Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Samsung refrigerator rs 2534ww
On the front screen, temperature 72 , we change 36 but go back 72 again. also freezing temperate has same problems.
backside moter running sound is weak.
  • Limeh Sep 23, 2008
    I actually have a different model, but the exact same problem. It started when we had a blackout and lost electricity, and when it came back the refrigerator side never started cooling properly. It stayed on 20 (celsius), and the motor was hardly audible. No sign of cooling air through the vents.
Samsung freezer.
The freezer temp will not go back to the temp it was originally it keeps dropping back 15 degrees below to what i set it.
Posted on Nov 18, 2008
    Problem Solver:
  • 9 Answers
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Posted on Sep 06, 2008
Samsung refridgerator regularly beeps with power freeze switching on and off
Sounds like a faulty temperature sensor calling and not calling for the power freeze to come on. Change the sensor!
Jan 01, 2013 | Samsung Refrigerators
Vegetables freezing in lower trays
lower the temperature in the temperate control and then lower the humidity control vent to half open on the trays themselves.
the main reason is your temperate is to cold.
Dec 30, 2012 | LG LRTP1231W Top Freezer Refrigerator
Rs 265lbbp fridge is freezing everything fridge portion no ice on coils
This unit has a heater on the damper door. Sometimes the heaters go bad our just weak, causeing the damper door to freezer close. You can try thawing our damper by removing it to see if the issue happens again.
Aug 18, 2012 | Samsung RS265LBBP Side by Side...
Refrigerator is freezing everything and the freezer compartment is covered with ice. I tried changing temperatures but they go back to -12 for freezer and 36 for fridge. Any suggestions?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 02, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
How do I increase the refrigerator temp in a Samsung fridge RF267AE. The reccommeded temp is 38 however mine is currently at 36 and items in the back are freezing
you should only have to press the button up to change the temperatures, if that does not work the display board on the front will need to be replaced to fix the issue, let me know,
http://www.appliancerepairlesson.com/
Mar 07, 2011 | Samsung RF267AE (25.8 cu. ft.) Bottom...
Samsung rsg257 showing "of" on
I had this same problem. Per the manual, it's been changed to "store display mode". To cancel this mode, press the Power Freeze and Freezer buttons at the same time for 3 seconds until a "Ding-dong" sound is heard and the unit will cool. I tried it and it worked!
Dec 05, 2010 | Samsung Refrigerators
The display unit keeps flashing on the fridge side on my samsung RS20CCVS.
When the temperature indicator flashes indicate then the temperature has ridge a level lower the the set temperature for example if you set you fridge side to 36 degree and and has fail to stop from getting cooler and has ridge 34 degree. some times those friges fail to calibrate them self tray by unplugging you dirge for 30 seconds and replug it then the board will auto calibrate for the next 24 hours If this problem comes back again that meas than your defrost element on the fridge side is bad.
Dec 05, 2008 | Samsung RS2578BB Side by Side Refrigerator
Whirlpool Refrigerator ED22PQXDW01 temperature is all over the place in the refrigerator from 36-38 up to 52-54 degrees. it seems that the vent holes from the freezer gets ice crystals forming on it almost...
if it freezing it is not a freon gas problem...
Sounds like a defrost problem..
first to get it to work again.. take all the food out .. unplug it .. open the doors and wait 24 to 36 hours..clean up all the water .. then plug it back in .. it will work for 2 to 3 weeks until a repair man can come and repair it for you . or let me know and I can step you thru the repair... let me know...
Aug 30, 2008 | Whirlpool Refrigerators
Water leak
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
Aug 17, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
251 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
