Question about Hotpoint Aquarius WF000 Front Load Washer
HOTPOINT WF00 HAVE REPLACED DRUM BEARINGS, MACHINE RUNS,BUT WILL NOT COMPLETE WASH CYCLE ( FILLS, WASHES BUT WILL NOT MOVE ONTO SPIN ) TRYING TO GET WIREING DIAGRAM TO CHECK I HAVE RECONNECTED THINGS IN RIGHT PLACE !
    Novelist:
  • 166 Answers
Deasr dashdach
Peace,
From ngafm,
I understand that you have,
HAVE REPLACED DRUM BEARINGS, MACHINE RUNS,BUT WILL NOT COMPLETE WASH CYCLE ( FILLS, WASHES BUT WILL NOT MOVE ONTO SPIN ) TRYING TO GET WIRING DIAGRAM TO CHECK I HAVE RECONNECTED THINGS IN RIGHT PLACE !
How old is this washer that you are spending so much money in parts for?How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Sounds like you really need a Hotpoint trained tech , so as not to spend weeks repairing, or not your washer.
My father and grandfather used to teach me , ("When in dought, don't)
If I were there I could show you the wiring order without the diagram!!!!!!!!!!
In the USA thousands of deaths and house fires happen when corners are cut, and cost home owners much more than the few bucks they plan on saving!
Do it right, like the rest of the things you did in you life to get this far!
Call a factory service and let them help you.
Stay healthy!
You will be fine.
Bless You,
ngafm1
Please give me a good rating for this fine advice i give you, before you sign off.
Thank You
Posted on Sep 10, 2008
How do I fix washing machine to finish emptying during rinse and spin cycle?
Long shot, but does it fill the same as when new? I would check the atmospheric switch which is a hollow tube that runs down the inside of the drum(not in the wash cage) when the water fills, It pushes air up to stop the fill. It may have gotten clogged. Or partially clogged.
Mar 28, 2016 | Fisher and Paykel Washing Machines
Cotton program stuck on wash cycle with 1 minute left
Control board needs to be replaced. Many times the control boards go bad because of a spike in the electrical grid cause by a brown out, lightening strike or even a surge in the power. After the control board is replaced... I suggest using a surge protector on all of your electronic devices including the washing machine.
Feb 06, 2014 | Hotpoint Ultima WF865 Front Load Washer
My GE SpaceSaver Washer/dryer will wash, but when it's time to rinse and spin the machine stops. It will not drain, riinse , or spin.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Jul 27, 2012 | GE Spacemaker Washer and Dryer Electric...
I have a problem with my hotpoint wf340 1400 spin when i put it on it washes but wont come off the wash cycle and will continue washing unless i stop it manually i then have to select pump out and then a...
it is either a broken wire to your heating element or the element itself is open circuit. when the water does not heat the machine will not move onto next stage of wash.
Feb 20, 2011 | Hotpoint Washing Machines
Machine will not final spin
I was given wrong info. the machine did go through the cycle and drain. However, the drum DID NOT revolve at all. Main motor Brushes replaced. Now OK. Thanks.
Feb 15, 2010 | Hotpoint Washing Machines
Hotpoint wma22 fills with water but won't wash or spin
Suspect motor brushes need replacing.
Simple task accessed by removing the top of the washer and releasing the clips holding the brushes into the motor - clip on back of brush - to remove the brush assembly.
Replace complete brush assembly.
Feb 16, 2009 | Hotpoint First Edition WMA22 Front Load...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Hotpoint Ultima WMA61 loud knocking noise in spin cycle
Hello I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. Also another way to check is to move the inner durm up and down to see if there is any play in it..
If you need any further advice then dont hesistate to ask....
Jan 14, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
145 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
