Question about Kitchen Ranges
Kitchen aid oven will not heat - Kitchen Ranges
  • Anonymous Mar 20, 2009
    I have a kitchen aid oven with a touch panel I keep getting a E7:E0 code when I try to preheat.
I fixed the problem by researching further myself and taking it apart and trouble shooting. If you had completed the session, your service might have been of help.
Posted on Sep 05, 2008
Why are both the upper and lower elements of my Kitchen Aid oven not heating?
They are either both bad, there is a connection loose or you through a breaker. Check the breaker box first and that the unit is still plugged in. Then check the elements. If they are black and charred looking then they have burned out.
Mar 15, 2015 | KitchenAid Kitchen Aid KERS507X Electric...
Oven will not heat up
Kitchen Aid blenders are used for chopping/blending not heating.
Apr 03, 2014 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchen Aid Gas Range.Convection mode fan does not come on.Glow bare works,as well as the gas element.Flame is the proper colour.Could it be the oven sensor?Model nos.ykgst307hw5
Does the oven heat to the proper temperature and hold it there or does it not heat at all? I could not tell from your description of the problem.
Regards,Richard
Nov 08, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
I bought a kitchen aid gas range 4 monthes ago. The model no is kgss907sss. The oven takes more than 1 hour to preheat to 375F. Sometime it even can't reach the temperature forever.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | KitchenAid KGRS807S Gas Kitchen Range
Igniter does glow and oven does not heat
Had same problem come up on christmas cold turkey yuk! What i did was swap the upper igniter for the broiler with the lower igniter for the oven and it worked so it sounds like the problem is the igniter you can do what i did to buy some time or just swap out the igniter with a new one. Good Luck
Jul 25, 2010 | KitchenAid KGRT607 Gas Kitchen Range
Kitchen aid slide in range - oven stopped working
Wynco, first thing I'd check is whether or not you are getting the 220 volts the unit needs. Find the circuit breaker and turn it off and then back on. This should be a dual or linked breaker. The breakers do corrode and wear out and may need to be replaced.
Dec 11, 2007 | KitchenAid KESC307 Electric Kitchen Range
Oven not heating to correct temperature
First thing that should be checked is proper voltage.  Low voltage can cause this problem.  Have that checked by a professional first then let me know what you find.
Oct 17, 2007 | KitchenAid KESC307 Electric Kitchen Range
Kitchen Ranges Logo
121 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
