Question about Samsung SpinPoint SP8004H 80 GB Hard Drive
Samsung sp 8004h samsung hd
I have a samsung sp8004h hard drive as slave
but it only shows capacity od 31.8 gb
as actual size of drive
wondering what could be the cause
  • 1 more comment
  • pbb5 Sep 04, 2008
    sorry actual capacity 80 gb sp8004h
  • Anonymous Nov 26, 2008
    I have this problem as well. HD is partioned into two but the missing part can not be found with Hirens Tools or others. ?????
  • ariel santos
    ariel santos May 11, 2010
    what is the actual capacity?
  • 446 Answers
How many physical hard drive you have if you have only one, chances are you have formatted this and devide the hdd into two, thats why you can see only 30gb on it, just for clarification...
Posted on Sep 17, 2008
Need maxtor Diamond 21 320 gb slave setting
Take a look at this pdf:
eshop.macsales.com/Tech/manuals/idehdsettings/Maxtor72.pdf
So If this is layout " : : : . : "
then...
slave -----------
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Jun 23, 2012 | Maxtor DiamondMax Computers & Internet
Install 2nd Hard Drive with different connectors and different OS.
yes you can use either sata power or molex(4 pin) plug to power your new SATA hard drive but not both at the same time.
Mar 19, 2012 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Hello im trying to set mysamsung sp8004h harddrive as a slave i dont know the proper pin settings it shows in the bios and device manager what do i do.
If it shows in the BIOS as a "slave", then you have the correct settings. If it does not show, or if the other drive on the same ribbon-cable does NOT show, then you have the wrong setting.
Nov 01, 2010 | Samsung Computers & Internet
Hi I have SpinPoint SP8004H 80 GB Hard Drive that has stopped spinning up - any thoughts on how to recover the data off please?
you might want to use a professional service to recover the data. Its not really an easy process and I dont suggest opening up the hard drive since the parts inside are very sensitive.
Oct 05, 2009 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Samsung SP0802N 80GB Slave
Go into the control panel. Press administrative tools. Select computer management. Under storage select disk management. Look for the hard drive. Make sure there isn't an additional partition on the drive. If there is you can change and delete partitions on this drive as well.
Jan 03, 2009 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Increasing the Hard disk capacity
Welcome to FixYa, my name is Steve. If you are adding a hard drive you need slave that drive to your existing hard drive. The hard drive manufacturer may have an installation program but normally you only need go to your BIOS setup and see if the hard drive capacity id displayed along with the options available there for LBA, etc. The description of your problem only mentions BIOS capacity but leaves me wondering what the present problem you face really is. I will help with more information. Steve Medley
Nov 30, 2008 | Computers & Internet
Seagate 160 gb capacity problem
the harddrive size is in another measurement system and the actual size of the drive is exactly what you are seeing 152.
here you can see how my disks show
894a905.jpg 160GB disk - 152,66GB
1000GB disk - 931.51GB
that is correct.
Jun 15, 2008 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard drive replacement
SATA drives are the latest hard drives available nowadays. You could try going online and checking other sites that could still have an IDE hard available for sale.
Jan 02, 2008 | Samsung SpinPoint SP8004H 80 GB Hard Drive
Samsung SpinPoint SV1203N 120 GB FHD
Try increasing the actual partition to the capacity numbers in the windows xp formatting , and also format the hard drive using NTFS .
Dec 08, 2007 | Samsung SpinPoint V80 SV1203N 120 GB...
Maxtor 500gb internal hard drive
To fix/restore to full capacity, you may need to delete the existing partition and re-partition then reformat again.
Most old computers have limitations on the CMOS/BIOS as to how big the capacity of the HD that it can recognize.  Windows however would recognize big HD size and therefore can partition, format and check.
Alternately, a third party disk utility program may be used such as Partition Magic.
Hope this be of some use/help. Post back how things turned up or should you need additional information.
Good luck and kind regards.
Oct 26, 2007 | Maxtor Hard Drive
Samsung SpinPoint SP8004H 80 GB Hard Drive Logo
393 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
