Question about Whirlpool GD5SHAX Side by Side Refrigerator
Ice maker is freezing up
The water tube that carries water into the automatic ice maker keeps freezing solid. I get my blow dryer and thaw out the ice and the ice maker will work for a few days then it will freeze again.
  • 2 more comments
  • Dawn Lauffer
    Dawn Lauffer Oct 27, 2008
    MY AMANA FREEZER KEEPS FREZZING UP ON THE ICE MAKER ! HELP!
  • heathhouse08 Nov 12, 2008
    I have the same problem. I thaw it out and sometimes it will work fine for two or three weeks and then the tube that delivers the waters freezes up again. I just thaw it out with the hair dryer and start over again. Puzzled :>(
  • Anonymous Jan 15, 2009
    3 year old side by side. Supply tube froze up, I thawed it out, it worked for a week and now it is not working at all. Not froze up this time, just not working. I pulled the unit out to see if I could have a repair place test the unit. They said they couldn't test it?? After additional discussion they said it could be the valve that supplies the water. I haven't pulled out the fridge to look at that yet.
  • Anonymous Mar 14, 2014
    ice maker freezing up
    Genius:
  • 1,198 Answers
The solenoid valve can leak slightly to make your problem. To check it, undo the tube from the solenoid to the freezer with the solenoid unplugged, and the water pressure on. Any leakage is bad, replace it.
Posted on Jan 24, 2009
I have an Amana SD125F-L refrig-freezer. The rubber tube which carries water from inside the freezer wall to the ice maker tray frequently freezes solid with ice. After thawing with a hair dryer, it...
Hi Jan, the problem is a bad ice maker water valve. Pull the refrigerator out and look for the plastic water line that's going to the tube that's freezing. Follow that tube to the faulty water valve. The problem is, its leaking water slowly to the ice maker and it freezes up . Easy fix : Good luck
Appliance Repair Tucson, AZ
Refrigerator Repair service 520-888-7039
Aug 15, 2013 | Amana Refrigerators
The water feed to the ice maker is frozen - I can see that it is plugged with frozen water. I was able to get the frozen water out of the chute that leads to the ice maker but I can still see the ice...
This usually means the water inlet valve that feeds the ice maker is bad. It can bypass a small amount of water and that water runs so slow that it freezes in the tube you are clearing.
The valve I am talking about is behind the frig on the bottom, it should be blue in color.
To clear the ice from the tube use hot water and a turkey baster, or a hair dryer.
The part number for the water valve is 4389177
Aug 01, 2010 | Kenmore Refrigerators
Ice maker waterline frozen
Occasionally these freeze up on many brands. Usually if the ice maker is not used much. There is a rubber tube that deposits water into the ice maker unit, Thaw it by warming it with your fingers. You can carefully use a hair dryer as well
Jan 15, 2010 | GE Refrigerators
The line to our ice maker is frozen solid with ice. Do you know how to get the ice out of it? I'd prefer to not have to defrost the whole thing.
Pull the refrig out from the wall and you will see where the single tube to the ice maker goes . Try removing the line housing straight out the back , and thawing at the sink . Or , 2 screws hold the ice maker on . Remove the ice maker and thaw the line with a hair dryer . You will need to replace the water valve ( the piece the wall water line connects to on the refrig ) due to a seeping problem . When the valve does not close completely , drops will seep into the fill tube and freeze , thereby , blocking the normal rate of water , entering the ice maker .
Nov 11, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The water filling the ice maker freezes in the filling tube.
You can thaw the frozen water with a hair dryer but to stop this from happening the water control valve may be the reason for this to happen. When the ice maker calls for water to refill it is timed. If the water control valve located on the rear of your refrigerator is not closing all the way for the ice maker side it causes the water to freeze in the tube because it slowly flow to the ice make just enough to seal the fill tube.
Thanks and let me know what you find, Sea Breeze
Oct 12, 2009 | GE Refrigerators
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
WATER FREEZING IN ICE MAKER
check 2 things. Make sure the fill tube is going downwards to the cup inside. The second thing is when the valve shuts off make sure it closes right away. If it doesnt then replace the valve.
Jun 18, 2009 | U-Line BI-95
WATER RUNS DOWN FREEZER WALL
SRCTE,  Are you certain that you installed a NEW water valve?  To isolate the problem between the ice maker and the water valve.  Remove the ice maker from the refrigerator.  Inspect the water fill tube for being stopped up with solid ice.  If so, clear the solid ice with a hair dryer blowing hot air into the end of the water fill tube.  Insert a long screw driver into the end of the water fill tube to break loose any remaining solid ice up in the tube.  Inspect with a flash lite to verify the water fill tube is clear and open.  Leave the ice maker out of the refrigerator overnite and operate the refrigerator as normally used.  After 6-8 hours, open the freezer door and inspect the end of the water fill tube; if the water fill tube is clear of solid ice then you have a bad ice maker which must be replaced.  If on the other hand the water fill tube has ice protruding from the water fill tube then the water valve is defected and must be replaced again.  If the water valve is replaced you may desire to install an external in line water filter. Hope this helps you.  Henry
Feb 06, 2009 | Refrigerators
Jenn air side by side refrigerator ice maker not working
On mine the water inlet feed tube would freeze solid. Removing the ice tray and using a hair dryer to completely thaw the tube would get it working for another month or so. My frig had a solid rubber inlet tube. I noticed at the appliance store that newer models had an inlet tube that was split on top. I got one of these from a local appliance parts store, and it fixed the problem. The tube replacement it easy. Get to the back of the frig. Turn off the water supply. Carefully pry the white plastic piece out ( located on the upper right side when facing the back of the frig. ) of the frig. When you have the new one in hand it will be clear what you are going to do. Pull out the old remove the water line. Attach the line to the new tube and insert it. Turn on water, check for leaks, and you should be ok. This repair is only effective if you have an inlet tube that freezes up. There can be many other malfunctions that stop ice makers from working. This was my problem. Replaced the tube 3 years ago and ice maker has worked fine since the replacement.
Nov 16, 2008 | Jenn-Air JCD2389G Side by Side...
Ice maker
IS YOUR FREEZER COOLING TO O.F
Jun 15, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool GD5SHAX Side by Side Refrigerator Logo
289 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
