Question about Sony RDR-GX300 DVD Recorder
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on my laptop, the DVD will not play (disc error shows up). It appears like the DVD burned on this unit only works on this unit only. Please help me to solve the problem. Thanks.
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Posted on Aug 11, 2011
SOURCE:
When attempting to record on a new blank dvd (-R), I receive an error code c1300 for a dirty disc. I have cleaned several discs and all stop after a minute or so, followed by the message dirty disc with...
the burn laser is dirty clean it using a laser disc cleaner avaliable from all good electronics shops that sell tv and audio decks hers a picture of what they look like
Dec 28, 2010 | Sony RDR-GX300 DVD Recorder
I have an rdr-gx380 recorder that wont play back some burned dvd movies why
i want buy for fixing my CCTV....
RDR GX380 have any problume to do this?
Mar 13, 2010 | Sony RDR-GX300 DVD Recorder
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
HOW DO YOU BURN A DVD ON A SONY DVD RECORDER RDR
Make sure your Sony input signal is on L1 or L3 (the inputs in back of recorder) or on L2 which is for inputs for cameras(located in front).Once you get a signal, you're where you need to be. Choose your recording mode for recording speed (pull down the flap on the remote control for this button and also the input button).
Choose from between1 hour and six hours. To archive really important stuff, stick with the first 3 speeds. TV recording can be on 3, 4 or 6 hour mode.
Push the record/pause button once. This will put the recorder into the record/pause mode and then it awaits you pushing it again to start recording immediately. Just pushing record will force the machine into a 3 to five second delay before actually recording anything so you might mess up and miss the first few seconds of your input. Suggest you use a dvr-rw or dvd+rw to practice on.
When your recording is done, just push the pause again. It stops recording but allows you to add more on to the first recording without starting a new chapter if you want. Just continue to release the pause button to continue.
If you are satisfied that you are finished, then push the pause button to stop recording. Wait for the info to be written(flashing message on screen). When it stops, you may play the dvd.
Notice- since the dvd has not been FINALIZED, you may only play it back on this unit without finalizing. It will not play on other dvd players unless you finalize it first.
To finalize, look on remote for the TOOL button. Press it once. Now push DISC INFO once. Use arrow keys and enter button on remote for the following. Scroll down to FINALIZE and press enter.
Use arrow keys to scroll to OK. push the ENTER button. Finalizing should take between 30 seconds and 2 minutes.
Warning- if titles or chapters are to typed in, it must be done BEFORE finalizing. Finalizing afterwards cannot be done.
Erasing can be done in part or all if using an RW+ or RW- disc
Dave
[email protected]
Nov 19, 2009 | Sony RDR-GX300 DVD Recorder
Sony RDR-GX300 DVD Recorder won't play dvd but plays CD
Usually when a dvd player starts doing that it indicates the unit needs to be repaired. Please visit the link below for Sony. You can either calll them or contact them online and chat with a live person. If there are any options other than having the unit repaired or replaced, they will be able to give them to you.
http://esupport.sony.com/US/perl/support-contacts.pl?
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Aug 04, 2009 | Sony RDR-GX300 DVD Recorder
Sony DVD RECORDER/PLAY WON'T PLAY
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
Jan 18, 2009 | Sony RDR-GX300 DVD Recorder
Can't play Burned DVD's
This is because when you burn a DVD and want to use it on another unit you have to finalize it. Especially from another device such as your computer. You should have the option on your computer to finalize or make disc compatible.
Please message back if you need further assistance
Sep 06, 2008 | Sony RDR-VX525 DVD Recorder/VCR
Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Jul 01, 2007 | Sony RDR-GX300 DVD Recorder
Sony RDR-GX300 DVD Recorder Logo
480 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
