SOURCE: poulan chain saw P3314
pull the muffler off and check if the piston is scored,if it is you need to replace the piston and cylinder.
SOURCE: rough start
dear rough start, i would suggest that you check the pilot jet in the carb. they have a very small orfice. this involves removel of carbs and cleaning. but try a carb cleaner that is put in fuel such as sea foam or someting similiar then take the bic for a good run down the highway. its worth a shot could solve the problem.
SOURCE: battery keeps losing its charge
you need to change your rectifier this is a common fault with harleys
SOURCE: stihl KM 55 won't start
1. 1st change the spark plug to NGK BPMR 7A.
2. Set the kill switch to on position (I)
3. lock the throttle interlock on
4. Do not prime the fuel bulb...this may cause flooding.
5. set the choke to full choke.
6. pull the cord gently until the piston resists then pull hard
7. repeat pull a second time
8. open choke all the way
9. pull cord again hard.
engine should start within 2-3 pulls, release throttle and feather the throttle until stable
SOURCE: what type of oil is needed for it
Hey pal, buy the best oil you can. I use Castrol Syntec Actevo 10-40wt. Buy 3 qts You might not need all 3 but it will come close...and that way u have some for topping off later....don't overfill and check your dipstick while u slowly fill er up...
good Luck to ya friend....Tim
