Question about Kenmore 24032\24036 Top Load Washer
Kenmore 22924 top load
Hi< I just had a technition come to fix my washer and he wanted to charge me 360 which i could get a new one....He was going to replace the timer with parts costing 188.
The washing machine agitates and fills with water at the same time. Does the timmer seem to be the problem or could it be something else. Would like to try and get the part and fix myself. Thank you
    Genius:
  • 1,028 Answers
Timer most likely suspect ..not sure of timer cost sears price usually 110-160 may find local parts place with cheaper price for part number remove console end caps remove screws underneath roll console up and back number on timer beside fsp or just go to sears.com click on parts link type in washer model # look for timer
Posted on Sep 05, 2008
Need to bypass lid lock Kenmore 2002 white red blue yellow which ones
Kenmore Whirlpool top load washer. lid lock issues - YouTube
? 3:34
https://www.youtube.com/watch?v=Vf1hVhpC8yE
Mar 12, 2013 - Uploaded by EurekaRecycler
Kenmore Whirlpool top load washer. lid lock issues ... The new one I bought or actually have a loan on the EXACT issue and I've only had it 3 ... cheap way to bypass the lid lock which is irritating, aggravating, frustrating on my ...
Kenmore Lid Safety Switch ( Temporarily Fix ) - YouTube
? 13:17
https://www.youtube.com/watch?v=UMlLqEF8EGM
May 20, 2012 - Uploaded by matttherepairman
This is a easy way to bypass a lid safety switch with-out cutting into the wire! Did your Kenmore Washer machine fill up and stop ? Your Lid ... +Jerry Munroe That is correct,,, You will not need to cut any wires Thank you for watching .... Kenmore Whirlpool top load washer. lid lock issues - Duration: 3:34. by ...
how can I disable the lock on my new top load Kenmore ...
www.shopyourway.com > Manage My Life > Questions
Jan 08, 2016 | Kenmore Washing Machines
Hi, our kenmore HE topload washer was making a loud noise then it stopped and not working now. What was the cause? Any solution? Is it worth fixing it? Your suggestion is greatly appreciated. Thanks
Hello
Loud noise in a top load washer is usually caused by the bearings going bad however, it really depends on the model# what part# needs replacement. Worth fixing-depends on the age of your washer...you know if its more then 10yrs old and repair will cost you more then 50% of its original cost then you can think what you want to do. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Kenmore HE2 Plus Front Load Washer
How do i get the top off a 22924 kenmore to re-attach the lid sensor. It has come unscrewed. My wife said the last guy re-attached with service call for $150.00
You have to remove the exterior washer case on Kenmore top loaders. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
It's not as difficult as it seems. A very simple process if you follow the steps provided. If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Kenmore is manufactured by Whirlpool, so these instructions do apply.
Feb 25, 2010 | Kenmore 24032\24036 Top Load Washer
Timer only works on heavy cycle not on normal model #11024632300
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
Feb 14, 2010 | Kenmore 24632 Top Load Washer
F1 CODE
http://forum.appliancepartspros.com/washer-repair/7591-kenmore-oasis-f1-code.html try this but I'm sorry to say you will probley need a new computer I had to with my stove pay for the guy to come out then more money for a new computer for the stove, not the answer you wanted but most likely is whats going to have to be done sorry and hope this helps
Jul 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore 80 Series top loading washer--will not stop filling with water at the beginning of the wash cycle and for the rinse cyle. Is there an easy fix or should I purchase a new washer? How much can I
The pressure switch is failed - remove the tube from inside the top console area and blow it out. If you're lucky it will again work - with no charge.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 31, 2009 | Kenmore Washing Machines
Roper top load washing machine that won't aggitate
Hi, It is most likley that the coupler is bad. The coupler connects the motor to the transmission. If the motor runs and you get neither spin or agitate, this is the most common problem. If this is something you want to try and fix, you can go to 222.whirlpoolsurplusparts.com and there I have a detailed article on how to change the coupler.
I hope this helps you. If I can assist you further, please let me know.
Thanks,
Vic
May 11, 2009 | Kenmore 23822 Top Load Washer
Kenmore Elite Oasis
You want to charge me to get answers from you but you want me to tell you my fix for free???!!! I don’t think so!!!
Aug 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 22062 top load washer
I have the same problem I posted on Bob Villa fix it website If I get an answer I will post it for you. Let me know if you found a fix.
Mllong9163
Jul 19, 2008 | Kenmore 22062 Top Load Washer
Kenmore oasis 15 months old
hi over here in the uk we have home insurance if you have the same thing maybe it's worth looking to see if you can claim on that rather than spending more money on a new machine.
Mar 06, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
121 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
