Question about Maytag Neptune MDE5500AY Electric Dryer
Neptune Dryer We purchased Neptune washer and dryer several years ago and then began to hear horror stories about the moisture/mildew problems and electronic board failing with the washer (we even received information on a class action suit) - We have always been careful to leave the washer door open when not in use and thankfully have never had a problem (knock on wood & fingers crossed). BUT - This morning my wife went down to dry a load of clothes and found that the drum was not turning, it does get hot and it appears everything is working on the digital panel, the drum just doesn't turn?? HEELLLP!!!!
  • 164 Answers
The belt needs to be replaced. open the front of the dryer, remove the bulkhead and install belt. or call your service guy and have him do it
Posted on Sep 05, 2008
Whirlpool cabrio dryer has water in it. Lent filter is also wet. Last time used was over a week ago. Why? Have had dryer for over a year and never have i encountered this problem with this dryer or any...
this happen with the dryer A typical 12-pound load of laundry weighs about 20 pounds when it emerges from the washer, meaning that a dryer has to dispose of about a gallon of water with every load. Because of the moisture, exhausting the dryer to the outside is recommended since indoor exhausting can cause mildew and other problems.
Typical ventilation is recomend see the diagram .God bless you56ed11ca-7868-4b1a-955e-88eafd615327.gif
Jul 13, 2013 | Dryers
Washer& dryer
I have never had the problems you describe in any top loader. You can always leave the lid open between wash sessions to allow interior moisture to evaporate
May 11, 2013 | Honeywell Heat/Cool Thermostat
Neptune 5500 gas dryer runs but no heat. I cleaned out the exhaust ducts already.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Matage neptune mah8700aww purchased five years
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
Jul 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
Water between the drum even when not on
Water between the drum is a common problem with not only front load but top load as well.
Front load washers such as the neptune have an airtight/water tight door which will hold moisture in the machine when closed. Try opening door and keep open between loads. In addition, a monthly cleaner specific for the front load machine will help this problem
May 29, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Maytag Neptune/ clothes smell like mildew
Go out and buy a box of "AFFRESH". Run it according to the directions.
May 28, 2009 | Maytag Neptune Washer
Dryer door will not open
only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
Nov 13, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer Model MCE800AYW
Dryer is throwing sparks when running and the back inside of the drum assembly is really hot to the touch?
Apr 08, 2008 | Dryers
Mildew smell and sound of water
Momma, Maytag put out a service bullitin on this problem. TB26-72. This is a common problem on your model. Why don't you google the service bullitin and it will give you the instructions they have for this problem. If you can't find it, post back and I will post them for you...Catriver...post back.
Sep 22, 2006 | Maytag Neptune MAH55FL Front Load Washer
Maytag Neptune MDE5500AY Electric Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
