Question about Canon PIXMA MP460 All-In-One InkJet Printer
Canon MP460 "np paper"
I get an error message when I try to print that says I have no paper in the feeder. It says to insert paper and reset the printer, which I do. It still does not grab the paper and I get the same message again.
Any solutions?
Thanks for your help,
Bob
  • 1 more comment
  • JOHNHA Dec 22, 2008
    Printer shows on screen that there is no paper, please insert paper & press O.K. But there is papar in the printer,in fact the paper is grabbed & pulled in about 1"
  • Anonymous Mar 16, 2009
    The same this happens. I try to print and it says I have no paper. I press ok and it tried to grab the paper but only does part way then says I have no paper once again.
  • Anonymous Mar 22, 2009
    I am having the same problem. No paper error comes up. I reload the paper ,press O>K> and the error message returns. Any solutions out there?
    Welcome Back:
    Visited the website for 2 consecutive days.
Canon PIXMA MP460 error code 5010
Posted on Sep 09, 2008
I have an error message in Canon IR 5020 "error E000004-0000.. how do I fix it?
Hi.
Power off CANON ir5020 then try to pull-out cartridge toner. check up paper feeder for paper garbage
cleaning using vacuum to get dust and small paper dirt.insert toner cartridge fix and power on again.
if same problem error display.your canon mainboard need repair.
Hope can help you.
Jun 28, 2011 | Canon Computers & Internet
I get an error message when I try to use the automatice paper feeder on top of the copier.
If I remember correctly, I had to replace the microswith in the ADF that resets the jams. It's located under the cover and the ADF has to be removed and taken apart to do it correctly. Hope this helps.
Jan 22, 2011 | Canon NP 7130 Black and White Copier
Mp460 feeds more than one pages
Hi ...
There is no hardware fault in this perticular situation. This happens because of paper loaded. There are 2 possible resolution to this problem:
I) Fan paper prior to inserting it into the MP460
  1. Remove paper from the ASF.
  2. Open the paper output tray. (See <2> in Figure 1 below.)
  3. Set the paper thickness lever according to the media being used. (See <3> in Figure 1 below.)
    Note: For paper thickness lever settings, use the following setings for the media type being used: Right side: Envelopes / T-Shirt transfers. Left side: All other media types.
    * Figure 1
    The illustration shows the PIXMA MP460
  4. Fan out the sheets of paper so that they do not stick together.
  5. Load paper in the auto sheet feeder with the paper's print side facing up. (See <1> in Figure 2 below.)
  6. Align paper to the right edge of the auto sheet feeder. (See <2> in Figure 2 below.)
  7. Pinch and slide the paper guide to the paper's left side. (See <3> in Figure 2 below.)
    * Figure 2
II) Load fewer sheets into the MP460
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon printer MP460
be sure that there is no jamed paper
be sure paper is all the way inside (make contact)
did you press reset after placing paper in?
Apr 21, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Cannon MP460 will feed paper through printer but not print
Check your printer sharing in the system preferences... make sure it's on.. then when you get the print window, look for your printer under shared printers... try it that way... worked for me on my wifi network here.
Mar 23, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Error message - re insert unit 1
GO ON LINE AND TYPE THE FOLLOWING:
CANON NP 6551 B/W RE INSERT UNIT 1
ENTER
WHAT IS CANON NP6551 B/W UNIT 1
ENTER
CANON NP 6551 B/W SERVICE MANUAL
ENTER
ROD
Feb 17, 2009 | Canon NP 6551 Black and White Copier
Paper pulling to one side
check the paper feeder if there are things blocking one side of paper loading.if so, remove it then try printing.
Jan 09, 2009 | Canon I960 InkJet Photo Printer
Canon pixma mp460 code error 6000
Solutions for error 6000 Issue: ERROR LCD: Error code (5xxx through 9xxx) appears on the display
1. Press ON/OFF switch to reset the multifunction device 2. Removing paper jams MP450 / MP460 3. The MP460 may require repair
heres the problems currently with mp460 and at bottom is the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13369
this is the solutions for the mp460
for the guest
clean out your ink absorber after unplug
reset printer you still have a little credit card sized paper in your printer that you need to remove it
May 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam issue
I finally fixed the problem by running two sheets of heavy card stock through at the same time.  With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on.  When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor.  I previously found that only one sheet at a time did't work.
Nov 26, 2007 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA  MP460 All-In-One InkJet Printer Logo
337 people viewed this question
old marine
old marine
