Question about Lexmark Wheelwriter 3 Typewriter
Wheelwriter ribbons Does the wheelwriter 3 and wheelwriter 5 use the same ribbon
  • angelno Sep 05, 2008
    Thanks for the answer. It was extremely helpful.
    Angelno
  • Lexmark Master
  • 3,594 Answers
The entire Wheelwriter line use the same supplies, ribbons and lift off tapes.
DickyO
Posted on Sep 05, 2008
IBM Wheelwriter 3 won't type
Print hammer selenoid cap is broken, or print hammer selenoid is gummed up.
Jan 03, 2014 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 - Cannot get the complete word - Middle part of word is white
Type on a two part form if the carbons are goog then you have a ribbon problem. Look at the ribbon. Do the letters overlap (ribbon feed) If they don't fall in a line near the center of the ribbon (ribbon lift) Check for folds in the ribbon.
DickyO
Oct 04, 2012 | IBM Wheelwriter 30 Typewriter
The correction tape is not working properly. Wheelwriter 1000
If everything was working befor the ribbon & L/O change Either the L/o is not properly attached to the ribbon or the ribbon and or L/O are old. Make some corrections then remove and look at the L/o, if the letters are near the center of the L/O the problem is the ribbon or L/o is old, if the print is on the top of the tape it is not properly attached to the ribbon or not coming out or the cassette properly.
If you have a fresh set or another T/W that works swap the ribbons and look at how they are attached.
For a picture ngo to lexmark.com and click your way to publications you will find a downloadable manual there.
DickyO
Jan 23, 2010 | Lexmark Wheelwriter 1000 Typewriter
My ribbon broke, I don' t know how to fix it.
The ribbon has 2 little (feet) on the rear of the cartridge they hook into the ribbon deck and it just rocks into place. You can get a picture and instructions @ lexmark .com klick your way to publications. Be sure to advance the ribbon by hand a foot or so to be sure it isn't sticking to itself.
DickyO
Sep 29, 2009 | Lexmark Wheelwriter 3 Typewriter
Ribbon won't advance on IBM Wheelwriter 3
Try some WD40 on the feed motor bearings top and bottom and the gear train it drives.
DickyO
Jun 19, 2009 | IBM Wheelwriter 30 Typewriter
Put new ribbon cartridge in ibm wheelwriter 3 not printing now
If the ribbon is lifting up you probably have a cracked print solenoid plunger cap. They are available but a little tricky to install.
DickyO
Feb 10, 2009 | IBM Wheelwriter 30 Typewriter
Wheelwriter 5
You probably need the plastic cap that is on the proint solenoid, they are available but a little tricky to install.
DickyO
Sep 30, 2008 | Lexmark Wheelwriter 3 Typewriter
Correction tape on wheelwriter 3
The correction cassette snaps on the bottom of the ribbon. The two little "feet" on the cassette slide over the small tabs on the ribbon and the ribbon clips on.
Hope this helps
DickyO
Apr 24, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 prints only top portion of characters
The platen is probably not all the way in. Be sure the black latches are lined up with the side frames and press firmly down on the platen.
hope this helps
DickyO
Feb 25, 2008 | Lexmark Wheelwriter 3 Typewriter
Wheelwriter 15 series II
The ribbon drive motor might be n/g. I think 6 beeps is the ribbon motor located under the gear on the ribbon cartridge.
Feb 08, 2008 | Lexmark Wheelwriter 1500 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
51 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
