 4 pin ATX power plugs. One that piggybacks on the main plug and one like the Pentium fan plug. They both say 12v ATX. The reason i ask is that when i first went out. the one that was on the main plug was not connected.
  • 42 Answers
Some motherboard/cpu setups require an additional 4-pin connector for additional power on the motherboard. The motherboard will require either a 20-pin or a 24-pin power connector (main power), and might need the additional 4 pin as well. If the motherboard will accept the additional 4-pin, then connect it!
Posted on Jan 15, 2009
The power supply light is flashing and my computer won't start up. No fan, nothing. I disconnected the power to the mother board and the light burned solid when plugged in. I have switched the watts...
Bad Power Supply.
Weak voltage power rail, or rails.
{There are three voltage power rails.
1) The 3.3 Volt power rail
2) The 5 Volt power rail
3) The 12 Volt power rail}
The flashing Green LED light is one direct indication of this for HP computers.
Usually there is at least enough power to light LED lights, and spin fans, but your Power Supply doesn't even have that much power.
1) All of the LED lights on at once use less than 1 Watt of power
2) EACH fan uses 2 to 3 Watts of power
3) A typical Processor can use 51 to 125 Watts of power.
Depends on what Processor it is.
The HP Pavilion A847C desktop computer has an ATX power supply, with a maximum rated wattage of 250 Watts.
The ATX form factor for a Power Supply refers to it's case size, for one.
5-1/2 inches Long, 3-1/2 inches Tall, and 6 inches Wide
The common type of Power Supply used in over 80 percent of PC computers out there, and readily available all over.
HP Support > Pavilion a847c desktop computer > Main support page,
http://h10025.www1.hp.com/ewfrf/wc/product?product=448706&lc=en&cc=us&dlc=en&submit.y=7&submit.x=5&lang=en&cc=us
Click on Product information in the list
Now click on Product specifications
Finally click on > Motherboard Specifications, PTGD1-LA (Goldfish )
Scroll the page down to view the motherboard illustration and photo.
The replacement Power Supply has to have,
A) A 24-pin ATX main power cable.
In the motherboard photo, view the Ram Memory slots. The long Blue, and Black slots.
To the right of the bottom corner of the Black ram slot (Slot 4) is a whitish connector.
Two columns of 12 socket holes.
This is where the 24-pin ATX main power cable plugs into.
(ATX Power Connector in the motherboard illustration)
Typical 24-pin ATX main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
NOTE the Lock Clip on the side of the connector.
B) 4-pin ATX +12 Volt power cable.
At the bottom Left corner of the Processor socket is a whitish square connector.
4 socket holes.
This is where the 4-pin ATX +12 Volt power cable plugs into.
(ATX12V in the motherboard illustration)
Typical 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
{The top of the Lock Clip is squeezed in to release it, and is held while the power cable is removed.
Same for the 24-pin ATX main power cable's connector}
C) SATA power cable.
Used for the SATA harddrive
The SATA power cable has 15 pins, and is the longer connector.
The SATA data cable has 7 pins, and is the shorter connector.
IF, the SATA harddrive has provisions for plugging in a SATA power cable, AND a 4-pin standard Peripheral power cable, ONLY USE the SATA power cable.
Otherwise you will burn up the SATA harddrive.
The SATA power cable plugs into the SATA harddrive.
One end of the SATA data cable plugs into the motherboard, and the other end plugs into the SATA harddrive.
Below the ram slots in the bottom Right corner are the SATA headers on the motherboard, that the SATA harddrive plugs into.
The Blue, Orange, Black and White connectors.
Of course the SATA harddrive only plugs into one of them.
Looking at the motherboard illustration you will see they are numbered.
SATA 1, SATA 2, SATA 3, and SATA 4.
IT DOESN'T MATTER which one you plug your harddrive into. (Or any SATA device)
That's the beauty of SATA.
BIOS will find the harddrive.
But for you, it will be easier to keep track of where the SATA harddrive is plugged in, if you just use SATA 1.
Typical SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
D) 4-pin standard Peripheral power cable.
Commonly referred to as Molex. (Misnomer)
Used for optical drives, Fans, and other associated hardware.
Typical 4-pin standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
E) 4-pin Small Peripheral power cable.
Used to be commonly used for a Floppy Drive.
For your computer it provides power to the Memory Card Reader.
Typical 4-pin Small Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
Watch disconnecting, and connecting this connector. You can bend the pins very easily.
SAFETY
WATCH your fingers as the pins are QUITE SHARP!
All of the power cables listed above are standard for today's Power Supply's.
About the Wattage.
A computer ONLY uses the power it needs, and NO more.
