Question about Sony Cyber-Shot DSC-M1 Digital Camera
File size on DSC-M1
I got the setting at fine and 5mp and am getting 3-4mb files. Is that the max? I thought a 5mp camera would produce files that were larger. Sony need to have a non-jpeg setting.
    Master:
  • 551 Answers
The files are compressed. A typical 5mp file should be around 2.5 Mb in size. A 7mp camera produces a file of abot 3.5 Mb.
Posted on Sep 15, 2005
Hello, My camera had been taking photos under a file size of 1 MB, normally 800 KB. Today for some inexplicable reason (I must have done something!), the photo file size is 4MB, too large to send and use...
On your camera, look for settings. You must have set it on "Large" or "Max" picture quality. Thus making your 'normal' 800kb into a more better quality.
On your laptop/computer try to open it in a image editor and change the resolution of the picture.
Dec 14, 2010 | Sony Cybershot DSC-T200 Digital Camera
I have a sony dsc t20 I lost the manual and now I don't know how to set the camera to take pictures at the max image size 3264 x 2176 (3:2), how to set it,please explain in steps if possible
Under menu items - look for Image Size, that set the size of image - nothing in manual on Pixels - I would set to FINE and 8MB that would be the MAX size of image. From the Cyber-shot® Handbook link on page 10 - it says the 8MB setting is for 3264x2448 - I cant see how to change the aspect ratio to get the 3:2 for 3264x2176
Apr 11, 2010 | Sony Cybershot DSC-T20 8.1 MP Digital...
Enlarging file size of pictures
That camera shoots at 7.2Megapixels at max resolution, that should print an 8.5x11 without any issue.
Check the settings on the camera to make sure that you've got it set to take "high" resolution, and not "low".
In the settings, there should be a resolution option that you can change. It's likely set to take lower resolution that what the camera can actually handle.
Mar 19, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Picture file size help
Select Picture quality as "Fine" in camera menu to get big n best picture file.
Jun 12, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Size of JPEG file produced by this camera
the general rule is a jpeg is halve the mb of the resolution-6 mp =3mb file size-kodak uses a ton of compression and this is the main reason why-put a memory card in a kodak and you pick up about 20-30% more capacity than other brands!
Apr 06, 2008 | Kodak EasyShare C663 Digital Camera
DSC T20 poor image problem
If you took the images at 8MP or 5MP settings, then normally you have a high resolution picture, was the picture clear at the cameras LCD monitor? As you said its like low res in your PC, please check the image file size 8MP resolution will be approx. 3Mb size, if its about that figure, then the problem is in the camera, if the file size is about 500K maybe its in the camera settings, PC cant affect resolution, unless you only have VGA card and monitor, hope this will help, thanks
Sep 12, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Image Quality decrease
Um ok. first off, chill with the images being described in inches. The DSC-S40 is way too simple to get lost with. You only have 2 options to play with. One is the resolution which you want to be as high as possible unless you have some special reason for it not to be. Two is you have 2 image quality settings to choose from(Fine and Standard). choose "fine" of course for best results. yes the files size will be a bit larger, but you get the best possible image. Remeber, this is considered a cheap camera, so you want the most it can offer.
Now about the file size anomalies. Dont worry about it. Here is the only conclusion I can come up with that sounds logical. .JPG and most "compressed" image types will never be the same size if taken from a camera unless the same exact picture is shot 2 times in a row very fast witout the camera moving. files size on a compressed image depends on the amount of color variations the camera has to render into a file. The more color variations, the more data the .JPG file contains. It is natural for file sizes from a camera to differ. If you set your camera at 4M and take a picture, and then you set it to 3M and try to take the same picture again thinking it will save space, in theory this is true, but remeber how "compressed" images are rendered. You may have had only the slightest difference of light change on the next pitcture you took . This can have a significant impact on the file size, and can result in a lower res image being bigger in file size than the higher res image. Now, if you are talking a huge difference like 3M@1500kb yet 4M gives you 500kb, then you either have it set to "standard" quality, or you are really lost in this stuff.
But anyway, I hope this is plenty of info. And makes plenty of sense to anyone who understands compressed images.
Sep 04, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-M1 (or MPEG4) playback on TV
Hello, You spoke about burning a DVD. Have you tried connecting directly your M1's TV out (yellow jack) to your TV set? If the quality level is same in direct connection using the MS as original carrier as with the DVD then "ite missa est", otherwise there is an issue with the DVD burning like reencoding of mpeg4 into mpeg2, maybe some quality parameters to tweek in a remote menu....
Sep 15, 2005 | Sony Cyber-Shot DSC-M1 Digital Camera
DSC-F717 mp Question?
do you mean your files are around 2 mb (megabytes) in size? megabytes and megapixels are not the same thing..megapixelspixels=resolution and megabytes=file size..5MP pictures are around 2MB in size..
Sep 12, 2005 | Sony Cyber-Shot DSC-F717 Digital Camera
Sony Cyber-Shot DSC-M1 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
