Question about Symantec Winfax Pro 10.03 (winfax10.03) for PC
Rate of Transmission
Hi Guys,
I'm using Winfax Pro 10.03 to send some marketing stuff (3 files total of 750KB) to 900+ fax numbers over a 56K modem. How long will it take me to finish it? Is there a way i can speed it up?
Please advise the soonest.
Thanks and Regards,
TJ H Lopez de Leon
  • 477 Answers
Hello no you cant speed it up in any way and 750KB should take in theory about 2minutes but in practise from 2 - 5 minutes.
Posted on Sep 04, 2008
I have a BSNL boardband connection, can you tell me how can I configured?
The internet connection that you use doesn't matter with WinFax, since WinFax requires a fax modem to send and receive faxes. You cannotuse your broadband modem to send receive faxes with WinFax PRO. http://www.getfaxing.com/forums
Dec 10, 2010 | Symantec WinFax Pro 10.0 for PC
Winfax Basic
If you have the fax # correct, than it is the responsibility of the fax recipient to correct the situation. You cannot make a parametrical changes to someone elses fax machine. Thank you, Dana
Jan 18, 2010 | Symantec WinFax Pro for PC
I give up. I have winfax software on this machine, but I am new at the job. Please can you help me link my fax to the winfax software? I am not able to send faxes as I think you actually have to be...
You need to setup a fax modem to be able to send and receive faxes with WinFax.
In WinFax, click on Tools, Setup.
Click on Modems & Communications Devices.
Here you can configure your fax device.
You need a fax modem, a DSL modem or a cable modem is not a fax modem.
I suggest you read this:
http://www.getfaxing.com/winfax/2009/06/25/first-time-guide-to-winfax-pro/
Jun 29, 2009 | Symantec Computers & Internet
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
Slow Fax Transmissions with USR V92 External fax modem
Its possible you've set your faxes to send in FINE resolution (200 dpi), I am not sure about MS Fax, but in WinFax you can select both Standard Resolution and Fine resolution as the default for sending faxes.
Jan 14, 2009 | 3Com U.S. Robotics Faxmodem 56K
Configuratin of Winfax pro
You need a fax modem. If you only have internet connection, you will not be able to send or receive faxes unless you subscribe to an internet fax service called www concordfax.com
Jan 12, 2009 | Symantec Winfax Pro 10.03 (winfax10.03)...
Broadcast Fax Sending
Change the resolution to STANDARD. This will cut your send times by 50%
Sep 06, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
I can't send to certain fax machines with WinFax Pro
Yes, some modems might have problems with Service Pack 3. You might need to update the Windows modem drivers.
Alternatively, there might be problems with the settings in WinFax for your specific modem.
You'll need to post more information on the fax modem you are using.
Jul 28, 2008 | Symantec WinFax Pro for PC
Unable to fax out
usually confilcts arrise like this when 2 or more type connections are present on one comp especially if not integrated on same card together.
solution: disable nic reboot pc then send fax should go alright.
though if you have call waiting you should disable it before sending any fax.  try using WINFAX  proven technology.
Oct 13, 2007 | Genica Conexant R6793-11 56K V.92 Data/Fax...
Winfax pro problem
This is a solution that was suggested for an earlier edition of the Winfax Pro, but there is no reason why it shouldn?t work on this one as well: 1. Close Winfax and any other program that has anything to do with it, delete all the temp files that yo don?t need. 2. Run Scandisk and fix any problems that may come up. 3. Run delfix.exe which is located in the winfax folder in the status files. 4. Run delfix-rebuild and delfix-optimize and check if the problem is solved. If the problem reoccurs there is another possibility- to change the name of the WinFax\data folder and create a new one which you will transfer the address book file, status files etc. from the old folder. Note that there might be some information that wouldn?t go through.
Feb 22, 2006 | Symantec WinFax Pro for PC
Symantec Winfax Pro 10.03 (winfax10.03) for PC Logo
48 people viewed this question
Top Symantec Computers & Internet Experts
Tony
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
