Question about Refrigerators
Dometic 2008 fleetwood discovery...............Freezer side works ref. side does not. Will only run on propane not shore power
  • 51 Answers
Make sure the cooling fan on the back is working properly it should be running if the unit is on. While your there check to make sure the plug is still plugged in for the ac to work. Also check the breaker in the box reset if necesary. All this good on the ac the heating element would be my next choice.
Posted on Sep 08, 2008
Rm3804
Verify is you have 100vac at the outlet behind the refrigerator. If you do not then you need to restore power to the outlet. The refrigerator will stay in LP mode until it detects good shore power.
Jul 01, 2014 | Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Mar 28, 2014 | Dometic RM2652 Refrigerator
Dometic s 1621 works on shore power but won't work on lp gas
What exactly happens when switched to propane? Have someone switch to propane while you stand by vent cover outside and listen for sparking when switched. Make sure it's calling for cool, as in maybe leave door open for a few minutes prior to trying. Let me know if you hear any "ticking" sound as if trying to light on propane.
Oct 29, 2011 | Dometic RM2652 Refrigerator
I HAVE A 1997 FLEETWOOD RV WITH ORIGINAL DOMETIC RM2852 REF IN IT. ALL POWER SEAMS TO WORK (LIGHTS ARE ON PLUGED IN OR OFF OF GAS BUT THE WHOLE PROBLEM IS THE REF OR FREEZER WILL NOT GET COLD
Largest problem is with the cooling unit going bad on these unit at about your units age.
But first
check your 12 volt fuses and make sure both the fuses in the back of the refer and the fuse in the power distribution panel are good
Must have 12 volt for the gas to work
Sep 23, 2009 | Dometic RM2852 Refrigerator
I have a dometic rv fridge. it works on the 120 v but not on propane. acutually the freezer works and the fridge is warm, when the propane is running the fridge
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jun 04, 2009 | Dometic NDR 1292 Refrigerator
Dometic RM2652 will not run on electricity only Propane
sorry but have absolutley no experience with propane run refrigeration, in America never seen such a thing, please repost with another expert,
Dec 18, 2008 | Dometic NDR 1292 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Rm 2611 will not run on gas when going down the road
Your voltage supply is being interrupted. The DC voltage needs to be at least 10.5 to work properly. If you are switching from shore to gen this can cause the interuption also. I presume the gas supply is staying on when you are traveling.
Jul 28, 2008 | Dometic RM2652 Refrigerator
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
