Question about Viking Kitchen Ranges
Model No.VESO-105. Elec. convec oven. Had power problems recently. Oven now only has power to fan and light. No cooking at all.
  • Wkmmarfa Sep 04, 2008
    Element is brand new. Replaced it a month ago. I suspect one leg of 220 is gone. We were whacked by lightning last week and lost two computers, one phone system, printer and router. However I have plenty of power at the box both incoming and thru the breaker.
    Problem Solver:
  • 7 Answers
If the fan and the light is working,, and no heat would suspect the element has gone on the oven.. check that the thermostat light comes on.. if it lights up then the thermostat is ok.. Element is situated at the rear of the back plate inside the oven. kind regards mcdapp
Posted on Sep 04, 2008
I have a GE Profile Spacemaker model JVM1660SB005, maufactured in November 2000. I attempted to change a burned out bulb on the left side. I did not check the manual to see how to remove the bulb, nor...
I regularly see (and repair) this light and / or fan failure on model JVM1660SB005 and most any model of over the range microwave.
The problem is on the controller assembly, which I regularly repair very affordably.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 05, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
My Sylvania micro/convec oven was installed in my RV last year but has never worked correctly. It runs long after the beeping ends and the glass sometimes gets a rainbow haze across the glass. Is this...
With this oven being a combi ventilation and extraction is important, the haze across the plate is
surplus heat, It not cooking but what you hear is the extraction fan running until the oven cavity has cooled down
Feb 12, 2010 | Sharp R-353 Microwave Oven
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
GARLAND CONVEC. OVEN - CONVEC. NOT RUNNING
it sounds to me like the door switch is not making. if you take off the bottom panel the switch is to your rightat the bottom. make sure that you kil power first brfore you remove the panet.
Dec 22, 2008 | Garland Convection Oven - MCO-NAT Gas
No manual
The light bulb is the oven light.
The snowflake with 3 raindrops is Defrost Mode (fan runs with no heat to reduce defrost time)
The 2 lines up top & down bottom is Traditional Cooking (heat from top & bottom elements)
The big circle with a fan is the Fan forced Oven
The small line at top only is the Grill Mode
The larger line at top only is the Double Grill Mode
The line up top with the fan underneath is Double Grill with Fan mode
The line on the bottom with fan on top uses the lower element with the fan for delicate dishes
The manual can be found on the Baumatic website - www.baumatic.com.au - select your product which takes you into another page & you will see on the left hand side a link to "View User Manual"
Nov 11, 2008 | Baumatic B187 Stainless Steel Electric...
Instructions
Hi
I would gladly try to help you, but you do not mention wich brand and model the oven is, however they all work basicaly the same:
1. Punch in cook time. 2. Punch "CONVEC" 3. Punch a temperature button 4. Punch "START"
If you give me the brand and model number I may be able to email you the instructions for fee via email.
Hope this will help you.
Eddie Rentas
Tupper Lake NY
Jun 25, 2008 | Cooktops
Jennair range
f-5 means the clock/oven control is bad. the only way to fix this is to replace the oven control
Nov 26, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Kitchen Ranges Logo
209 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
