Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima CTD80
Hi , my dryer seems to have stopped heating as it dry's, it is also flashing either F-08 or F-10 depending on which setting i was trying, I was trying to dry a large feather pillow. I have switched off and re set the program, it starts then comes up with the error message, i have cleaned the filters(both) checked the water draw is empty and de fluffed the small tank at the back of the machine that the water condenses into, I have had this machine three years with no trouble from it so hopefully it is a simple fix?
can you help? cheers jo
  • Anonymous Nov 08, 2008
    dryer shows f11 errer
  • 4 Answers
I have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Posted on Jan 14, 2009
  • Marc Hindley
    Marc Hindley Oct 23, 2011
    Woman or not, your description of the parts is perfect and your solutions works. Unplugging is a must!
    President:
  • 1,462 Answers
Take back panel off. check continuity thro the heater and ther stats. usually one of the stats faulty
Posted on Sep 05, 2008
I dont know at which point in your life you decided to make this your fixing solution. but it as worked an absolute treat. iv been having this f-10 problem for ages i keep cleaning out the filter and no luck. then i found this and thankfully as your a women and im a women i understood your thingys lol. thanks so much. who needs men ay lol
Posted on Jul 18, 2010
  • pju1 Oct 17, 2010
    I'm a bloke - and NOT a handy-andy - but Sunday morning - "F-10" shows up - wife out running 10 mile race - follow your instructions and - yep - we're drying!
    Great help - thanks.
Hotpoint ultima tcd980 condenser tumble dryer not drying properly
this sounds like one or two of your stats (tod) for short have gone if you need more help get back ok
Oct 22, 2012 | Washing Machines
My drier dos'nt dry my washing
Is it pumping out the water?
try laying the draining hose on the ground or a bit lower than the machine if possible.
Jan 15, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
By hotpoint ultima ctd80 tumble dryer has error code f11. What does this mean?
F11 - No pump connection. the pump that pumps the water up to the draw has gone wrong. hope this helps.
Sep 26, 2010 | Hotpoint Ultima WF860 Front Load Washer
Condenser not drying stuff properly
I am hoping your talking about a clothes dryer here. based on the model number you posted here. Does your dryer even feel warm to the touch as in any signs of internal heating? If not then here are some things to check. 1 the basics: Check the circuit breaker and make sure that both of them are in the on positon. Just trip them off and then back on again to reset them. 2. Check the power cord for any signs of a bad connection. It will show up as a dark discoloration. 3. I know you said you checked the lint filter but have you gone outside and verified that the external outlet vent is free of obstructions? If not please check it and clear any obstructions. 4. The heating element itself may be open. Ovetr time they are like light bulbs and the burn out requiring repl;acement. 5. There can be a thermostat failure causing an open circuit and no power to the heating element. 6. The motor switch also controls the heating element circuit and it is actuated when the motor is running. If the switch has failed it will prevent the heating element from being energized. 7. The least likely suspects are the timer and heat setting controls yet either of them can cause a no heat condition. You did not mention if it was a gas or electric dryer and the comments above are for an electric dryer. If you have a gas dryer then you can have 8. a bad ignitor, 9. a bad gas valve, 10. a failed gas regulator. Based on this model number CTD80 it does not cross to anything that I can find. The bottom line is your unit is probably worth the cost of getting it repaired. You may want to check your model number again please and repost it you need more information. It appears this is a UK model. I hope this was helpful. It certainly was educational here.
Jan 11, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Ultima CTD80 suddenly stop working mid programme, supply is okay and fuses are good any ideas would be a welcome help thank Martin
if you have no display then the overheat cutout on the heater has tripped. can be reset but check air path (door filter and condensor ) as this usually trips for a reason.. safety first.
Oct 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint CTD80 Tumble Dryer F03 error
hiya
sounds like you will need a thermostat kit and possibly a heater unit, if your getting them shipped to oz you will probably use them. i would change the thermostats first as this will more than likely be the cause.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj.
p.s if its still broken this time next year i'll come and have a look just waiting of my visa :)
Jul 24, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WT965
Hotpoint Ultima WD72 Front Load Washer/Dryer
This video will show you how to keep your soap draw clear and how to service the parts.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Jul 08, 2008 | Hotpoint Ultima WD72 Front Load...
Tumble dryer not drying
Either dryer element has failed, thermostat for drying or the drying condenser fan not working.
There are two heating elements and the top one is for drying.
Apr 07, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima tumble dryer error code f-03
i have a hotpoint ultima ctd80 which i have had the last 2 years, it has shown error codes f11, f10 and f15, every time i fix this problem by first switching off and unplugging appliance then removing small cover from back (middle with 2 screws) then larger panel that the smaller panel overlapped. once you remove these you will see the heating elements, remove the 2 screws at the back off this, remove cover carefully then at the top you will see two things (not very technical lol i am a woman), with a pin press the pin in the one with a hole, mine makes a clicking sound when i do it, not sure if it meant to but works for me. put all parts back together and thats the job done. make sure both fillters and water emptied regular, hope this helps and saves you a fortune on call outs
Jan 26, 2008 | Hotpoint Ultima WF860 Front Load Washer
No heat on tumble dry programme. Display flashed F 13.
You need to replace the heating element for the dryer which is positioned on top of the outer drum. Remove the top cover of the machine and locate the heater.
Nov 01, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
1,175 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
puggy666
Level 1 Expert
gbob59
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
