Question about HP Compaq nx6110 Notebook
Monitor I had problems with my HP NX 6110 monitor, there are many vertical dotted lines on my screen. I don't know what to do, please help
On my screen I keep seeing red vertical stripes. How do I get rid of this?
You can try to hook up an external monitor. If the vertical linea are visible on the external display, try to update your video card driver. If it is not showing in the external monitor, You are having an LCD problem.
If you don't have any external monitor, go to BIOS setup and check if the lines are visible, if yes, you're having an LCD/screen problem. You need to replace either the LCD cable, LCD inverter or LCD itself.
Hope this helps.
Jul 17, 2011 | HP Pavilion dv4-1020us Notebook PC
Tiny pink dots will appear over the entire monitor viewing area
Its a signal cable problem,between AD bord to Panel..Fix it poperly, If no then replace the LCD panel..
Jul 10, 2009 | HP w17e Monitor
Vertical red line on HP w2207 monitor
Please try to connect the monitor to another PC, if problem still exist then probably there's an internal problem in the circuit board of your monitor wherein an elecronic part/s might be cold soldered / defective. I recommend to bring the monitor to an authorized HP service center to fix the problem. If the monitor display is good if connected to other PC, then your previous PC should be checked if the VGA card (if there is any) is properly placed to its slot & working properly as well as it cables & connections. regards
May 29, 2009 | HP w2207 Monitor
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
May 25, 2009 | HP f2105 Monitor
White vertical line on my hp compaq nc8000 monitor
Hi there welcome on!
Try another screen and tell me if you still have the line !
Apr 04, 2009 | Compaq NC8000 Notebook
Vertical Lines in Monitor
If the lines are only on your laptop screen, it is generally the display IC on the LCD panel.
When plugged into an external monitor and you still see the lines, it is the video memory on your laptop.
Dec 23, 2008 | HP Pavilion dv8000t Notebook
HP compaq nx 6110 blinking
try and connect a monitor to the external monitor connection at the back and check whether the same thing happens. probably it wont and this will mean that the screen is having luminosity problems and might need to be changed.
Aug 25, 2008 | HP Compaq nx6110 Notebook
Laptop is HP zd8639ea 17" screen. A thin vertical line of very small flashing dots has appeared in the centre of the screen. How to get rid or is it replacement screen time?
Hello Dave 1011
There's a (very) slim chance it's a cable issue. More than likely, however, it is, as you suspect, the monitor.
If you're handy w/ tools and such, you can replace the monitor yourself. It'll cost at least $225US so, shop around for a good deal. (Aside from the motherboard, the monitor is the most expensive part of your laptop.)
You can run a test of your video to confirm the problem. However, when the issue is localized on the screen like that, that's a red flag that your problem is hardware.
For now, you can connect an external monitor to your laptop. In fact, that's the best way to pin down the problem to the monitor (or cables connecting to the monitor). Do this before shelling out the bucks for a new or refurbished monitor.
If the problem persists while using an external monitor, then, the problem is still likely to be a hardware issue - but it isn't your monitor. The issue is in your video circuitry. Now you're talking about a new motherboard.
I also recommend you find the product service manual for your laptop and follow the steps for disconnecting the monitor from the laptop. Then, reconnect it. See if there are any changes in the symptoms. If you need help w/ this, just let us know.
Please, let us know if this was helpful for your or, of course, if you have any further questions.
Thank you
Apr 03, 2008 | Computers & Internet
HP L1706 monitor with thin white/blue horizontral line
It is the problem of monitor pcb in vertical section.check vertical ic for dry soldring. Resolder the ic if problem still on then change ic or check components related ith it. check continuity of vertical deflection coil.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 13, 2008 | HP L1706 17" LCD Monitor
Bright,thin line, in the middle of the screen, then...
1. I turn on the monitor, I hear a 'cracklin' sound
Reply: In a CRT Monitor there is a component called EHT which generates High voltage which is connected to the anode of the CRT, If there is any leakage due to moisture can cause this crackiling sound, You need to clean this high tension wire or replace the EHT ( CAUTION : BE AWARE OF HIGH VOLTAGES )
2. The screen only shows a bright, thin line.
Reply: The vertical Drive section of the monitor is faulty.
Dec 21, 2007 | Hitachi SuperScan Elite 802 21" CRT...
HP Compaq nx6110 Notebook Logo
110 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
