Question about Sharp Office Equipment & Supplies
Sharp Model FO-4700 Facsimile, when powering up, message appears ' Please Wait A Moment ' and that message stays on constantly, no matter what key is pressed. No key tone, and same message comes on even after plugging and unplugging power to machine ??
  • mod0505ya Sep 05, 2008
    Turning the power on and off does not correct the problem. There is no change no matter what button is pressed. There is no phone line plugged into this FO-5700. It is only used as a copy machine. The 'Please Wait a Moment ' will stay on for hours. Did remove and replace toner and drum cartridge, did remove and replace the paper feeder tray. This machine had worked properly, with never an error message, previous to this. Thanks
  • Anonymous Mar 21, 2014
    when i try to photocopy document using Sharp facsimile machines fo-77, the copied document become full black.
    Sergeant:
  • 336 Answers
I am unsure if this will help, but I have the owners manual at this web address and if you look in troubleshooting your problem may be there.
RCF
http://dl.owneriq.net/1/16e35fda-9c8f-4230-9822-5009063ff537.pdf
Posted on Sep 05, 2008
    Genius:
  • 1,056 Answers
Since it will not come out of the "Please Wait" mode, that's telling me that it is failing to initialize.
In other words the controller board refuses to progress through normal stat up procedure. Now it could be that a sequencer board has failed, or the controller board has failed. In either case, my first recommendation would have been to power off, and power on. Since you have done that (I'm assuming repeatedly) it is time for a little more drastic matters.
Depending on the age of the machine, this would come under a warranty repair. If it is past warranty, well...next option.
If you have a service contract on it, contact the people that service it.
If you don't, I would contact a local company that does service Sharps, and ask them what they charge for a service call.
Last choice (and this one is always a little rought to take) how old is the machine, and how much did you pay for it, vs. replacing the machine.
  • 6,487 Answers
If a beep sound is not made when you press the keys, turn off the power switch and then turn it on again after 5 minutes.
Hope that helps.........
  • Mark Gil
    Mark Gil Sep 05, 2008
    If you unplug the fax for about 2-4 hours and still the same result, better contact Sharp or take this machine to a service center to diagnose and fix this...
    Genius:
  • 1,847 Answers
Unpluge the scanner and pluge back reset the scanner setting to default factory setting then try.
  • Legin Varghese
    Legin Varghese Sep 05, 2008
    There may be a button on your console that says 'memory' or
    "memory status". pressing this key should erase any documents in the memory.
    if none of this works turn it off and leave it off overnight, if in the morning when you turn it back on the memory should have been cleared....dont turn it off at the machine turn it off at the wall socket so the machine thinks there is a power failure...this should make the machine print out a status report when you turn it back on.
    good luck
I am using sharp facsimile model FO-P610 for the past two years.Recently,the machine gives problem of noisy noise from ear piece each time I want to make speaker on dial.I have checked with Telecom...
In 45 years I havenever seen a bad fax modem.....it's a noisy phone line problem.
I would take the fax machine to a different location and try with a different phone number.
Mar 21, 2010 | Sharp Office Equipment & Supplies
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp fo 4700 display error ( polygon )
You have a bad printhead unit(laser unit) . The polygon mirror is not rotating within a specific amount of time. I recommend you to replace your fax unless your willing to spend between 200 to 500 dollars.
May 03, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Sharp fax model fo 2950m
There are two ways to fix your problem. First open your cover, then press the small white rounded reset button in the lower frame. The second method - unplug your fax, then hold down the stop and start key while pluging in the fax. When you see memory clear on the screen let go of the stop and start key. I believe the screen will say 1 for yes 2 for no for memory clear, press 1. The second method will ERASE every thing in memory that includes program #'s and transaction report setting.
Jan 28, 2009 | Sharp FO 2950M Plain Paper Laser Fax
Sharp FO DC535 fax will not come to ready
Turn on the fax while holding down the stop a start key, don't let go until you see 1 =all ,2=image , 3=none. Press 2 for image. If the problem persist press 1 for all.
Dec 29, 2008 | Sharp FO-DC535 Fax
Sharp UX-117 display Wait a moment on power on and then no signal
I have not worked on a sharp ux-117 before, however most sharp fax machines are all alike when it comes to resetting this code. Turn the fax on while holding down the stop and start key don't let go until you see 1 =yes, 2=no for memory clear. press 1=yes. Some of the sharp fax machines have a small white rounded reset button. No guarantee but you have nothing to lose.
Dec 03, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp FO 5700 - Please Wait For A Moment message
Hold down the stop and start key while turning on the fax, let go when you see 1 for yes 2 for no for memory clear. Press 1.
Sep 08, 2008 | Sharp FO 5700 Plain Paper Laser Fax
Sharp wizard oz-730
Hi, I has this problem but I found in the user manual this instructions and works ok: 1. Press and hold the Start key.
2. While holding down the Start key, push the RESET button
on the bottom of the Organizer using a pen or some other
pointed object. The following message will appear.
"Do you really want to initialize the organizer's memory (this will delete all data)? Yes:[ENTER/No:[ESC]
3. Press to initialize the Organizer.
The message .Working... Please wait.. appears while the
Organizer proceeds with the initialization procedure.
The Welcome message then appears.
Oct 10, 2007 | Sharp Wizard OZ-730
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
