Question about HP PSC 2175 All-In-One InkJet Printer
Remove and check cartridge keeps flashing, wont stop flashing, even after in remove cartriges and replace them
  • sirgonn Sep 11, 2008
    I am having the same problem. I just refilled my black-ink cartridge (after this started) too, and I don't want to have wasted my money.
  • rcoulter1019 Sep 11, 2008
    I have this same thing, along w/the lights for Copy, Scan Photo Card blinking. It started about 2 nights ago, and I don't know what else to do. I couldn't even turn the thing off-had to unplug it to see if that would help.
I've found out what was wrong. My cartridges expired. HP has put a "limit" on how long your cartridges last. They do this to try to prevent refilling. Cartridges typically last for a little less than two years after the expiry date listed on them.
You can fix this (as I did) by buying a couple of new cartridges # 56 and #57. They sell them together in the same pack for 50-something bucks in Walmart.
Hope this helps.
Posted on Sep 14, 2008
My printer exhibits the same problems as the above two posts. Furthermore, the diagnostic check down load from HP indicates all systems "OK". I have removed the cartridges, checked them for I know not what, and returned them to their proper place. Light still flashes.
Posted on Sep 13, 2008
Lexmark pro 705 wont recognize cyan ink
Make sure that you're using genuine Lexmark cartridges. If you are, try updating the firmware of your printer. Just go to http://bit.ly/ghfW8H to download the firmware update.
Reseat the printead again and the cartridges then reboot the printer. If it doesn't help, try replacing the cartridge.
Apr 25, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Mp 730 "Wrong Cartridge" have been using same cartridge w/o any problems
the cartrige has become faulty or the wire strip that connects to the cartrige holder is comming out or a wire in the strip is broke , a new cartrige would then do the same thing
Oct 18, 2008 | Canon MultiPASS MP730 All-In-One InkJet...
Installed new cartridges will not print keeps telling me to insert paper which I have and keeps saying to remove tape on cartridges which I have will not align
Try removing the power cord and USB cable from the Back of the printer for a couple of Minutes then plug back in and see if that will help. while unpluged remove cartriges and Paper after plugging in replace cartriges and Paper.
Jun 10, 2011 | Lexmark Office Equipment & Supplies
Replaced new ink keeps saying right cartrige is incorrect wont let me print. the cartrige is correct i paid $50.00 for a two pack of black and color ink!!!
Wiping the nozzles with a moistened soft cloth or removing and reinserting the cartridges usually helps. The cartridges for the Lexmark X7170 are black: 32/34 and color: 33/35. If these are the cartridges that you purchased and even tried your old and new cartridges yet the problem persists, please don't hesitate to contact Lexmark technical support.
Mar 23, 2011 | Lexmark X7170 All-In-One InkJet Printer
Ink cartrige problem i replaced both cartriges keeps saying right cartrige is incorrect wont let me print
Mar 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Wont print lights flashing even after new hp ink installed - what now?
I had this psc and usually the ink was leaking or the cartrige head needed cleaning, or the cartridge was not installed properly. Just check these 3 things and you will find the problem.
Apr 07, 2010 | HP PSC 1315 All-In-One InkJet Printer
I replaced my ink cartrige , it keeps telling me
Make the the cartridge is seated properly and the contacts are not dirty or soiled form touching them.You can remove the cartridge and clean the contacts with isopropyl alcohol gently and ley dry.
Feb 16, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Black Cartridge
Hi - If you are saying that the right side cartridge is the black cartrige that you have replaced, then I have two suggestions that may help. If the cartrige is a new HP genuine product I would take it back. If not, I would return the cartrige you have and buy a genuine HP for the printer. Though an expensive solution, there is always a chance of defects from either party. The remanufactured or refilled cartrige will have a date on it. The circuit board on these can wear out and then not be recognizable over time. Second suggestion if you have not already done this, a cotton swab or Q tip dipped in distilled water(damp only) to wipe down the circut board on the printer where the cartrige will connect to it, may help. Turn off the printer to do this. Make sure it is dry when you turn it on and reinstall the new cartrige. Hope this helps.
Jul 07, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Printing with only the Black ink cartrige.
Yes. The printer won't operate without both cartridges installed, even if one is empty.
Mar 15, 2009 | HP DeskJet 842c InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
321 people viewed this question
Seeker5211
Seeker5211
