Question about NEC MobilePro 900c Pocket PC
Word & Excel programs for NEC 900C
I am looking for a windows cd program that will allow me to edit word & excel files on my 900C. Also looking for a street map program with gps support for the 900C. Any recomendations?
    Master:
  • 903 Answers
Textmaker http://www.softmaker.de/ might help, I think they have an excel program as well, if not there is one around, you might look on Pocket PC magazines forum there are some 900 users over there.
Posted on Sep 15, 2005
SOURCE:
Size of the excel file increased from 721 KB to 50MB
Many businesses use Excel to track their data and expenses.
However, you can run into problems when files grow too big.
Try reducing the size of your Excel files in different ways to eliminate your storage problems.
Remove unnecessary graphics and fonts from the Excel file.
Simple report data doesn't need a lot of excess formatting to make it attractive.
If you need to keep different fonts in your file, reduce some of the font sizes you originally used.
Reduce the number of pivot tables you allow in your data analysis.
Run your pivot table wizard when dealing with involved calculations.
When given options to format the file, choose those that allow the data to refresh instead of adding a new table.
Input your data, close the file and save as an Excel (XLS format) file and as an HTML (XML format) file.
To do this, choose "XML Data" in the "Save as type" drop down box.
Change the name of your document as well, so you can tell the difference between the two files.
Open the XML file and save it back into the regular XLS file to create a smaller file than the original.
Again, rename this file, as well as changing its type. This act removes odd programming left from past calculations since the last "save."
Check into file compression software such as OzGrid.
These products exist because you cannot open a file once it gets too big.
Compress the XLS data by compelling the program to recalculate the cells used for your file.
Excel File Size Reduce Software 7.0
http://www.newfreedownloads.com/Business/Spreadsheets/Excel-File-Size-Reduce-Software.html
http://www.ozgrid.com/
or
Microsoft Excel files can contain thousands of cells filled with data.
When you combine this information with graphics, such as charts and graphs, as well as ever-expanding links to other worksheets, you can end up with an enormous file that takes up precious system space and slows Excel down.
While there are many software programs available that promise to shrink Excel files, there are many ways to reduce the bulk without downloading a new application.
1. Click on any cell in the Excel file you want to reduce.
Open the "Go To" dialog box in Excel 2007 by clicking the "Find" drop-down arrow on the Home tab of the ribbon and selecting "Go To."
In Excel 2003 or earlier, go to the "Edit" menu and select "Go To."
You can also use the keyboard shortcut "Ctrl+G" in any version of Excel.
2. Click the "Special" button on the "Go To" dialog box.
Select "Blanks" and click "OK." Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
In Excel 2003 or earlier, go to the "Edit" menu, point to "Clear" and select "All." This will clear any blank cells to help reduce the file size.
3. Go to the very last cell containing data in the Excel file.
Select the entire row beneath this cell by clicking the number to the left of it.
Hold "Ctrl+Shift" and then press the down arrow key to select all of the cells beneath this point.
4. Click the "Clear" drop-down in the "Editing" group in Excel 2007 and select "Clear All."
Select the column to the right of the last cell. Hold "Ctrl+Shift" and then press the right arrow key. Again, select "Clear All."
5. Repeat Steps 1 through 5 for any other Excel files that are linked to the workbook you are trying to reduce.
Save the files and then check the new file size by clicking the "Office Button" in Excel 2007.
Point to "Prepare" and then click on "Properties." In Excel 2003 or earlier, go to the "File" menu and select "Properties."
The file size will be listed on the "General" tab.
http://www.ozgrid.com/Excel/ExcelProblems.htm
Apr 22, 2013 | Microsoft Office Professional 2010
Tip
How to unlock a forgotten Excel xls password
Have you ever forgotten your Excel password for a workbook or sheet and then had a sinking face? Or has your workmate left your office and he(she) forgot to unlock an Excel workbook with a password set on it? What’s worse, you could not contact your former colleague. If you’re stuck with an XLS file with a password that you need to unlock or crack. What should you do?
Indeed, the protection feature of Microsoft Excel that allows users to lock a workbook or sheet with a password. When the Excel workbook/sheet is protected with a password, any user attempt to edit data shows an error message.
It was truly very often for us to meet the password problem. So when we forgot our secure excel password. Don’t feel confused. Actually there are a lot of methods available to recover or unlock the Excel password. But most of them are designed for PC experts, not common PC users, those solutions are too complicated to get it work for us. And in this article, I will show you a professional Excel Password Recovery tool which could help you to unlock forgotten Excel password easily.
Excel Password Recovery 5.0 is powerful password recovery software to recover forgotten Microsoft Excel passwords, enabling you to easily view the workbooks and sheets for the information. This Excel password recovery tool supports to recover password for Excel documents of all versions through 2007. In addition to the powerful attack modes of brute-force attack, brute-force with mask attack, and smart dictionary attack, this program is super easy to use with the straightforward user interfaces.
Below is the guide of how to unlock Excel password with this software, only 5 steps are needed to recover Microsoft Excel password:
Step 1: Download the setup file of Excel Password Recovery 5.0 on the official website: http://www.recoverlostpassword.com and install it.
Step 2:open the software,Click “Open” to browse the full path of the Excel into the program,Select your file in the Open File window and click “Open“.
