Question about Ovens
Magic Chef Oven
I have a Magic Chef oven that starts beeping and then a code of F1 is displayed. What is the problem and how much does the part cost.
  • 116 Answers
An F1 usually suggest a defective touch pad (The keys get stuck sometimes because long use or "over pressing" or poking it with things like knives and such). If its a unit with seperate touch pad and clock (controller) changing the touch would be enough othewise the whole controller has to be replaced. You did not give a model number so not able to give an exact price. But it should be in the region of $120 - 230 depending on the model you have
Regards
Posted on Sep 05, 2008
I'm getting a constant beeping sound and a F1
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced
Aug 10, 2011 | Magic Chef 9112 Gas Double Oven
Fault codes F1 and F2
Just two work there:
1.- Replace the touchpad or the clock (ERC) if the code "F1" is displayed. Disconnect the ribbon connector to the touchpad. If no code is displayed after an hour, replace the touchpad. If the code displays again, replace the clock.
2.- Replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Parts replacement coudl look in www.repairclinic.com
Hope helps.
May 02, 2011 | Magic Chef Ovens
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | Magic Chef Ovens
Old Magic Chef wall oven (model 9875-5XRB), constantly beeps and displays the F1 error code. I have replaced the touch pad once before. Is that the only solution?
Does anyone know the answer? This was posted in October 2010! I ran the self clean too about a week ago. But we had a bunch of power outages last night. Today my oven has taken to beeping and flashing the F1 code. It is almost the same Model number. they wrote 9875XRB (not 5XRB) ...
Oct 18, 2010 | Ovens
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
My mom has a Magic Chef oven, model 5892VRV. It
You have 2 choices.
Replace the electronic control(clock).
Or, replace the range.(stove).
Sep 04, 2009 | Magic Chef Ovens
F 1 beeping on Magic Chef oven ?
The F1 code is a defect touch pad or membrane
May 01, 2009 | Magic Chef Ovens
Oven keeps beeping and displaying F1
this code is suggesting that you might need a control board.
Jun 21, 2007 | Magic Chef 9815 Electric Single Oven
Oven timer goes off when not being used
I have the same problem with the beeping and screen flashing F1 does anyone have a solution yet?!
Aug 22, 2006 | Magic Chef 9512 Electric Single Oven
Ovens Logo
166 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
