Question about Sony Cyber-Shot DSC-W1 Digital Camera
W1 Making noises....??
I have just noticed my W1 making a clicking noise. It seems to see when the camera is in the Green automatic mode. The noise seems to be the apeture switching between the two settings it has. Why is it making noise when switching between the two appetures? James
    Master:
  • 551 Answers
The W1 uses metal rings that slide in place with a tiny hole in the middle to give the required apperture it does not have a diaphram that closes and opens to give the apperture... so what you here is the sound of changing the suitable ring ( or disc) with the apperture ... You can look in the camera (lens side) and change appertures, you should be able to see this happen ... don't click with flash though :) The sound is very low though if you here a loud click there's something wrong.
Posted on Sep 15, 2005
VW Golf 2007 1.9TDI, I was recently in a accident approx 20mph, and crashed head on into a turning car. What is making the kinda rattling/clicking noise, more noticeable during gear changes.
This could be almost anything from loose trim to broken body parts, you should get the car checked by bodyshop to make sure that it is safe to drive
Jan 13, 2016 | Cars & Trucks
Blurry pictures and beeping noises
It could be the lens is damaged on the inside (Gears and so).
But before you make any conclusion. try to switch the camera to auto mode and make sure the camera is not in the macro mode.
To start, switch of the camera, remove the batty and leave it out several seconds. perhaps you also should charge the battery on an external charger,but if you are sure it is charged, after a few moment reinsert the battery. Then switch the camera to the automatic mode and check if it is not in Macro. (when you see the flower on the screen it is in macro)
If it is still acting the same you made the right conclusion in the question above. (I hope you are wrong but if not, you start looking for another camera)
Jan 26, 2014 | GE J1470S Digital Camera
1996 Chevy 1500 automatic making clicking noise in first gear
yes could be a bad fly wheel. we have had them on our 1996 van and it is exactly as you describe. you do not hear it revving the engine. you will need to get under the truck . remove inspection cover for trans. look very carefully with a flashlight for reflections from the cracks in the flywheel. we tried to pry ours and it did not move. but we saw it with the flashlight both times. 2 flywheels were made one with ovals and one with circles. the oval ones always go bad. do not buy an aoval replacement
Jan 02, 2010 | 1996 Chevrolet K1500
Nikkor 70-300 f/ 4.5-5.6 AF noise followed by "click"
Well most AF mode do make a noise of some sort because its trying to adjust for a clear shot. I've played with several cameras and their features and notice this is a common thing, its usually the camera. But if your really worried about it and it does bother you, just take it in for a service. Maybe because of you dropping it several times, the noise is more louder now.
Sep 08, 2009 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
Sensor Cleaner making noises?? (Nikon D300)
Yes, all D300 makes this noise when the sensor is being cleaned.
Apr 24, 2008 | Nikon D300 Body Only Digital Camera
Sony cyber shot DSC-W1 Digital Camera
I found an online manual for your camera. Page 84 talks about the USB Mode Normal with the 4 dots underneath. It also show a troubleshooting area for this and it is on page 96. Hopefully this will get your camera working right again. Here is the link to the pdf manual. http://www.docs.sony.com/release/DSCW1.pdf
Aug 25, 2007 | Sony Cyber-Shot DSC-W1 Digital Camera
Soft clicking-grinding noise
i think that you have the full-time auto focus on.
go into the menu and turn it of and all should be fine.
seekreep from Edinburgh - Scotland.
Jun 10, 2007 | Olympus C-7000 Zoom Digital Camera
W1 Sharpening
I think I read somewhere that pictures came out too soft and therefore sharpness should be set to +. You need to use an image viewing application that can show the photo's EXIF data.
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
What are defect pixels?
Ocassionally images from digital cameras will have "defect" pixels. These pixels may appear in the final photograph as bright white, green or red spots that are out of place when compared to the rest of the image. Sometimes people call these spots "hot" or "dead" pixels. Usually these pixels, and other types of "digital noise" appear in the darker or underexposed parts of images; additionally, images taken at longer exposure times are much more likely to have this issue. Many Nikon cameras have a "noise reduction" or "NR" process that fixes these problem areas. When NR is activated and image exposure times drop below 1/4 of a second the NR automatically processes the images as they are saved. This Noise Reduction feature is sometimes called "Night Portrait" or "Night Landscape" Scene Modes. If these spots are seen on images photographed under normal conditions (bright light with exposure times shorter than 1/4 second) then the camera may need to be sent in to a Nikon Service Center for repair. Notice the green defect pixel near the center of this image.
Aug 30, 2005 | Nikon Coolpix 3200 Digital Camera
Ocassionally images from digital cameras will have "defect" pixels. These pixels may appear in the final photograph as bright white, green or red spots that are out of place when compared to the rest of the image. Sometimes people call these spots "hot" or "dead" pixels. Notice the green defect pixel near the center of this image. Usually these pixels, and other types of "digital noise" appear in the darker or underexposed parts of images; additionally, images taken at longer exposure times are much more likely to have this issue. Many Nikon cameras have a "noise reduction" or "NR" process that fixes these problem areas. When NR is activated and image exposure times drop below 1/4 of a second the NR automatically processes the images as they are saved. This Noise Reduction feature is sometimes called "Night Portrait" or "Night Landscape" Scene Modes. If these spots are seen on images photographed under normal conditions (bright light with exposure times shorter than 1/4 second) then the camera may need to be sent in to a Nikon Service Center for repair.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Sony Cyber-Shot DSC-W1 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
