Question about Frigidaire Refrigerators
Refrigerator Door Ajar Alarm
The door ajar alarm on my Frigidaire refrigerator Model FPCEB21TIRB1 sounds even though the doors are closed tightly. This can happen several times a day or not at all for several weeks and the only way to silence the unwanted false alarm is to open and close either the freezer or refrigerator door. Unfortunately, there is no on/off manual switch for the alarm. Is there any way to silence the alarm permanently? It's a feature I could happily live without.
  • sobejohn Sep 07, 2008
    With the help of a friend, we were able to solve the problem by first removing the "Transformer - door alarm" (part #36 in the System and Autmomatic Defrost Parts), a white plastic box located on the back of the refrigerator. We then opened the box and removed the circuit board to gain access to the door alarm buzzer. We disconnected and removed the buzzer and then returned the circuit board to its original position in the plastic box. Finally, we reattached the box to the back of the refrigerator since it's obvious that the transformer controls more than just the door ajar alarm. So far, the refrigerator is working normally and there are no more false alarms.
3 Suggested Answers
  • 26 Answers
SOURCE: Frigidaire freezer hit to touch after left ajar
If you mean HOT to the touch, that is normal if the unit is left open, the compessor will run indefinatly and transfer it's heat to the shell.
Fuji
Posted on Aug 07, 2009
woodchuck789
  • 4059 Answers
SOURCE: Freezer door stays ajar after closing the refrigerator door.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Posted on Oct 16, 2009
  • 2118 Answers
SOURCE: door was ajar on my
the air vents are iced up.you need to melt out the ice that's in the air ducts or remove the food,shut down the machine for a day and let it melt out on it's own
Posted on Oct 02, 2010
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Samsung refrigerator alarm beeping continuously
May 15, 2016 | Samsung Refrigerators
The alert ding goes constantly and no doors are ajar
How do I use the digital control panel on my Samsung fridge ...
www.samsung.com/uk/support/skp/faq/1023129
Samsung ElectronicsFeb 17, 2015 - Energy Saver Button. For better energy efficiency press the Energy Saver button. If condensation occurs on the doors turn the Energy Saver ...
Support - 4-Door Flex Refrigerator ... - Samsung
www.samsung.com > ... > French Door
Samsung Electronics4-Door French Door Chef Collection Refrigerator. 4-Door ... Will the Water Dispenser on the French Door Refrigerator Work Without a Water Filter Installed?
My New Samsung Fridge Won't Quit Beeping - eHow
www.ehow.com > Home
Remove bulky food items that might keep the door ajar. ... Samsung refrigeratorsfeature an internal door alarm system to alert you when a door ... The alarm turns off and the beeping stops no matter how long the doors remain ... Therefore you hear thedoor alarm go off in intervals, even though the door is actually closed.
Jan 19, 2016 | Samsung RF4287HARS French Door...
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
How can i stop the door ajar alarm when door closed and 0 f
Hey friend, thank you for your post!
In order to stop the door ajar alarm from beeping when the door is closed you would need to reset the alarm. If you have done that and it continues to beep it could be an issue within the switch or panel of your Frigidaire freezer. I would recommend having a professional come out to properly diagnose your appliance. -Matt
Sep 19, 2014 | Frigidaire Freezers
What causes my Kenmore to buzz when dispenser door is closed?
Sep 14, 2014 | Kenmore Refrigerators
My frigidaire gallery refrigerator model number DGUS2645LF3 is showing an error code "5b" and nothing inside works.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You are in the Sabbath Mode.
The Sabbath Mode is a feature that disables portions of the refrigerator and its controls in accordance with observance of the weekly Sabbath and religious holidays within the Orthodox Jewish community.
Sabbath Mode is turned ON and OFF by pressing and holding "?" on freezer temp and "?" on refrigerator temp for five seconds. The display shows "Sb" while in Sabbath mode.
In the Sabbath Mode, the High Temp alarm is active for health reasons. If a high temperature alarm is activated during this time, for example due to a door left ajar, the alarm will sound intermittently for about 10 minutes. The alarm will then silence on its own and a red high temperature icon will display. The high temp icon will continue to display, even if the door is closed, until the Sabbath mode is exited and the icon reset. The refrigerator will function normally once the door is closed, without any violation of the Sabbath/Holidays.
If this does not solve the problem you have a bad control board.
Sep 02, 2014 | Frigidaire Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
Refrigerators Logo
1,146 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
