Question about Acer Aspire 5100 Notebook
PXE-E61: Media test failure, check cable
Last night while working on my Acer Aspire 5100 Laptop the screen went blue with white squigglies. Upon restarting, i recieved the above message. My research tells me that my hard drive crashed. Can I replace the hard drive? If so, what are the specs for a new compatible hard drive?
Thanks!
  • stevenaw Sep 04, 2008
    Thanks for the fast and helpful response!!
And where is the solution???
Posted on Sep 11, 2008
    Sergeant:
  • 359 Answers
Yes PXE indicates it is trying to boot off of a network LAN and does not see a harddrive.
Yes you can replace the HDD.
Your research is correct, your HDD is most likely dead in the water.
for the Aspire 3500 series, assuming same design for most older acer's.
Step 1: remove power cord, and battery
Step 2: flip computer upside down
Step 3: find the hard drive bay, there might be a cylinder like icon near it, and it will be close to the front of the system.
Step 4: remove the screws, likely 2 screws.
Step 5: on removing the plastic lid you will see a metallic box, with a plastic strip on top of it.
Step 6: on the side that has extra space there will be 1 or 2 screws, undo these
Step 7: pull the plastic strip toward the side of the computer that has space open and the whole caddy should pop out.
Step 8: take the 4 screws out of the side of the caddy and the hard drive will just slid out.
Step 9: just put new one in the same way the old one was. and reverse the steps and put your recovery disk in to install your OS.
Pull the old one out to make sure, but it is probably a 2.5" SATA HDD, and any capacity will do according to your budget.
My instructions may not be exact, but use common sense, you can do it!!
Posted on Sep 04, 2008
Went to shut down comp. and screen said, and still is. broadcom undi pxe-2.1 v11.4.1 copyright [c] 2000-2008 broadcom corporation copyright [c] 1997-2000 intel corporation all rights reserved. ...
A "media test failure, check cable" means your hard disk failed. The bios can not locate the boot sector of the hard disk to begin loading the operating system.
"Operating system not found" means windows can't load because the Bios can not find the operating system (because the hard disk failed).
This is pretty much an unrecoverable error in terms of fast fixes. You can take the hard disk to a data recovery service if you need to retrieve important data or files.
Dec 05, 2010 | Acer Aspire 5610-2328 Notebook
Tip
PXE-E61: Media Test Failure
Issue:
My computer gets this message when I try to boot it:
PXE-M0F: Exiting Intel PXE ROM.
Solution:
Your computer is set to boot from the network (PXE = Netboot).
Go to your BIOS and make sure you boot from your hard drive.
Remarks:
Shouldn't be enabled by default
[more...]
on Jan 04, 2009 | Acer Aspire 3680 Laptop
I get an error message on startup on my Acer Aspire 5100, it says Realtek RTL8139(x)/8130/810x PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE...
It is beacuse your Hard drive is not detected on the computer properly.
Try resetting BIOS.
If that doesnt work, Check whether your hard drive is good.
Nov 28, 2010 | Acer Aspire 5100 Notebook
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
PXE-E61 media test failure on Acer Aspire 5050 laptop
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
Feb 08, 2010 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
PXE-E61: Media test failure, check cable Pxe-M0f: Exiting Broadco
PXE-E61: Media test failure, check cable (of the HARD DISK pls)
pls first check the hard disk seated in the bottom left side of ur notebook u have to take out the 7 or 8 screws first and then take take it out by pulling the connector gently and try to re seat or re fit the hard disk so connector can seat firmly in hard disk and then power up ur notebook if Error persists
then sorry to tell u my friend that ur Hard disk has CRASHED and not giving up files for OS loading kindly replace ur HARD DRIVE and restore ur OS thru backup disk u got
Pls take care of ur notebook from bumps and falls and hard impacts during operation and carrying bcoz the disk inside the HDD is very sensitive and gets damaged easily by impacts
pls rate me FIXYA for my diagnosis
Mar 09, 2009 | Acer Aspire 4720 Notebook
your e-machine is set to boot from the network (PXE = Netboot)
go to your BIOS and make sure you boot from your hard drive
Aug 31, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5100 Notebook Logo
273 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