If you put a 10,000 Watt power supply in, and the computer only needed 100 watts for what it is doing, it will ONLY use 100 watts.
To wit, if you install a Power Supply with more Wattage than 250 Watts, it will NOT hurt your computer.
If you need guidance in replacing your Power Supply, or recommendations for a Power Supply, please state in a Comment.
Regards,
joecoolvette
(Apologize for being so lengthy)
Nov 24, 2010 | HP PAVILION A847C Intel Pentium 540 HT...
I've got a new Gigabyte Ga-M68Mt-D3 mobo paired with a cooler master 460 watt power supple. Cpu is Amd phenom II 3.2 ghz with 4 gig of DDR3 ram. I powered up the supply attached to my ATX power supply...
Most motherboards now have a 24-pin power supply connector. If you haven't already found a diagram showing the pinouts of the 20- and 24-pin power plugs, here's one borrowed from a handy site:
The two plugs are essentially the same, but the 24-pin version duplicates some voltages on the extra pins. The extra pins in the larger connector were meant to provide extra current paths for voltages that see heavy loads from newer processors and motherboard circuitry. Depending on how a motherboard is designed, it might work with a 20-pin plug connected (leaving pins 11, 12, 23 and 24 empty). But typically if the board has a 24-pin connector it needs the 24-pin power supply plug.
Most power supplies have a 20-pin plug with a separate 4-pin section that fastens to it for connection to a 24-pin mobo connector. It typically has one side designed to slide onto the end of the 20-pin plug, essentially turning it into the 24-pin version. This added plug does not have a retaining clamp on its side, so you can tell it from the the 4-pin CPU power plug. The wire colors are also different. For reference, here is the processor power plug, from the same website:
New motherboard specs call for the separate processor power connector for the same reason the extra pins were added to the power supply connector: to handle the high currents needed by increasingly faster CPUs.
When the motherboard has these connectors, you need to use them all to get everything working. Hope this helps. Thanks to smspowersupply.com for the diagrams, and thank you for using Fixya.
Nov 19, 2010 | Computers & Internet
Un pluged power sulp. cant remember whear they go
Would help if I had the computer manufacturer's name, and the Model number.
Generic Info:
A) Main power cable:
You may have an old computer which has an AT power supply.
This type of power supply has 2 main power cables.
Example:
http://www.playtool.com/pages/psuconnectors/connectors.html#oldpc
NOTE the lock tabs on the side of the connectors. The connectors only go one way.
NOTE the Black wires in both connectors.
When both connectors are plugged in properly, the Black wires in both connectors face each other.
Look at the photo to the far right.
(The Black wires are Ground wires)
B) Newer computers past the time period of the above, use an ATX power supply. They use an ATX main power cable.
First there was a 20-pin ATX main power cable.
As time proceeded, and more power was needed to the motherboard, the 24-pin ATX main power cable came out.
20-pin ATX main power cable, and it's respective connector,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
NOTE the lock tab on the side of the connector. It operates in the same fashion as a see-saw on a playground.
The top of the lock tab is pressed in. The hook on the bottom of the lock tab, catches on a protrusion coming out of the side of the connector, on the motherboard.
When plugging in the Lock Tab faces the 'bump', or protrusion on the connector on the motherboard.
Scroll down the page for info on the 24-pin ATX main power cable, and it's respective connector.
With either style of connector, ensure that the ATX main power cable's connector, is pushed down in the connector on the motherboard. Ensure that the Lock Tab is locked into position.
3) 4-pin ATX +12 Volt power cable.
Also referred to as P4 MB, (Pentium 4 MotherBoard), and P4 12V
(Pentium 4 12 Volt)
This power cable is power for the Processor.
The respective connector on the motherboard, is a square whitish plastic connector with four socket holes.
As shown on the photo to the far Left.
Different manufacturers place the female connector in different places, but it is always located somewhere near the Processor.
4) Standard 4-pin Peripheral power cable:
Also misnomered as a Molex connector.
[Name of first design stuck. Same as calling an adjustable open-end wrench a Crescent wrench]
This power cable is used for IDE, (PATA) harddrives, optical drives, (CD/DVD drive/s), and sometimes for computer case fans.
Note the rounded corners on one side of the connector.
Only allows installing in one direction.
(Unless you 'gorilla' it)
5) SATA power cable:
Used for SATA harddrives, and optical drives that are SATA.
Only plugs in one direction.
NOTE*
Sometimes a SATA harddrive, will have a provision for a standard 4-pin Peripheral power cable, AND a SATA power cable.
ONLY plug in the 15-pin SATA power cable!
I cannot stress this enough.
Plugging in both power cables will BURN up the SATA harddrive.
May not happen right away, but I assure you it WILL happen.
