Question about Dell 962 Photo All-In-One InkJet Printer
962 All in One
The bulb used for scanning and copying has gone "dull" on me. All copies now appear black or grey and are not legible.
Where do you buy a new bulb and how do you install it?
  • kvarle Feb 18, 2009
    my scanner bulb (lamp) is pink and i can't find a repalacement bulb
  • arosendahl Mar 31, 2009
    Same for me. Where do we get the bulbs? Is it worth it? Are there any Dell employees in the U.S. that can help?
The printer is functioning, however when the paper comes out these is nothing on it. Yes, there is fairly new ink in the printer. Please help with this issue. Thank you
Posted on Sep 20, 2008
Samsung scx 3200 prints dark but xerox copies are so light that they cant be read
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Feb 14, 2014 | Samsung SCX Office Equipment & Supplies
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
Where can I buy a replacement Bulb for my printer Brother MCF-6490CW?
You will most likely need to take it to a staples or send it in if its still in warranty and they will replace it for a small fee
Aug 05, 2012 | Brother Office Equipment & Supplies
My Del 962 will not scan. The light does not come on and it does nothing. What should I do?
Hi,.... I'm having the same problem as sharon_mi334. My Dell AIO 962 does not copy, fax or scan...but prints. When attempted(copy, fax or scan), the output is a scanned image or a print out that's completely black. When I looked at the "scanner light unit/ copier camera" or what-ever it's called ... the gizmo that moves across under the glass plate,... I noticed there was NO light coming out of it as it should on any other copier, etc. Sooo,... is that the problem, ie: unable to copy the image? If so, can I fix that by replacing a bulb or a particular unit? Looking for some advice and thank you for your help and time.
medflight.
Dec 11, 2009 | Dell 962 Photo All-In-One InkJet Printer
Thick black and grey line when scanning or copying a document.
Burn the thing it's junk. Go buy a commercial machine if you want something that works.
Apr 15, 2017 | Epson Stylus Multifunction Inkjet Printer/...
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
2nd request - Dell 962 All-in-one Printer - from glass top
ok..start by removing the printer from your printer panel.
then go here for fresh drivers(not the CD version)
reinstall
hook up printer
see how it works
Mar 17, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell No. 962 (All-In-One Printer)
you need to go to your printer settings and make sure it is set as the default printer for everything. Make sure it is also set as your default scanner. you may also try lightening the image with the lighter/darker setting on the machine. if this continues, you may want to see if a section of the light is burnt out. this wiill cause darkness on scan & copies but not printing from the c drive. Make sure the machine is lighting up completely when is scans or copies. If part of the lighting is burnt out it will be a fix or replace situation.
Mar 05, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
192 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
