Question about Zenith L20V26C 20.1 in. LCD Television
Colors Bleed I bought this TV and for the first week, it worked well. Then, one day, I turned it on and the coloring all bleeded together. I don't have any idea what could have caused this. I didn't do anything weird to it. Any ideas?
    Novelist:
    Champion:
  • 277 Answers
In answer to your question, the problem is probably due to a bad drive transistor, dead/dying electrolytic caps, and/or a bad gun. consider taking it to a repair shop.
Posted on Sep 18, 2005
SOURCE:
My HDTV wont turn on, two weeks ago the colors blend together I wasen't able to adjuste the colors. then I turn it off and leave for two weeks. when I try to turn it on it wont turn on, the control panel...
It seems that you have an issue with the power board. You could also have faulty convergence modules causing the blending of colors.
I wouldn't advise you to open the set yourself, because of the complicated circuitry and high voltage. It is safest and best to get TV repairman to look at this issue and provide a fix/repair.
May 31, 2008 | RCA Televison & Video
Problems with colors and display on my Samsung LN37A550P3FXZA flat LCD.
Replace all busted capacitors in power supply board inside.
Jan 10, 2014 | Televison & Video
First a line appeared across my screen then several weeks later the colors started to bleed over picture until now only a small amount of picture can be seen through bleed colors. It comes and goes
Hello
The digital processor board has the trouble. there is no repair to this board. It has to be replaced as card basis.
2_3_2012_4_21_40_pm.jpgSee the picture of the faulty board, and its position. The work is a skilled one ofcourse. OK.
Feb 03, 2012 | Toshiba 42HP83 42 in. HD-Ready Plasma...
SljThere is a sound like a motor
Ur tv have a colors wheel design into it.The tv colors wheel it is defective and it is worn out,it is not spinning inside it motor mount axis motor baring anymore.The tv colors wheel is it defective that where the motor noises came from.The tv colors wheel it have to be replace to solve this making motor noises problems.The tv colors wheel it is sit way back of the tv.If u don't have any mechanical skills like take many mechanical parts aparts and putting it back together again.Don't atemp to change the tv colors wheel ur self.Hire a tv tech. to change the tv colors wheel.
Sep 22, 2011 | Samsung HL-P5063W 50" Rear Projection HDTV
LG 32LF11 HDTV is haveing blurring issues, meaning that in some instances ( like digital art ) colors blend together or i should say bleed together, like if i take a red background and put a black line...
I have a similar issue with Samsung LN46N610. Red (and green to a lesser extent) text or graphics on light background creates something like a shadow or blurred edge. My PC is connected to HDTV via HDMI cable. I don't have this issue when I use Toshiba 46XV645U (Toshiba a different audio problem though) HDTV
Jan 03, 2010 | Televison & Video
Bright colors bleeding onto picture
if you tried adjusting all parameters in the menu and anything you do is not resolving it, go into any workshop to have them replacing the main board. It looks ugly this idea but now days this kind or repair is posible and the board is "affordable". find any workshop close to your area. The reason of this idea is because the main board controls all parameters in the tv and the other part who we can blame on is the screen itself so if the tv is repairable (economical to repair) the workshop sure it would tell you.
Apr 08, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Color cartridge problem
the color cantridge u changed is genew or u have token the other and just fill them fith ink???
if u have bought new cartidges go try print a test page and check if u have installed the cartidges corectly
if u havn bought genew cartidges i seems that the heads are blocked with ink!! go buy some new ones and i believe u will be fine
dont forget to vote!! :)
Stratos
Nov 17, 2007 | HP PSC 1510 All-In-One InkJet Printer
COLOR BLEEDING
Thats A 26" LCD tv sets thats sold mostly by walley world. The problem you describe is most likly the sustain voltage on the LCD screen has a bad capacitor in the power supply circuit that supplies that voltage to the driver board. If you still have a warranty Take it in or hopefully you bought an extended warranty with the set. Good Luck.
Jul 25, 2006 | iLO 2600 Television
Zenith L20V26C 20.1 in. LCD Television Logo
138 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