5) Floppy drive power cable:
This is another style of 4-pin Peripheral power cable. A smaller version.
Your computer may not have a Floppy Drive, and hence may not use this power cable.
If you have a Card Reader though, it uses this style of power cable.
Only plugs in, in one direction.
{NOTE*
Watch the sharp pointed pins coming out of a Floppy Drive, or Card Reader, that this power cable plugs onto!
Will stick your finger as easily as a straight pin! ]
For power cables going to a graphics card, (Video card, same same), let me know what graphics card it is.
To reply, or post questions, post in a Comment.
Regards,
joecoolvette
Sep 27, 2010 | HP Computers & Internet
My evolution 3000 been occasionally powering down for no apparent reason for a couple of weeks. now completely died. no power at all. won't switch on or show any life.
Power Supply's have a Form Factor. (Actually only motherboards do, but most Power Supply's follow the motherboard Form Factor)
The ATX designation determines it's size, shape, and factors concerning the various power cables coming out of it, (Spaghetti), plus other concerns.
An ATX power supply shape is generally close to 6 inches long, (15.24 Centimeters), 6 inches wide, and 3-1/2 inches tall.
(8.89 Centimeters)
It is the common size and shape used for 90 percent of the personal computers made, out there.
From what I have been reading about Evesham, they used typical power supply cables used for most ATX power supply's.
Basic specifications on the Evesham Evolution 3000 desktop computer,
http://www1.epinions.com/specs/pr-Evesham_Evolution_3000_evop3ghblulightmar04_PC_Desktop
Power Cables:
1) Don't know if the Power Supply will have a 20-pin ATX main power cable, or a 24-pin ATX main power cable.
In reality the point is moot, because new power supply's have a main power cable which will be a 20-pin connector, or a become a 24-pin connector.
To expound,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
(If you scroll up the page, you can see a 24-pin ATX main power cable, and it's respective connector.
Scrolling further up produces a 20-pin ATX main power cable, and it's respective connector.
Color of the connector does not matter)
2) The Evesham Evolution 3000 specifications, state that an Intel Pentium 4 processor is used.
This means there will be a 4-pin ATX +12 Volt power cable, which plugs into the motherboard.
Example,
(Again, color of the connector does not matter)
3) There will be a few 4-pin Peripheral power cables,
One connects to the Harddrive, one connects to the Optical drive, (Or optical drives. Spec's state just one CD/DVD drive is used)
4) There is a Floppy Disk drive power cable,
(Again, I'm going off of the specifications stated. Your Evesham may not have a Floppy drive)
To be continued in a Comment.
Jun 15, 2010 | Evesham Evolution Blue Beast...
Need to know what parts compatable to ATX-1523D for an emachines T-1090
It's a Small Form Factor power supply.
4.9 inches Wide, 2.5 inches Tall, and 3.9 inches Long.
Put's out a maximum of 150 watts, (Supposedly)
Has the following power cables;
A) (1) 20-pin ATX main power cable:
The main power cable. Main power cable designs have moved up to the 24-pin design, with some main power cable connectors having a 20-pin connector, and a separate 4-pin connector
B) (1) 4-pin ATX +12 Volt power cable:
This power cable is power for Intel Pentium 4 processors,and on up.
I have a eMachines T-1090 in my shop. (Still works great) It has a Pentium III 933MHz processor. Didn't know Pentium 4's were offered.
C) (4) 4-pin Peripheral power cables.
(The connector on the end of the power cable, is referred to as a standard 4-pin Molex connector. This is a misnomer. Molex was/is, a company that made this style of connector first. The name Molex was on the connector. The name stuck with people. It's just like referring to an open end adjustable wrench, as a Crescent Wrench)
D) (1) Floppy Drive power cable
Except for the size, and shape of this power supply, just about any low-end ATX power supply with a 4-pin +12 Volt power cable, would work.
More in additional comment.
Mar 28, 2010 | E-Machines T1090 PC Desktop
I purchased a zion 2 case and I cant figure out the fan plugs because the plugs are like the ones use for cd burners to power themup
To connect the power cable, just take the 4-pin connector coming from the fan and connect it to any 4 pin connector coming from the power supply. you can then use the 4-pin connector to power a cd/ dvd drive or ATA hard drive
~gnomer
Jan 31, 2009 | XION II Mercury (XON102) ATX Mid-Tower...
Where to plug case side fan
Pinout Pin number Wire color Description 1 yellow +12 volts 2 black ground 3 black ground 4 red +5 volts
Jan 27, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
Replacing power supply on a gateway desktop 600xl
to replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Feb 28, 2008 | Computers & Internet
Gateway GT4022 PC Desktop Logo
70 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
