Question about Kenmore 13742 / 13744 / 13749 Built-in Dishwasher
Kenmore dishwasher how do I retrieve a screw I dropped in the bottom?
While installing this dishwasher, a Kenmore 13742 model, I dropped a screw into the bottom. It disappeared below a round part with holes in it.
How do I get the part detached from the bottom so I can access the screw?
Try turning off the power at the breaker box, turning off the water, and unhooking any connections. Next, remove the dishwasher from the counter, and turning it upside down. You'll want to shake it gently at an angle so the screw can drop free. This is a relatively hassle free fix if you can get it to work. If this doesn't work,you may have to remove the pump motor assembly and then the motor to access the area where the screw is lodged. The later solution will require you to pack a lunch. You'll be there a while. Be sure you know what you're doing before you begin disassembling. It's a big job.
Posted on Dec 05, 2009
Control panel buttons no longer work.
Hello ...
I tried to look up your model numbers here (usa)...
with no success... (Kenmore 13742 / 13744 / 13749)
I rarely (ever) suggest owners go direct to Sears...
but this would seem to be.. appropriate...
(I my opinion they are rude & pushy to sell parts
(good news ... here... their guaranteed fit/fix)).
Before doing so...
Check your water, drain & power at the appliance.
With the breaker turned of...
open the appliance cord JUNCTION BOX and assure the
wiring devices (usually "wire nuts") are still tight and secure.
Finding nothing... you are at the UNHAPPY JUNCTURE
where you need to use SEARS PARTS DIRECT...
http://searspartsdirect.com/dishwasher
Aug 01, 2017 | Kenmore 13742 / 13744 / 13749 Built-in...
On my Kenmore Dishwasher Model 66513749K601, the door is leaking water. I'm wondering if changing the gasket will repair it or if this machine has a history of other issues.
Hi, Just change the door seal... it is very easy to do...and don't cost much at all...
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
Aug 14, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Hi we have a Kenmore Dishwasher Model # 13744K and it won't turn on. It has water in the bottom that won't drain. Please advise. Thanks. John Webster.
For a dishwasher that was rated pretty high by Consumer Reports, it does not clean very well. In addition, the plastic control button cracked in less than a year and I must constantly clean around the inside of the door ... and I never received my rebate.
Despite those issues, it has been a workhorse. My wife is a daycare provider and the machine is used twice a day (on average) and still runs well. On a monthly basis, I alternate a pint of lemon juice and a pint of vinegar to keep it clean and once per year I use a granulated dishwasher cleaner.
Dishwasher has not power, check breaker and it is ok. Tub still has water in the bottom. Dishwasher was running and just shut off.
Hi
First make sure that nothing is blocking the drain pump assembly located inside the lower front panel of the dishwasher. If the issue returns after its cleaned then it means that the control board has gone bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 04, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Dishwasher soap is not dissolving.
Try emptying the dishwasher and putting a few tablespoons of vegatable oil in the bottom. Run the cycle without soap and no dishs. Often dish soap (palmolive) builds up and creates soap suds that won't go away during a normal cycle. The oil binds with the soap residue to get rid of it. It worked for my Kenmore. I know do it every few months. Good Luck!!!
Thanks
Jun 22, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Upper tray of Kenmore 13742 is not cleaning. Followed the Versastyle fix for rmussak on Mar 6,2009 to determine if chopper or motor needed replacing. Everything seems fine. What next?
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Mar 11, 2011 | Kenmore 13742 / 13744 / 13749 Built-in...
Soap suds comes out of the door at the bottom when I try to wash
too much soap. if you have a water softener you only need about a tablespoon of soap. if there is a buildup in the dishwasher it make take several loads before it goes away. also check the wash arm to make sure all the holes are open.
May 22, 2010 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore dishwasher 13749 needs a new electronic control panel
order sears on line / model & ser needed also instruction manual can be ordered .. not a hard job ..1/2 to 3/4 hr .. one wire or plug at a time new board is the same . hope this helps mm ..
Dec 07, 2009 | Kenmore 13742 / 13744 / 13749 Built-in...
Kenmore 13742 / 13744 / 13749 Built-in Dishwasher Logo
422 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
