Question about Spectrum Technical Hifi EQ-B5100 Professional Equalizer with (Black) Home Equalizer
Hook up to Ritron EQ
Hi. First I apologize for my ignorance but I have been given a Ritron equalizer (vintage it seems) - 20 channel in all - 10 on each side. I would need to know how to connect it to my Kenwood receiver or to my Yamaha vintage amplifier if I want to go that route - and assuming it's the amp we connect to.
The EQ has the following confusing array of connections at the back.
Under TAPE we have two connections (L and R) for MONI and OUT. Under LINE, there are two connections under OUT , and then, next to that a bank that states : 2 - IN - 1, with two connections under the 2 and two connection under the 1 (again L and R). It's very confusing. Could you please help keeping in mind that I know nothing about connecting vintage equipment. Many thanks
  • 682 Answers
Record out-------equalizer in---------equalizer out-------playback in.
Posted on Sep 08, 2008
How do I hook a bsr eq-1 equalizer to a Yamaha av receiver rxv573
Seems like it should be , audio out to the eq. Then out of the eq to your sound source, ( speakers )
Apr 22, 2015 | Yamaha Audio Players & Recorders
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
I AM trying Hook up Sony rec suroundsond to eq
You can't. External analog stereo processing DOES NOT EQUAL multichannel. Two channels in, two channels out.
May 11, 2011 | Yamaha EQ-70 Home Equalizer
I recently bought the yamaha rx-v567 and I own a yamaha EQ-70. How do I configure and hook up the EQ to the receiver?
The EQ is connected via one of the Tape loops on the amp (rec out from EQ to play in on amp,rec out on amp to play in on EQ). You then switch "Tape Monitor" on to hear the sound with the EQ settings applied. You can also connect it across Pre out and Main in should you have such sockets. I'm pretty sure it will only affect the main two front channels and not the surround channels.
Dec 19, 2010 | Yamaha EQ-70 Home Equalizer
How do I hook up my older model Onkyo AMP (model# TX-20) to my ADC equalizer
use tape out from the amp to line in on the eq (observe left and right)than line out on the eq to tape in on the amp----whenever you select tape monitor and the eq is on your sound is equalized --enjoy
Sep 08, 2010 | Audio Players & Recorders
Manual
amp output goes to eq input
eq output goes to amp input
WHEN USING TAPE MONITOR on amp you run record from amp to input on eq and
output from eq to play on amp
Jul 27, 2009 | Teac EQA-120 Home Equalizer
Eq on channel a doesn't work on 2 units
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Feb 11, 2009 | Peavey EQ215FX Home Equalizer
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
Hi. i want to add a graphic eq to my pioneer receiver (home audio).
if the Eq has enough jacks to run every thing, that would go In to Eq an out to receiver, you were told correctly, for example cdplayer out - to Eq In - Eq- out to Receiver in
Nov 29, 2007 | Spectrum Technical Hifi EQ-B5100...
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
244 people viewed this question
Top Spectrum Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spectrum Audio Player and Recorder Expert? Answer questions, earn points and help others
