Question about Refrigerators
My dometic rm4213s model fridge in my vw camper van wont get coold. the heat exchanger at the rear gets hot but not all the way across.
  • 51 Answers
If the freezer is getting cold check for air flow in the back it needs to be free of any obstructions. Next adjust the sensor on fins inside the fridge it works as your temp control move it up and down for control.
Posted on Sep 08, 2008
Can a dometic RF 60 absorbsion fridge be used in a camper van if gas is not connected?
google search shows that it is a 3 way fridge --12v/ mains /gas
it will operate off the battery, mains plug in ,or from a gas bottle
so --yes it will operate without a gas connection
it is not suitable for a built in application but is stand alone unit
Jan 15, 2017 | Dometic Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
Everything freezes, model 2652 dometic americana
Hello, Inside you fridge part (not the Freezer) you will find your cooling fins,and on you fins there is a white piese of plastic and in this plastic there is a probe this will adjust you temp. by slidding it up and down.but it hasen't been touched you may have a faulty probe.acesses to plug is in rear of fridge in a black box (printed circit board)located outside of camper,you may need a qualified person to install.
Sep 14, 2011 | Dometic RM2652 Refrigerator
My Dometic RM2652 in my camper isn't getting cool enough when it's set on electricity. It feels cool, but not cold. The ice in my freezer turned to water, but it was still cold. The refrigerator section is...
Sounds like maybe your element for Heating when on hydro may be faulty. A voltage check at spades on board connected to element will confirm. If power to element but no heat felt at element should confirm it's faulty. Remember, if stack is already hot from propane, element will also feel hot, so it has to be out or fridge cooled down at back first.(off)
Apr 20, 2011 | Dometic RM2652 Refrigerator
Hi my fridge freezes every thing even at it's
your thermostat is bad, what it does it sense the temperature set buy the control setting, once it goes bad it does not recognize the temperature hot or coold and the unit keep running and freezes everything. thermostat work like the therometer switch, when it reach certain temperature it cut off.
Jul 16, 2009 | Dometic Refrigerators
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Camper fridge will not cool down(unsure of model)
ok firstly if you remove the element and give it 110v does it warm up if it warm up and still not making the fridge cold the propane chemicals are not right any more
May 15, 2009 | Dometic WA3210 Compact Refrigerator
Freezer working on gas but not fridge compartment.
Check to see if you have the right gas pressure at the refer
Jan 26, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
119 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
