Question about Ovens
Beko DCC4521 Guys, Please help. My Beko Dcc 4521 has just packed in. The bottom oven does not work. The fan comes on, the light next to the dial lights up. Yet I get no heat to cook with. Please help
  • topseller08 Sep 07, 2008
    Hi there, cant actually see the element enough to visualise any damage. However at £20 for an element I would like to have a go at changing it.
    Can you assist me further
  • Anonymous Mar 23, 2014
    Power. On light on no heat
On Tuesday this week I had the same problem, purchased a new element, followed the instructions from Apprentice & my cooker is now working again to the delight of my wife & for saving me about £300. Thanks
PeterB
Posted on Feb 07, 2009
    President:
  • 1,462 Answers
Almost certainly the element. take the back panel off inside the oven and the element is exposed. often you can see the damage. if you want to go further and repair yourself, then get back to me
Posted on Sep 05, 2008
Switch off mains
remove the back panel inside the oven
remove the back outer panel.
the element is held in by one of two ways
either 2 7mm nuts on posts coming out from the element base plate or 2 screws from inside the oven
plus one screw inside the oven on the outside ring
remove wiring making a note of where it goes
undo nuts or if applicable, screws and element comes out
replecement is the reverse procedure
before removing element, suggest you check it with a multimeter to see that it actually faulty. if no multimeter, another way is to remove element wires and connect direct to mains and if ok, it will heat
Posted on Sep 07, 2008
MY BEKO DV5531 COOKER WORKS BUT WHEN I PUT OVEN ON FAN LIGHT COMES ON BUT OVEN JJUST BUZZES WHY ??
The blower motor has gone bad and will either need lubed
or replaced.
Sep 01, 2014 | Ovens
My beko Dcc 4521 electric oven won't switch on at all. I have changed the main 30amp fuse and this hasn't helped.....any ideas??
You may have had the experience of replacing a defective 30A fuse with a defective 30A fuse. It happens. We've all done it.
Jul 11, 2014 | Ovens
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2013 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
Jan 14, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Ovens Logo
696 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