Step 3: On the Recovery tab, select “Brute-force Attack (Trying All Possible Combinations)“.
Step 4: Click “Start” in the Menu to initial the program.
Step 5: The program is recovering the password. Once the password is found, it’ll be displayed in the File Opening Password Box. Click “Remove All Passwords from the File” to remove both the Password to Open and Password to Edit. Click “OK“. Use the password provided to open the Excel file and view the information.
Tips:
If you have any questions of the procedure and the settings, you could visit the website: http://www.recoverlostpassword.com
If you need to crack an Windows or Office suit password, you should check out Windows Password Recovery 6.0 and Office Password Recovery 5.0 from the same company. It supports all office products including Word, Excel, Access, .etc .It also supports multilingual passwords.
on Jun 30, 2010 | Computers & Internet
Reduce the size of excel file
or
Apr 22, 2013 | Microsoft Office Computers & Internet
How do I unlock an excel spreadsheet which has password protection (lost). I am using Mac Excel not Windows
A) Open document > Select edit menu > choose select all > then choose copy from edit menu.
Open new document > edit menu> paste.
Select tools menu> choose options> window opens with options. Select form different tabs the edit tab> make sure that al desired boxes are selected.
Select save tab>choose and mark box>ask about properties
accept or Apply options and close.
Save new document different name. When saving it should ask if you want to save properties> choose not save. Maybe it asks if you want to modify properties> choose yes> select box archive amongst read only, hidden or archive.
If this does not work.
B)There are many 3rd party utilities which claim to reset forgotten word password:
The program that I recommend is the Excel Password Recovery 5.0 It recovers/removes the "Password to Open" and "Password to Edit" for you to view and edit the document freely.
http://www.recoverlostpassword.com/products/excelpasswordrecovery.html
May 06, 2010 | Microsoft EXCEL MAC UPGRADE 2008 Upgrade...
My excel sheet is not opening
assuming you have Excel sw on your PC.
Assuming you are running XP.
Assuming you can start your Excel and Open any excel file using File/Open within excel.
You must associate Excel file with Excel program in your Windows Explorer.
Fastest way is Browse to any excel file with your Windows explorer (NOT IE)
Right click and select Open with...
Browse to find your Excel MSOffice program
Select Use always to use this program
OK
Dec 28, 2008 | Microsoft Excel 2003 (06503995)
Word & Excel won't open files when doubleclicked in Windows Explorer
Excel may have "Ignore other applications" selected. See THIS Microsoft Knowledgebase Article.
Try going to Excel Options; Advanced tab; and under the 'General' heading: uncheck the box that says: Ignore other Applications that use Dynamic Data Exchange (DDE).
Dec 02, 2008 | Microsoft Office Home and Student 2007...
reinstall - there must be administrator issues on your computer.
Oct 29, 2008 | Microsoft Office 2003 Basic Edition...
NEC Mobilepro 900c will not connect w/computer
Are you using the NEC Mobilepro 900c drivers? I'm sure the drivers are different. YOu can find the XP drivers here: http://hpcmonex.net/nec900/files/soft/nec/activesyncusb.zip In addition, you should make sure that you have Activesync 3.8 or older. You can find it here: http://www.hpcfactor.com/ftp-root/software/microsoft/activesync/activesync-38/MSASYNC.EXE
Dec 25, 2007 | NEC MobilePro 900c Pocket PC
Upgrade from reader to full function
Yup, softmaker company release a version like word,excel
Sep 21, 2007 | NEC MobilePro 900c Pocket PC
Open Questions:
I WAS TRYING TO INSTALL JLIME ON MY MOBILEPRO 900, EVERYTHING WAS DONE AS PER THE DOCUMENTATION AS PER THE WEBSITE. AFTER ALL THE STRESS OF PARITIONING THE FLASH CARD.. I GOT THE FOLLOWING ERROR.. "ROOT=/DEV/HDA2" NOT found kernel Panic VFS cannot mount I dont understand a bit of this error.. i ahve tried all the zImage files on the website.. but still I am getting the same error. I used the Henchman.tar--------( All the versions avaliable on website" Haret.exe as kernel Bootloader file which read as below # boot a kernel with HaRET # # have the kernel zImage and the Haret executable in the same dir as this file # this file if named 'startup.txt' will automatically launch the kernel when you start Haret # # 'set MTYPE 659' is for the NEC MobilePro900c # # in CMDLINE change 'root=' to point to the location of your root filesystem # eg 'root=/dev/hda1' is the first partition on your CF card # and 'root=/dev/hda2' is the second partition # set KERNEL zImage-2.6.23mp900c set MTYPE 659 set CMDLINE "console=tty0 console=ttyS0,115200n8 root=/dev/hda2" bootlinux i have tried mentioning "hda1" , "sda1","sdb1","sdb2" I believe its not the problem with the Henchman file or is it??? I have the following partitions sdb1 as boot flag which is fat-1GB sdb2 which is of ext2-2GB sdb3 as SWAP-1GB i loaded the boot files in the Fat ie the Haret.exe Zimage and startup.txt file in fat system Please help me out in removing this error and getting Jlime installed in My Nec Mobilepro 900.. I used a transend 4GB flash drive
Jul 16, 2011 | NEC MobilePro 900c Pocket PC
NEC MobilePro 900c Pocket PC Logo
289 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Thomas F. Schneider
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
