Question about Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon super g3 image class d880
Cant get to do anything giving E000 error code
unplugged, checked trays, took toner in and out,
tried delete and clear buttons
  • Anonymous Nov 01, 2008
    error code e000
  • Anonymous Apr 10, 2009
    So how do you reset the "fuser" unit? for an E000 error?
  • 4 Answers
E000 means your fuser section is having problems.sometimes you can reset but may need to replace fuser unit.
Posted on Oct 01, 2008
How do you reset fuser unit?
Posted on May 07, 2009
D861 E000 show up.. unplugged and reconnected still shows E000 Cannon Product
Hi there
E000000-0000
E000 to E004 are all to do with the fixing unit.
It can be reset.
It has been known to be caused by noise on the mains supply so a filter might keep it away.
To reset. Press the star button followed by 2 and 8 at the same time, then the star button again.
You should now be in service mode.
Select COPIER and this will give you some options along the top.
Select FUNCTION.In the list select CLEAR.
From the next list select ERROR and press ok.
Then switch off machine and back on at the power socket.
If it clears then all is ok.
Be warned!! Do not try to change any settings in service mode or clear any other function!! It is very easy to turn the machine into a cabbage.
Sorry I cant help you more than this, hope it works for you
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 01, 2010 | Canon ImageClass D861 Printer
Error E000
unplug the unit for just 1 day, or you can fuse near the powersupply area if you have access into the inside parts.. but first try to unplug the unit for a day to remove the last settings you made..
let me know
Aug 08, 2008 | Canon ImageClass D880 Copier
Hi, My printer had a paper Jam and I am pretty sure some paper got stuck however i cant find any when lifting the top up.It now wont work and the alarm light is flashing ThanksJemma
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred. Step2 Turn off the printer. Step3 Remove any paper trays. Inspect them for wrinkled or damaged paper. Step4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge. Step5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it. Step6 266_a1.jpg If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam. Step7 266_a2.jpg If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything, though. Step8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on. Step9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
If you still face the problem let me know..
Goodluck..
Jun 03, 2008 | Canon Office Equipment & Supplies
Error Msg E000
E000 is a fixing unit failure...either the thermistor or fixing lamp failed. Not sure about individual part replacement, most likely needs entire unit replaced....then reset the code.
Aug 03, 2009 | Canon Office Equipment & Supplies
Canon Imageclas D860 Error Code E000 Have tried unplugging the unit and then restarting to no avail
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear the
error.; then, turn back on the power.
Apr 14, 2009 | Canon imageCLASS D860 All-In-One Laser...
E000 sYSTEM eRROR
Solution: Unplug unit for 3-5 minutes, then plug the unit back in
Unplug unit for 3-5 minutes, then plug the unit back in.
OR
I hope it helps!!!
Dec 12, 2008 | Canon ImageClass MF5770 Laser Copier...
How to reset error code E000 on IR2000
E000: Fuser did not heat up. check Fuser lamp, check thermistor, check thermostat, if this parts ok try to reset the trouble code. to reset fuser errors, first shut power off and turn on again. Then, go to service mode. Select "User mode" by pressing additional function ( * ) key then Press "ID" key ( # ) on user mode screen. Select menu 7 using cursor key. Press "OK" key. Select 4 item with cursor key. Press "OK" key. Printer reset. YES=( * ) to clear fuser error code E000.
Jul 11, 2008 | Canon Office Equipment & Supplies
On a Canon D671 I received error code of E000 after hearing a soft pop in the machine, I was copying from the TRAY. Thanks, Roger
Took it to the repair shop and they put in a new fuser (the heating element burned out). ((The heated roller the melts the toner to the paper at the output of the copier.))
Jun 19, 2008 | Office Equipment & Supplies
System Error E000
Since there are few techs who can function on telepathy alone, a make and model number is mandatory.
Make; model #; description of problem, and it wouldn't hurt to mention (generally) where you are located.
There isn't a 'generic problem' within even a particular manufacturer's machines; most have varying sets of error codes within series of machines since they may be equipped differently.
Jan 25, 2008 | Office Equipment & Supplies
Error E000
the machine model or brand is not mentioned,
but if it is canon this code relates to heater [fuser} proplem
Dec 21, 2007 | Office Equipment & Supplies
1,118 people viewed this question
old marine
old marine
