Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sony Wega KP 46WT520 - Flickers Green
Good Day,
This TV occasionally flickers to a green screen. It will stay green for a time - then it will go back to normal.
This TV was manufactured in 2004.
Will replacing the lamp help?
Thank you for your assistance.
  • 3 Answers
EVERYONE CALL SONY- SONY HAS EXTENDED ALL OF OUR WARRANTIES. i have this same problem with my 60" wega. i called sony and they explained to me that the problem was the optical light box. it cost a grip to fix even for them...so instead of fixing the problem they offered me the best true flats they had at way less than the actually price. i bought a 46" bravia for less than 550 including tax. i still have my 60" but until i get it fixed on my own this 46" will definitely do. i hope this helps you all
Posted on Sep 10, 2008
  • archiecando Sep 10, 2008
    helps you all
Should i have this fixed or buy a new tv?
OK LOOK IN YOU STK RESOLD YOU IC STK AND BE FIX
Dec 29, 2008 | Sony KP-46WT520 46" Rear Projection...
TV switch light flickers 11 times but no function
Hopefully it is only a board component that needs replacing and your dry joints that need re-doing. I would advise that you take it to a television repair shop as this type of repair can be very complex (replacing resistors and capacitors just to name a few).
Dec 03, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Projection TV keeps shutting down
Good Day;
Sounds like you have a bad green picture tube that has failed. To check this out; remove front speaker grill, remove small panel, you will see three CRT's (pictue tubes) sticking down, remove the little board on the middle tube then restore power. If TV stays on more then likely the CRT is bad but not always the driver on board could also be bad, check voltages.
Good Luck, big IRISH.
Sep 05, 2008 | Mitsubishi VS-45607 45" Rear Projection...
The TV shows light green ring line on the screen.
Take off the speaker grill and the particle board just behind it. You'll find a block with six knobs. The 3 bottom knobs can be adjusted ever so slightly to fix your problem. Do it very slowly. You wan to adjust the center knob for green. Turn it until the lines go away. But again, do it very slowly. You're adjusting the voltage to the green tube. Do it too fast and you can damage it.
Jun 22, 2008 | Sony KP-57WS500 57" Rear Projection...
SONY KP-46WT520
does the led blink when it shuts down if so how many times does it blink? And the green line is that running up and down the screen or across the screen?
Apr 26, 2008 | Televison & Video
Kp-61v45green flickers left to right
there is a convergence board in the back of the tv that needs replaced..my tv was doing the same thing and i rto be replaced the board and it works perfect now.the part should run under 100.00 and has to be soldered in place.
Mar 03, 2008 | Sony KP-61V45 61" Rear Projection...
Screen/Picture Flickering
alo all..
i got problem wif my TV... sony wega trinitron 29inch..
- last 2 night... the TV @ screen slowly lost color for 2-4second... and after that it suddenly turn off for 5-10second and turn back on itself. the led blink 3-5times....
what the problem to my TV?
Jan 09, 2008 | Sony KP-46S25 TV
Sony 46 9x16 tv turns green and goes off
Sorry, this sounds as if you will need a major repair. How old is the TV?
Dec 30, 2007 | Sony 46IN TV Stand Designed for Model...
Rear projection tv flickers green/shuts off
rodman, i just started having the exact same thing on my Sony (same model). it's about 5 years old. did you ever find a solution?
Dec 10, 2006 | Sony KP-57WS500 57" Rear Projection...
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
113 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
