Question about Panasonic CT-27SC13 27" TV
Component Input Video 1 component input isn't working. When you press the tv/video button all I get is video 2 and video 3. I purchased a progressive scan DVD player and wanted to watch movies in 480-I, but video 1 isn't working... never appears.
    Novelist:
    Champion:
  • 277 Answers
To save cost on this model, as with many others they are sharing the S-Video input circuits with the composite input circuits at the entry point. There is a kill switch incorporated with the S-Video jack in the set. Even if you put an external switch box to the set, the composite video will not work unless the S-Video plug is pulled. Your best solution is to get a TV set with a true multiple video input. The other alternative is to have a sat receiver with an external input for throughput feeding. Another alternative, but not as good quality as S-Video, is to use your sat receiver in the composite mode to the set, and have an external switch box to select one or the other.
Posted on Sep 18, 2005
I had it working about 10 minutes ago and moved the remote and now no signal.. how do I fix this?
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
Feb 05, 2018 | Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
Have connected cable (white, yellow, red) from Conia DVD player to TV as component 1 and connected Sony VHS cable (white, yellow, red) to TV as component 2. What other steps need to be taken for the...
component video needs Red, Green, Blue to be connected on the DVD end and to the TV for video to display, also the Red and White audio out needs to be connected to the TV for audio to work .
VHS has Red, White an yellow for Right Audio, Left Audio and video respectively.
You need to switch the inputs on the TV to the corresponding Component and Video inputs. Most TV's have a source or Input button to switch between the inputs. simply press the button until you have the input you are looking for.
Mar 13, 2011 | Televison & Video
No colour
Hi, Definitely a TV issue for me. Changed Wii to another input on TV and resolved situation. Need now to check how to get my TV to recognize colour on AV2 & 3 because I prefer to keep DVD input as AV1!
I had to use the (RCA) video inputs and not the component inputs. These are the ones made for video games. If you want to use the component input (Component cables are Red,White Red, Green, Blue). If you don't have any, you should be able to purchase them at your local electronics store like Radio Shack or Best Buy. Hope this helps, read below:
TV (This is your cable connection or TV; coax)
Component 1 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
Component 2 (Must use component cables for this input/output; Red and White for audio, Red, Blue, Green for Video)
HDMI 1 (HDMI Cable)
HDMI 2 (HDMI Cable)
Video 1 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Video 2 (Must Use RCA cables, or RCA jacks; Red and White for Audio, Yellow for Video)
Sample of Component Cables:
http://www.tigerdirect.com/include/AddCartfromGallery.asp?EdpNo=245214&csid=ITD&Sku=C184-27083&imgcart=1
Oct 07, 2010 | Nintendo Wii Console
Tv works jsut no pic black and white screen says weak or no signel?
If it says "weak or no signal", this means your are not showing the correct input or have no channels programmed.
To find the the correct video input:
1. turn On the device you are trying to see
2. press the [input] button on the side of the TV until you get a picture (wait 3 seconds between pressing the button)
You program the TV by accessing it in the User Menu.
Also, You may access the inputs using the TV remote. Each input button (V4 and V5) may need to be pressed muliptle time to access the picture . When you press this on the remote you will notice the input change from Composite 1, Component 1, S-Video. V5 will show composite 2 and component 2. Using the side panel allows youto scan all inputs in case you are not sure.
Jun 23, 2009 | JVC LT42P789 42 in. LCD TV
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
The who input button
usually a tv that doesn't "see" video on the S-video will not even "switch" to it.  It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual From the Manual:   " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button Use the WHO•INPUT button to toggle through the available input sources (VID and the current channel) and view the content from the component you have connected to the TV. 1. Press TV to place the remote in TV mode. Make sure that the content from the component is turned ON. 2. Press WHO•INPUT to tune to the available input source and view the component. 3. Press WHO•INPUT again to tune back to the channel you were previously watching.  "
James Mac
Sep 10, 2008 | GE 31GT740 31" TV
1st time using component video connections on my onkyo
Yes, switch to the video input that you are trying to configure (i.e. video 1-4). Press the menu button on the receiver or the remote and cycle to video settings. There should be a setting that says "video output" or "output" - set that to component. You may also have to configure the Input for that particular setting. For instance, if you have an HD tivo going into component 2 but you want it to be Video 1. Select Video 1, hit the menu button and scroll to video setup. Select video input setup and cycle it to component 2. Next, use the menu to cycle to video setup, select video output, switch to component. This should solve your problem. As a sidenote, you may also have to configure the audio in/out if you're using digital coax or optical. Let me know if this works.
Feb 02, 2008 | Onkyo TX-DS787 Receiver
Panasonic CT-27SC13 27" TV Logo
189 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
